GlennWest Posted August 24, 2021 Report Share Posted August 24, 2021 (edited) Toilet in my Teton is orginal. About a year or so ago spring broke that holds the valve shut. Now the spring is broke again and foot valve seeps water. I never got the replacement spring to work smoothly. I understand the new 320 dometic foot valve is push down to flush and half way for water. No lifting up. Ours we half to lift up and it is somewhat uncomfortable on the bare foot.They are not costly and about replacement parts are about half the cost of new one. We do have a sprayer on ours which we use. Does the new 320 work this way? Ours look like the 510 Edited August 24, 2021 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Randyretired Posted August 24, 2021 Report Share Posted August 24, 2021 The spring in our Sealand toilet breakes every year or 2. I keep a spare on hand. Lifting the pedal is kind of pain. Quote Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
Ray,IN Posted August 24, 2021 Report Share Posted August 24, 2021 The Sealand is actually a Dometic 510; parts fit my Sealand exactly, when you remove the plastic shroud that covers the pedestal you should find a sticker with make and model . The new spring design is approx. 1/2 as strong as the original. Do not allow the pedal to slam back to the closed position or the spring breaks in a short while. When I overhauled our commode I replaced everything for which parts are available. I should have left the OEM spring cartridge in place. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
GlennWest Posted August 24, 2021 Author Report Share Posted August 24, 2021 Yes, replacement never did work good. But how is the 320 unit. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
TXiceman Posted August 24, 2021 Report Share Posted August 24, 2021 We tried a Dometic 320 and it was JUNK. With proper water flow and pressure, it would not sweep the front of the bowl. I would repairing my old Thetford and returning the JUNK. At least on the Thetford, you can get repair parts and they are not subject to leaks. Read up on the 320 problems before you jump in. Ken Quote Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
GlennWest Posted August 24, 2021 Author Report Share Posted August 24, 2021 Repair pats on mine are substandard. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted August 25, 2021 Author Report Share Posted August 25, 2021 Been researching and not found a lot of negative concerning the 320. Yes, they are negative but that is same for all of them Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Ray,IN Posted August 26, 2021 Report Share Posted August 26, 2021 The Dometic 300 series is all plastic, the 500 series has a ceramic bowl. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
GlennWest Posted August 26, 2021 Author Report Share Posted August 26, 2021 (edited) 320 is ceramic. 300 plastic Edited August 26, 2021 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
dennisvr Posted August 26, 2021 Report Share Posted August 26, 2021 I have 1 1/2 baths in the 5er and (2) 320s. One started to leak between the two sections (you cannot take apart to repair) and the other has a weak spring (no parts available) Mine are 10 yrs old I think the newer ones you can replace the springs, not sure about that. Quote "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
GlennWest Posted August 26, 2021 Author Report Share Posted August 26, 2021 (edited) went on amazon and parts are there. ball seal, water valve. Edited August 26, 2021 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
KeepingUpWithTheJoneses Posted August 10, 2022 Report Share Posted August 10, 2022 Ours broke after 2 years, replaced the cartridge 6 months ago, just broke again. Obviously the manufacturer has no incentive to correct this defect. Quote There's more to see than can ever be seen More to do than can ever be done Link to comment Share on other sites More sharing options...
