Jack L Posted April 4, 2021 Report Share Posted April 4, 2021 We have a problem with the oven staying lit. How can I tell if is the pilot light or the thermocouple ? Jack L Quote Link to comment Share on other sites More sharing options...
Kirk W Posted April 4, 2021 Report Share Posted April 4, 2021 Does the pilot stay burning? It has to send the heat for that to happen. It is also normal for it to be turned off by the oven control valve. They can be a bit difficult until you get used to them. This video may be helpful. How to Light an RV Oven Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Ray,IN Posted April 4, 2021 Report Share Posted April 4, 2021 (edited) Adding to Kirk's advice; If you can light the pilot and it stays burning while holding the knob in that is normal; however if it goes out when you release the knob after a minute or so the flame sensor is dirty or not sending the ~4 milliamp signal to the gas valve. If the pilot goes out while baking the pilot gas screw may require adjusting; one oven brand does not have this adjustment though. During cold weather a near empty LP cylinder can cause low pressure and in turn cause pilot lights to go out randomly. First do things that are free. Clean the flame sensor to remove baking residue or soot from the pilot flame. Next remove the other end of the flame sensor from the gas valve and clean both sides of the connection with a pencil eraser, when replacing this exercise care not to crush the contacts by over-tightening That's the free remedies.To check gas pressure, adjust the pilot flame height requires personal research for a DIY person or calling in a professional. Edited April 4, 2021 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
travelinbob Posted April 5, 2021 Report Share Posted April 5, 2021 Ha, I had that problem so I just replaced the oven. BUT not the end of story. When we bought the RV it did not have an oven, only a cooktop. Installing a oven was part of the purchase. The oven we got included was a POS. We hated that thing for years. One day the pilot would not stay lit so I go to replace the thermocouple. The manufacture of the oven decides that it would be best to secure the thermocouple tubing to the rear of the oven with a clamp and screw. So.....in order to take the thermocouple off I had to remove the oven. I decided that if the oven was coming out it sure was NOT going back in.....I researched and found what I wanted. Main feature was a pilot that I did not have to lay on the floor to light it. I finally found that the only replacement was made by Furion and they just started making the oven/cooktop slide in. Best thing I ever did. Quote 2006 Elite Suite 36TK32001 F-550 Starhaulerwww.mytripjournal.com/elitesuitestravelsIN GOD WE TRUST Link to comment Share on other sites More sharing options...
