RV_ Posted July 21, 2021 Report Share Posted July 21, 2021 Excerpts: "The good news is that Red Hat Product Security and systemd's developers have immediately patched the hole. July 20, 2021 -- 16:04 GMT (09:04 PDT) | Topic: Security Systemd, the Linux system and service manager that has largely replaced init as the master Linux startup and control program, has always had its critics. Now, with Qualys's discovery of a new systemd security bug, systemd will have fewer friends. Successful exploitation of this newest vulnerability enables any unprivileged user to cause a denial of service via a kernel panic. As Bharat Jogi, Qualys's senior manager of Vulnerabilities and Signatures, wrote, "Given the breadth of the attack surface for this vulnerability, Qualys recommends users apply patches for this vulnerability immediately." You can say that again. Systemd is used in almost all modern Linux distributions. This particular security hole arrived in the systemd code in April 2015. It works by enabling attackers to misuse the alloca() function in a way that would result in memory corruption. This, in turn, allows a hacker to crash systemd and hence the entire operating system. Practically speaking, this can be done by a local attacker mounting a filesystem on a very long path. This causes too much memory space to be used in the systemd stack, which results in a system crash. That's the bad news. The good news is that Red Hat Product Security and systemd's developers have immediately patched the hole. There's no way to remedy this problem. While it's not present in all current Linux distros, you'll find it in most distros such as the Debian 10 (Buster) and its relatives like Ubuntu and Mint. Therefore, you must, if you value keeping your computers working, patch your version of systemd as soon as possible. You'll be glad you did. In a phrase, "that's bad, that's really bad." Much more with related hotlink here: https://www.zdnet.com/article/nasty-linux-systemd-security-bug-revealed/?ftag=TREc64629f&bhid={%24external_id}&mid={%24MESSAGE_ID}&cid={%24contact_id}&eh={%24CF_emailHash} Quote RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
