gypsydan Posted April 12, 2021 Report Share Posted April 12, 2021 (edited) Needing to fix my EPDM roof. I've used DICOR self-leveling in the past, but would like to find something else. I've talked with DICOR and they admit their sealant has a problem with collecting dirt over time, and thus turning black. I have used elastomeric on the roof of a mobile home, but have heard it does not work on EPDM roofs. Does anyone know of a sealant other than dicor which would do the job, and not collect dirt and turn black? Edited April 12, 2021 by gypsydan didn't do research first Quote 2009 Four Winds Chateau - 25' class C 2002 Chevy Tracker Link to comment Share on other sites More sharing options...
Randyretired Posted April 12, 2021 Report Share Posted April 12, 2021 Eternabond is a tape that is permanent. Seals and lasts longer than dicor. Quote Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
Will B. Posted April 12, 2021 Report Share Posted April 12, 2021 1 hour ago, gypsydan said: ...DICOR and they admit their sealant has a problem with collecting dirt over time, and thus turning black.... It definitely gets dirty, but is super easy to clean, in my opinion. (Not counting having to actually GO up on the roof; that's the hard part!) But a little mineral spirits cleans it right up. I had to remove some Dicor to re-run an antenna wire. While I was up there, I cleaned several spots that were starting to show its age. Quote 2018 Grand Design Momentum 399TH • 2019 Ford F-350 (DRW) 2016 Harley-Davidson Heritage • 2013 Harley Sportster with a sidecar Web: https://MyRVRadio.com • Facebook: https://fb.com/MyRVRadio Link to comment Share on other sites More sharing options...
oldjohnt Posted April 12, 2021 Report Share Posted April 12, 2021 (edited) Pretty well anything up top my RV gathers dirt REGARDLESS of the material grrrrrrrrrrrr I have used Dicor up top, like it and it performs great, as well as Eternabond Tape which, along with the rubber roof, all still gets dirty. HOWEVER I will say the Eternabond Tape being slicker and smoother and even is easier to clean then the Dicor. PS I used Dicor like around roof top vents but Eternabond Tape for say longer cracks or tears but anything up top of course gets dirty grrrrrrrrrrrr John T Edited April 13, 2021 by oldjohnt Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted April 14, 2021 Report Share Posted April 14, 2021 Dicor, Eternabond, any caulk/sealant will collect dirt which in turn mildews/molds. I ALWAYS add 2-3oz bleach to my 5G pail of soapy water to wash the entire RV. This mixture safely cleans the complete exterior, including awnings of dirt and mildew/mold while leaving a clean shiny surface without any negative effects. I've only been using that mixture since 1996 though so use it at your RV's own risk. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
chuckbear Posted April 14, 2021 Report Share Posted April 14, 2021 11 hours ago, Ray,IN said: Dicor, Eternabond, any caulk/sealant will collect dirt which in turn mildews/molds. I ALWAYS add 2-3oz bleach to my 5G pail of soapy water to wash the entire RV. This mixture safely cleans the complete exterior, including awnings of dirt and mildew/mold while leaving a clean shiny surface without any negative effects. I've only been using that mixture since 1996 though so use it at your RV's own risk. Bleach can strip off wax,polish and other protective coatings so be careful. left to dry on the sides, the streaks can be almost impossible to remove. Using bleach as a cleaning agent on paint or fiberglass will require a second set of hands continuously rinsing adjacent areas. Chuck Quote Chuck and Susan 1999 Fleetwood Bounder 34 Triton V10 on Ford Chassis Link to comment Share on other sites More sharing options...
rpsinc Posted April 14, 2021 Report Share Posted April 14, 2021 I have used polyurethane caulk on RVs with success. It isnt as thin and self-leveling like Dicor but works well and a little massaging with a putty knife and its good to go. Quote Marcel Link to comment Share on other sites More sharing options...
Ray,IN Posted April 15, 2021 Report Share Posted April 15, 2021 11 hours ago, chuckbear said: Bleach can strip off wax,polish and other protective coatings so be careful. left to dry on the sides, the streaks can be almost impossible to remove. Using bleach as a cleaning agent on paint or fiberglass will require a second set of hands continuously rinsing adjacent areas. Chuck Thanks for your concern, however I've been using this solution for about 37 years without any surface or fabric damage of any kind. I'm not forcing anyone to do as I, just offering a suggestion aa requested.Prior to posting did you calculate out the percentage of 3oz., 5.25% bleach in 5G of water? Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
gjhunter01 Posted April 17, 2021 Report Share Posted April 17, 2021 I just use plain water through our 1600 PSI power washer which does a good of cleaning our TPO roof and a replaced EDPM slideout roof. Contrary to popular concerns, the flexible roofing will just flex and not tear when being cleaned with a power washer. With plain water, there are no streaks on the siding. Quote Link to comment Share on other sites More sharing options...
