trimster Posted May 10, 2021 Report Share Posted May 10, 2021 So, this morning I was pulling my trailer in the rain to a shop for suspension work. Pulling away from a stop, slight incline, the Volvo tires spun and then grabbed, then spun then grabbed. BIG jerk on the trailer hitch. And here is the result. These blocks hold the top of the 1" rod that the hitch floats on. Being under-engineered (not long enough to distribute the fore and aft stress widely enough) the blocks held but the steel bent. I have a solution to fix this. Longer blocks, 4 thru bolts and a stiffener plate on the other side of the plate. It's kinda like putting a bandaid on skin cancer and hoping it will get better I think. So looking for a new hitch. Budget is tight. Used is good. For future trailer upgrade, I'd like to find something that would hold 4k pin weight and 25k-32k trailer. Suggestions, leads on where to get something are welcomed. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
rickeieio Posted May 10, 2021 Report Share Posted May 10, 2021 Perhaps the difference between a used hitch v. new aren't that great. The only new hitch I've priced is an E.T., which has a 4-6 week wait period. Ours ships tomorrow.....$$$ Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 10, 2021 Report Share Posted May 10, 2021 Holy hot mess. How much throttle were you using? That's a new failure point, if it makes you feel any better. The idea of longer blocks, with extra bolts is valid, I'd also look at a stiffening piece welded just above the bolt heads. The grade and quality of the steel in the side plates could also be checked. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
trimster Posted May 10, 2021 Author Report Share Posted May 10, 2021 4 minutes ago, Darryl&Rita said: Holy hot mess. How much throttle were you using? That's a new failure point, if it makes you feel any better. The idea of longer blocks, with extra bolts is valid, I'd also look at a stiffening piece welded just above the bolt heads. The grade and quality of the steel in the side plates could also be checked. Not much throttle at all. Tires were on concrete surrounding RxR tracks. Tires spun on the tracks, grabbed when they hit asphalt. Guess if I had the axles locked it might not have happened. I don't lock them very often when driving. Maybe I will now, if the roads are wet. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted May 10, 2021 Author Report Share Posted May 10, 2021 14 minutes ago, rickeieio said: Perhaps the difference between a used hitch v. new aren't that great. The only new hitch I've priced is an E.T., which has a 4-6 week wait period. Ours ships tomorrow.....$$$ Just called ET. They are way! Out on delivery now. They are having to design a new head apparently. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Star Dreamer Posted May 10, 2021 Report Share Posted May 10, 2021 I think for a 32k trailer, ET may be your only choice. Our Heavy Duty ET Junior is rated for 32k and a 8500 pin rating. If you plan on a 32k trailer you want something with at least a 6500 pin rating (20% minimum of trailer weight). A 25k trailer would be 5k pin weight to get to 20%. Quote 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
rickeieio Posted May 10, 2021 Report Share Posted May 10, 2021 Got the call that our hitch will ship. While I had them on the phone, I asked about a new head design. He said the new head has been on all ET hitches for the past year and a half. It's the design Henry and Young's Welding collaborated on. Some refer to it as the Super Binkley, but there's no Binkley parts used. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
trimster Posted May 11, 2021 Author Report Share Posted May 11, 2021 My bad. It was Air Safe hitch that I called and they are waiting for the new heads to be approved. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Av8r3400 Posted May 11, 2021 Report Share Posted May 11, 2021 IMO, an ET is worth every penny. Quote Av8r34002012 Volvo VNL 730 D13 iShift & 2021 Grand Design Momentum 397TH I'd rather die trying to live - Than live trying not to die. -Leonard Perry Link to comment Share on other sites More sharing options...
aknavy Posted May 11, 2021 Report Share Posted May 11, 2021 (edited) TrailerSaver makes one rated 7.5k/32k. Think it's about $3.5k, but not sure. Edited May 11, 2021 by aknavy Quote 2001 VNL 660 2018 DRV Fullhouse JX450 2018 Jeep Wrangler Rubicon Link to comment Share on other sites More sharing options...
trimster Posted May 11, 2021 Author Report Share Posted May 11, 2021 So, I'm effecting a fix for my existing hitch. I'll post images soon. I was able to straighten the ¼" plate and test fit a fab'd backing-plate. It's a short-term fix addressing 2 of the design flaws, to get us thru this season. One of the issues leading to the side plates bending is trailer breaks. I just replaced them and it appears that only 1 of the 4 are working properly. It's a wiring/ground problem. Easy fix. However, the bending shown in the photo was acceleration. I've wanted to add a pinbox that would take care of chucking. That would have helped in this instance. Ordering one today. I did find several TrailSaver TS3 hitches (used) but the closest is outside Fresno Calif. The other, south-west area of Texas. Bit of a drive from Salt Lake city. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
aknavy Posted May 11, 2021 Report Share Posted May 11, 2021 5 hours ago, trimster said: I did find several TrailSaver TS3 hitches (used) but the closest is outside Fresno Calif. The other, south-west area of Texas. Bit of a drive from Salt Lake city. Check for TSLB's too, if you're considering Trailer Saver. Quote 2001 VNL 660 2018 DRV Fullhouse JX450 2018 Jeep Wrangler Rubicon Link to comment Share on other sites More sharing options...
rickeieio Posted May 11, 2021 Report Share Posted May 11, 2021 We have had a Trailer Saver TSLB for the past 8 or 9 years. It's been fine. It has the upgraded third bag and is rated for something like 7,500# pin and 32k# gross. That said, on the new build we're going with an ET, because for a few dollars ($600ish) more, we're covered for whatever trailer the future might bring. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 12, 2021 Report Share Posted May 12, 2021 Find a used Trailersaver. You can swap the Binkley head for an ET head if its worn out. Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
jenandjon Posted May 12, 2021 Report Share Posted May 12, 2021 Your hitch looks like the Comfort ride 204. Its just too small apparently. You should look at the 308. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
trimster Posted May 12, 2021 Author Report Share Posted May 12, 2021 4 hours ago, jenandjon said: Your hitch looks like the Comfort ride 204. Its just too small apparently. You should look at the 308. It does. It is rated at 17k. My trailer loaded is 13.8k typically. But that hitch rating is bogus. The damage shown was when the trailer was empty (approx 11.8k). Incredibly, I have sent documentation of all the problems with this hitch to PropPride. Crickets. The still have them for sale, albeit hard to find on their site. You have to use the search function to find them. Their published facts on the site are misleading. Their not interested in fixing that either. When they sell them the invoice says "...sold without warranty or guarantee...". ProPrides tongue-pull hitches are really good...and spendy. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
geodog Posted May 12, 2021 Report Share Posted May 12, 2021 Try contacting Roadmaster. They now manufacture and sell the ComfortRide hitches. They might give better customer service than any retailer. ShortyO Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted May 13, 2021 Report Share Posted May 13, 2021 https://store.propridehitch.com/propride-5th-wheel-energy-absorbing-hitch/?gc_id=11804110284&h_ad_id=485097042226&gclid=EAIaIQobChMIl5P2xt7H8AIVF_rICh1f7gHrEAYYASABEgK83fD_BwE Their site says bending is covered under warranty. Hope you get a reply. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
trimster Posted May 14, 2021 Author Report Share Posted May 14, 2021 2 hours ago, SuiteSuccess said: https://store.propridehitch.com/propride-5th-wheel-energy-absorbing-hitch/?gc_id=11804110284&h_ad_id=485097042226&gclid=EAIaIQobChMIl5P2xt7H8AIVF_rICh1f7gHrEAYYASABEgK83fD_BwE Their site says bending is covered under warranty. Hope you get a reply. Yup. But the invoice says "no warranty, no guarantee ". Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 14, 2021 Report Share Posted May 14, 2021 2 hours ago, trimster said: Yup. But the invoice says "no warranty, no guarantee ". But only you've seen the invoice. The website is out there for anyone to see. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
trimster Posted May 17, 2021 Author Report Share Posted May 17, 2021 So, I did a follow-up review on this hitch. Ya, Propride stopped responding to my emails after the first video. This should irritate them more. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
noteven Posted May 17, 2021 Report Share Posted May 17, 2021 If I may be permitted a dumb question (my speciality ) How does a company get away with selling new equipment with "no warranty?" I know the RV world specializes in "useless warranty" (sir we are booking for 123 weeks from now...) but no warranty seems unusual... Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
geodog Posted May 17, 2021 Report Share Posted May 17, 2021 This appears to me to be a "Knockoff" of the ComfortRide hitch. ShortyO Buy an ET Quote Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 18, 2021 Report Share Posted May 18, 2021 There's a guy named Dave ????? that is the hitch building business.... of sorts.... He initially did the Trailer Saver 5th wheel hitch and sold it to Hensley. Then Dave started a few other hitch companies, would build and sell until someone sued him then close up shop, move and modify the hitch a little and start back selling. That's where the Comfort Ride hitch came from that Rick Olson bought and later sold to Road Master. Sometime before Comfort Ride, Dave started using the air cells as the load carrying base. Nice idea, but he usually had structural problems on the surrounding load carrying components. I wonder if this was one of his companies. Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
rpsinc Posted May 18, 2021 Report Share Posted May 18, 2021 6 hours ago, noteven said: How does a company get away with selling new equipment with "no warranty?" Because people buy them. Quote Marcel Link to comment Share on other sites More sharing options...
