dewilso Posted May 27, 2021 Report Share Posted May 27, 2021 Does anyone here KNOW, based on their own experience, if Eternabond Primer leaves a residue in the overspray area? Quote Dave W. KE5GOH Stuck in the 70's --- In E. Texas Link to comment Share on other sites More sharing options...
Ray,IN Posted May 27, 2021 Report Share Posted May 27, 2021 No personal experience, however the Eternabond library might shed some light: https://www.eternabond.com/articles.asp?id=200 The RV section is lower half of webpage. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Will B. Posted May 27, 2021 Report Share Posted May 27, 2021 You could just tape the area, if it's not too late. Like blue painter's tape, etc. Then you could just peel it off. When in doubt, that's what I do. Protect all the things! Quote 2018 Grand Design Momentum 399TH • 2019 Ford F-350 (DRW) 2016 Harley-Davidson Heritage • 2013 Harley Sportster with a sidecar Web: https://MyRVRadio.com • Facebook: https://fb.com/MyRVRadio Link to comment Share on other sites More sharing options...
dewilso Posted June 1, 2021 Author Report Share Posted June 1, 2021 Did not seem to leave a residue. Quote Dave W. KE5GOH Stuck in the 70's --- In E. Texas Link to comment Share on other sites More sharing options...
57becky Posted June 5, 2021 Report Share Posted June 5, 2021 This is from the Eternabond site: EternaPrime® is an adhesive and surface conditioner intended to aid adhesion of EternaBond® MicroSealant tapes, or other non- MicroSealant tapes such as butyl tapes and other self adhesive seaming tapes. EternaPrime® is also an excellent primer for use with self-adhered modified bitumen membranes. Use EternaPrime® when surfaces to be bonded are very dirty (oxidized and cannot be easily cleaned), or dusty (like on a tar and gravel roof). EternaPrime® will prepare the surface by coalescing all loose particles into a solid platform for the EternaBond® tape to adhere to. EternaPrime® allows EternaBond® MicroSealant tapes to be installed in temperatures as low as -20°F (-29°C). EternaPrime® also prepares most contaminated surfaces for tape application. I don't think any overspray on the roofing material will hurt anything. Quote Link to comment Share on other sites More sharing options...
