Sculptor Posted July 24, 2021 Report Share Posted July 24, 2021 Hello, I’m looking for a good reference in central Montana. In April this year, we had one AC blower professionally replaced. The service company owner said he happened to have one in stock and he came right to our campsite and installed it. Early this morning it started making a strange grinding noise so my wife shut it off. It has been cool at night but we leave it on and let the thermostat do it’s job. It has been very hot in the upper west mountain time zone, so I might need yet another unit to replace this one. If, that’s IF, I have to replace it, can anyone suggest a reputable place to buy from in Montana near Bozeman or Billings? We are looking for the purchase receipt this morning. Perhaps there will be a warranty. Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Wrknrvr Posted July 24, 2021 Report Share Posted July 24, 2021 It could be possible that the blower fan moved on the shaft. Hopefully it could be moved and work good again. Vern in a T-shirt Quote Link to comment Share on other sites More sharing options...
Chad Heiser Posted July 25, 2021 Report Share Posted July 25, 2021 I just installed a second AC in a friend’s 5er. Before I put it on the roof, I took the shroud off and checked things out. I spun the fan by hand and it was making a loud rubbing noise. It turned out the fan motor mount got tweaked a little during shipping and the fan was rubbing on the styrofoam housing. I was able to re-tweak the motor mount to get the fan moved back into the correct position and stop the rubbing. It is possible your fan is rubbing on something. This can be a quick DIY fix if that is what the issue is. Quote 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
TXiceman Posted July 25, 2021 Report Share Posted July 25, 2021 Manufacturers are building these unit lighter and cheaper. The base plates are thinner and more prone to warping if not handled correctly. Last year, I replace the two older Coleman Mach units with Coleman Mach 8 Plus. The base plate is now plastic and you have to be sure and get some extra foam support under them to dampen the vibration. I also had to go through the unit and tighten all os the not tight enough nuts and screws and tie down a few wires. Problem was lack of quality control. Ken Quote Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
Sculptor Posted July 25, 2021 Author Report Share Posted July 25, 2021 I hope to get up there today before it gets too hot, and take a close look. Thanks guys for your experience. Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
