etcetera Posted June 20, 2021 Report Share Posted June 20, 2021 How hard is it to do any maintenance on Class A, both pushers and the engine is in the front configurations? Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted June 20, 2021 Report Share Posted June 20, 2021 It's easy. You give your credit card to the nice guy at the service counter, the sweating and grunting occurs out of sight and ear shot, easy peasy. In reality, your question should be a 2 parter. Side engine fan models are typically easier to service than rear fan models, while front engine models are just a bear. A lot of side fan pusher service can be done without entering the cabin, a little less on the rear fan pushers. Much more work on front engine models will require removal of the doghouse, and working from inside. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
etcetera Posted June 20, 2021 Author Report Share Posted June 20, 2021 I am specifically interested in this class A model. Supposedly removing the doghouse exposes the entire top of the engine. I have never owned a class A so have a hard time visualizing this. youtube searches went nowhere. 2004 Itasca Sunrise M-30W Quote Link to comment Share on other sites More sharing options...
Kirk W Posted June 20, 2021 Report Share Posted June 20, 2021 8 minutes ago, etcetera said: Supposedly removing the doghouse exposes the entire top of the engine. It actually varies quite a bit from one make/model to the next. I doubt that any of them would be considered to be easy to access things like sparkplugs. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Darryl&Rita Posted June 20, 2021 Report Share Posted June 20, 2021 (edited) Here's a generic version; How to Remove the Doghouse (Engine Cover) from RV - YouTube Most doghouses aren't a 2 piece setup, like he's showing, and usually have a bolt in each rear corner, and either a screw or buckle in each front corner. You can touch most of the top, but you'll be working from the bottom for spark plugs and things like that. Air filters are remote mounted now, as are cabin air filters. Oil filters might be engine mounted, or remote, but they're underneath work, either way. Edited June 20, 2021 by Darryl&Rita Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
