tazh2o Posted May 22, 2021 Report Share Posted May 22, 2021 just got visable an a gl inet router I cant get them to work together no matter what i try. anyone have some detailed instructions on how to set up Quote Link to comment Share on other sites More sharing options...
Ski Posted May 22, 2021 Report Share Posted May 22, 2021 Make sure your phones hotspot is on. Follow the instructions that came with the router. Quote Link to comment Share on other sites More sharing options...
tazh2o Posted May 22, 2021 Author Report Share Posted May 22, 2021 did that doesnt work Quote Link to comment Share on other sites More sharing options...
LindaH Posted May 22, 2021 Report Share Posted May 22, 2021 8 hours ago, tazh2o said: just got visable an a gl inet router I cant get them to work together no matter what i try. anyone have some detailed instructions on how to set up See if these instructions will help -- they helped me when I was having problems getting my Visible phone to work with the router (instructions were provided to me by forum member, mrschwarz): https://drive.google.com/drive/folders/1deQiLekBPFNiST0iafzFRYs-CK25pzkr?usp=sharing Quote Link to comment Share on other sites More sharing options...
docj Posted May 22, 2021 Report Share Posted May 22, 2021 You don't say what kind of phone you are using for your Visible account. If it is an iPhone you need to understand that connecting an iPhone's hotspot to a non-iOS device can be a bit challenging. If you are using an iPhone, let me know and I'll walk you through the steps you need to take. Quote Link to comment Share on other sites More sharing options...
tazh2o Posted May 23, 2021 Author Report Share Posted May 23, 2021 thanks finally some good input Quote Link to comment Share on other sites More sharing options...
LindaH Posted May 23, 2021 Report Share Posted May 23, 2021 8 hours ago, tazh2o said: thanks finally some good input So, have you tried the instructions and did they work? Quote Link to comment Share on other sites More sharing options...
zealot Posted May 26, 2021 Report Share Posted May 26, 2021 On 5/22/2021 at 10:17 AM, docj said: You don't say what kind of phone you are using for your Visible account. If it is an iPhone you need to understand that connecting an iPhone's hotspot to a non-iOS device can be a bit challenging. If you are using an iPhone, let me know and I'll walk you through the steps you need to take. Hey docj, how would I go about setting this up for the first time on an iPhone? Quote Link to comment Share on other sites More sharing options...
docj Posted May 26, 2021 Report Share Posted May 26, 2021 12 hours ago, zealot said: Hey docj, how would I go about setting this up for the first time on an iPhone? IPhone hotspots have sort of a "sleep mode" in which they become invisible to non-Apple devices. What I have found works best is to start by: 1. Turn hotspot off 2. Turn WiFi totally off for 30 seconds then back on 3. Turn hotspot on and make sure to check the box "Share this connection" 4. Use the "quick menu" that you get by swiping down from the right corner to temporarily turn off WiFi otherwise the phone will use WiFi rather than LTE. If this doesn't make the hotspot visible to other devices then reboot the phone and try again. Quote Link to comment Share on other sites More sharing options...
