trimster Posted June 28, 2021 Report Share Posted June 28, 2021 Those who have seen the pics of my current hitch, or put eyes on it at the WCR, know that 'Huston, we have a problem '. I'm in the Roadmaster neighborhood so I thought I'd upgrade to the 245. Don't think I'll get a trailer in the future that will exceed it's capacity. I'll feel so much better with a real hitch holding stuff together. They will do the installation. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
MoneyMakeranch Posted June 28, 2021 Report Share Posted June 28, 2021 have no more info other than the pics shown https://lasvegas.craigslist.org/rvs/d/tecopa-air-ride-5th-wheel-hitch/7340591536.html looks to be all there ? good luck on a replacement hitch. Quote Link to comment Share on other sites More sharing options...
trimster Posted June 28, 2021 Author Report Share Posted June 28, 2021 (edited) Found this one close. It's a 2008 TS3 https://portland.craigslist.org/clc/tro/d/oregon-city-5th-wheel-hitch/7342015631.html Thoughts. It is a few years old. Last owner has it for 4 yrs but only went out 5 times. Edited June 28, 2021 by trimster Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
MoneyMakeranch Posted June 28, 2021 Report Share Posted June 28, 2021 good luck on whichever hitch you decide on. maybe well cross paths at one of the rallies and compare trucks. Me 2012 Volvo 780 Quote Link to comment Share on other sites More sharing options...
trimster Posted June 29, 2021 Author Report Share Posted June 29, 2021 Anyone mounted a Trailer Saver TS3 to an HDT? Use standard mounting rails? Or something beefier? I'm now researching a shop to install it in Albany, Or. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted June 29, 2021 Author Report Share Posted June 29, 2021 16 hours ago, MoneyMakeranch said: good luck on whichever hitch you decide on. maybe well cross paths at one of the rallies and compare trucks. Me 2012 Volvo 780 Thanks for the help. I didn't think about hitting up Craigs List. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Radar274 Posted June 29, 2021 Report Share Posted June 29, 2021 (edited) 47 minutes ago, trimster said: Anyone mounted a Trailer Saver TS3 to an HDT? Use standard mounting rails? Or something beefier? I'm now researching a shop to install it in Albany, Or. Yes, we mounted ours using standard mounting rails on a 1/2 plate. We have been hauling a 20,000 DRV for 5 years without any problems, the airbags are filled to 65 lbs. The Hitch was used on our dually for 5 years before mounting on the Volvo. We installed addition rails so we could move it up closer when not hauling anything on the deck. Safe travels Bob Edited June 29, 2021 by Radar274 Quote Bob&Kay 2012 VNL730 I Shift D13 2.47 ratio 2018 Mobile Suites 40 kssb4 Link to comment Share on other sites More sharing options...
steiny93 Posted June 29, 2021 Report Share Posted June 29, 2021 I installed an Air Safe hitch on an HDT, didn't use standard rails, used 3x6x1/2 steel tubes. The tubes were bolted to the top plate on the HDT, then the hitch was bolted to the tubes. Worked very well in that I could adjust the hitch location via swapping out different length of tubes. Very very easy Quote 2000 volvo 6102013 cyclone 3950 Link to comment Share on other sites More sharing options...
GlennWest Posted June 29, 2021 Report Share Posted June 29, 2021 I have to say this. I have the ET Hitch by Henry. Actually Henry built mine. My Teton rides so smooth. Nothing gets out of place. I never had this good a ride with other hitches. Even the air ride hitch I had on my dually didn't ride this smooth. There is zero back and forth/chucking movement like most hitches have. Henry really nailed this with his design. It does come at a high price but is well worth it. I just made over a 1k mile trip. Over some rough places too. Lots of construction. Nothing is out of place. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Randyretired Posted June 29, 2021 Report Share Posted June 29, 2021 (edited) I mounted a Trailer Saver hitch before Henry started selling his hitches. It was used and I have had to do some things to keep it going including a new hitch head. I added the 3rd bag.. To increase the weight on the rear axles I mounted it on 1/2" plate. Our Teton is heavy on the hitch, about 6,000 pounds+. It rides pretty good about like Glenn described his hitch. I do think Henry's is a better design but the cost to change is not worth it to me. Edited June 29, 2021 by Randyretired Quote Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
trimster Posted June 29, 2021 Author Report Share Posted June 29, 2021 2 minutes ago, Randyretired said: I do think Henry's is a better design but the cost to change is not worth it to me. This is my logic as well. I'll probably get the hitch for $850 and put another $300 in materials + labor to mount it up. Way cheaper than the Comfort Ride + install. I drive up to see the hitch later this afternoon. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
rickeieio Posted June 29, 2021 Report Share Posted June 29, 2021 We've been pulling with the 3 bag TrailerSaver on our 770 for 8 or 9 years. No issues. We have a 5x5x5/8" angle bolted to the inside of the frame rails, then the hitch bolted to the angles. Put a leveling valve on it and do away with the gauge. Several of us have done it, Geodog, Paul G, and myself. Likely others too. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
trimster Posted June 29, 2021 Author Report Share Posted June 29, 2021 24 minutes ago, rickeieio said: We've been pulling with the 3 bag TrailerSaver on our 770 for 8 or 9 years. No issues. We have a 5x5x5/8" angle bolted to the inside of the frame rails, then the hitch bolted to the angles. Put a leveling valve on it and do away with the gauge. Several of us have done it, Geodog, Paul G, and myself. Likely others too. Possible that you could send a photo or two of the way you have it mounted? Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
rickeieio Posted June 29, 2021 Report Share Posted June 29, 2021 I have three pictures that show what you're asking, and can't figure out how to get them here. They're on google drive. I even tried to email them to you. No luck. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
rickeieio Posted June 29, 2021 Report Share Posted June 29, 2021 Finally resorted to pulling the pics up on the screen, taking pictures of the pics, and emailing them. This whole google drive thing is a pita. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
trimster Posted June 29, 2021 Author Report Share Posted June 29, 2021 Ya. Pretty much. Thanks. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted June 29, 2021 Author Report Share Posted June 29, 2021 Email hasn't arrived. Hmmmm. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted June 29, 2021 Report Share Posted June 29, 2021 1 hour ago, rickeieio said: Finally resorted to pulling the pics up on the screen, taking pictures of the pics, and emailing them. This whole google drive thing is a pita. Rickeieio. Paste a link to the drive location. In other words, move your cursor up to the address bar at the top of the screen. Left click to turn the address blue. Right click, then select "Copy" Come back here, "Paste" in the reply window. Submit reply. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
trimster Posted June 30, 2021 Author Report Share Posted June 30, 2021 Got the hitch... Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
jenandjon Posted June 30, 2021 Report Share Posted June 30, 2021 You will be much happier with that. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
rickeieio Posted June 30, 2021 Report Share Posted June 30, 2021 I re-sent using the computer rather than my phone. We'll see....... Our hitch has mounting flanges on the side plates, not the fixtures for attaching to the rails. I would think any welding shop would be able to make your fit just fine. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
trimster Posted June 30, 2021 Author Report Share Posted June 30, 2021 Found a local fab shop. Scheduling is the issue now. Always something. But we can extend our site here. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted July 7, 2021 Author Report Share Posted July 7, 2021 Hitch installed. Whooohooo! The shop did a great job and did it in essentially one day (picked up the truck 10am the next day). Went above and beyond. If you need work done in the Albany, Oregon area.... Sheet Metal Solutions. Big operation that knows what they are doing. I was a rush job, they squeezed in. Only $920 out the door. I was expecting way more. Like most places out here, cash saves you 3%+ credit card fee. They built a platform that can be removed if I change hitches down the road. But this hitch mounts on typical rails so welded to the riser frame are beefy rails. I've done a test hook to the trailer and the height seems to be spot on. We'll pull the hell out of it Friday as we move to the coast of Washington. Looking forward to watching a hitch in the camera that does not flex all over the place and helps with chucking. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
dblr Posted July 8, 2021 Report Share Posted July 8, 2021 Congrats and looks like a great job!!!!! Quote 2017 River Stone Legacy 38MB 2001 T2000 Kenworth 2009 Smart Passion ET Junior hitch Link to comment Share on other sites More sharing options...
trimster Posted July 10, 2021 Author Report Share Posted July 10, 2021 5 hr pull yesterday from Albany, or. to Ocean Park, WA. On the coast where it's mucho cooler. Beat the snot out of the hitch. Up hill, down hill with hard braking, bad roads (the ones that take your seats full-range), and nothing broke. Nice! Watched my hitch-cam. This Trailer Saver was taking the brunt of it with seeming little effort. Does take a load off ones mind knowing the hitch part of the system is up to snuff. I do want to extend the Schrader valve to an easier location to reach. Maybe the auto leveling valve upgrade might be the trick. Hmmmm. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
