RV_ Posted July 9, 2021 Report Share Posted July 9, 2021 This is an excellent article for folks that want maximum speeds from their AIOs, desktops, laptops, and mini PCs - for any PC or Mac where you can upgrade the storage drives. Excerpt: "Computer enthusiasts of all stripes and skill levels are likely familiar with common hard drive form factors like the big and bulky 3.5” mechanical hard disk drive (or HDD) and the slimmer and smaller 2.5” solid state drive (SSD). If you know about HDDs and SSDs, you likely also know about the SATA (or Serial AT Attachment) computer bus interface that’s typically used to connect drives to the computer’s motherboard. And though these remain the most common form factors and connection options, M.2 and NVMe drives are becoming more popular in modern PC builds. Now, to be clear, M.2 and NVMe aren’t interchangeable terms, but they are closely linked. In this explainer, we’ll break down exactly what M.2 and NVMe are, where they differ, and how they can ultimately benefit your next PC build. The M.2 Form Factor The M.2 form factor (formerly known as the Next Generation Form Factor, or NGFF) is a more modern type of internally mounted expansion card that replaces the previous mSATA (Mini-SATA) standard. Unlike standard HDDs and SSDs, M.2 drives aren’t connected to a motherboard via a cable, they’re instead plugged directly into the motherboard using a dedicated M.2 connector slot. Depending on its type and functionality, an M.2 drive can make use of either the standard SATA interface or the faster PCIe (Peripheral Component Interconnect Express) interface, but in both cases it plugs directly into the motherboard. Since they fold down and lie flush with the motherboard once they’re connected rather than jutting out like a graphics card or RAM chip (or a traditional HDD or SSD), M.2 drives allow for a cleaner, less cluttered PC interior with fewer cables to manage. Certain desktop PC peripherals like wi-fi cards can come in the M.2 form factor, but the most common use for M.2 is SSD data storage, basically functioning as an alternative to the existing 2.5” storage drives that are mounted in a separate bay and then connected to the motherboard via a SATA cable. It’s important to note that M.2 SSDs which utilize the SATA interface aren’t really faster than standard 2.5” drives, they just take up less space and look cleaner. If you want faster speeds, you’ll have to make sure your M.2 drive is utilizing the NVMe interface protocol." Much more with videos and related hotlinks in the other 2/3rds of the article here: https://www.newegg.com/insider/m-2-and-nvme-ssds-what-are-they-and-how-do-they-benefit-your-pc/?cm_sp=50338_1_DM__article_-_-Pers_EmailOTMayweSuggest_exist-_-2020-12-02t16:10:08.132z&cm_mmc=TEMC-Shipping-New-Tracking-Notification-Responsive-US-_-CR-_-RecommendArticle-_-50338_M.2 and NVMe SSDs: What are they and how do they benefit your PC? Quote RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
