Travel Trailer - and Vehicle - How Old Can a Vehicle Be and Still Tow Safely?
J1955
Hi, I'm looking at several options for a vehicle that can pull a travel trailer primarily. My question revolves around how old is too old to safely pull a trailer? How would I know? Some SUV's for example have tow hitches installed already. Others obviously don't. I'm concerned about rust for example, and how would you know if it's safe? Is it a 5 year old vehicle? 10? Vehicles to stay away from?
Thanks!
John
I think it would depend on how many miles the older vehicle has and how well maintained.  I know that when I sold my 5 year old Grand Cherokee, with 95,000 miles on it, it was just as capable of towing a trailer within its capability (under all of the weight ratings) as it was the day I bought it.  I couldn’t say that for all 5 year old Grand Cherokees.  I also know that it was no longer capable of towing my particular trailer any more, because I had added a second battery and the tongue weight was now over what that Grand Cherokee was rated for.  The combined rig was not over the Grand Cherokee’s combined weight rating, the Grand Cherokee itself, when hooked up to the trailer, might not have been over its GVWR, and it might not have been over the rear axle rating (I never actually hitched it up and visited a CAT scale once I added the second battery, I just checked the tongue weight and said forget it).
Stay away from any vehicle that doesn’t have the payload, tongue weight rating, axle rating, tow rating or combined weight rating of the vehicle in question.  If I want to tow a 30 foot 10,000 lb travel trailer, I would stay away from ALL half ton trucks.  If I want to tow a 21 foot 5500 lb travel trailer and have a lot of weight in the truck (i.e., shell cap, generator, extra propane tank, extra spare tire, several tables, chairs, two large dogs, two people, 100 lbs of photography equipment, two electric bikes, firewood, 6 gallons of water, large cooler of beer and other beverages, and so on) then I probably should skip the half ton trucks also.
On the other hand, if I wanted to tow that same 5500 lb. trailer as a solo and without much extra stuff, then most - but not all - of the half ton trucks would work well.
As far as SUVs go - if the SUV doesn’t have the factory tow package, forget it.  The Grand Cherokee with the factory tow package I had (2015) was rated at 6200/6400 for a V6 and 7200/7400 for a V8 or diesel.  Without the tow package, the same Grand Cherokee was rated at 3500 lbs.  The same sort of thing applies to all of the SUVs, though the amounts vary from model to model.
The other thing about SUVs - the towing weight rating is probably not the limiting factor for the vehicle - often the limiting factor is the tongue weight and/or the payload.  That was the case with my Grand Cherokee - it was rated at 6200 lbs for a trailer but the tongue weight was limited to 620 lbs.  After I added the second battery, my 5500 lb. trailer had a tongue weight of 750 lbs.
Best way of going about things is to choose the trailer and then choose a vehicle that can tow it.  Otherwise you could find yourself being forced to buy a smaller trailer than you would like because your tow vehicle is too limiting.
I tow our travel trailer with a 2003, Dodge, 2500, crew cab, diesel truck. If the vehicle is mechanically sound and has the weight capacity, there is no reason that it would not work. On the other hand, if worn out it will not be reliable. My 2003 has 135k miles.
  • 1 month later...
As long as you maintain the equipment, running gear , etc.  You can tow older rigs.  Back in the 1990s, we had a 1979 Silverstreak that we refurbished.  After that we refurbished an 1989 Avion.
The key is maintenance.
Ken
  • 2 months later...
  • 2 months later...
Old thread (more than 1/2 year from the start) now, but a few key points.
Others have hit on the maintenance and integrity on vehicles - this is the key.
A few key areas:
- Drivetrain (engine down to hubs) - A good mechanic can tell a lot about key components (engine, trans, differentials) by looking at the oil and checking for metal particles, for example. Spark plugs on gasoline engines can also be tell-tales.
- Frame - Rust was already pointed out. On pickup trucks sometimes the bed mounts + rails and body mounts can rust through.
- Suspension components - Namely springs and spring mounts. Coil and leaf springs can both fail after a lot of loaded miles and with the help of rusting. This is something I am looking at replacing on my truck - both front coils and rear leaf packs. I don't have any visible issues with them yet, but I do look at them every time I am working on the truck just in case. 2011 F350 with north of 177k miles and going, I'm the original owner.
- Hitch components - This really gets back to the frame question as hitches are part of the integrity of the frame/structure of combinations (trucks/trailers).
- Any weldment - inspect welds for cracks. Cracks generally propagate in-line with welds if there are any. These can develop around the HAZ (heat affected zone) of the base metal next to the weld/edge of weld as well as right smack down the middle of the weld beads. I'd generally say that, on steel, rust is a bigger issue to keep an eye on than welds being an issue, but both are good to keep in check.
Edited by FlyFishn
