Kstar Posted March 17, 2021 Report Share Posted March 17, 2021 Journey 2013 MH, Kwickee steps go in and out but...when motorhome off and we turn the switch off to pull in the steps (working outside and need the space) the steps pull in and out quickly and jitter. Opening or closing door doesn't stop the action. Turning the switch back on does stop it but step remains out. Suggestions? Thanks Quote Link to comment Share on other sites More sharing options...
catsaplenty Posted March 18, 2021 Report Share Posted March 18, 2021 In mine there is a "plunger" button that the door pushes in when closed. When it worked loose it caused problems. You might see if that is loose or if you can tell by pushing it in by hand, if it works right. Perhaps it isn't being fully engaged by the door closing. Sorry - all I know. Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted March 18, 2021 Report Share Posted March 18, 2021 (edited) These steps do not have a manual off/on switch, the motor starts/stops exactly like a power window, the controller senses a sharp rise in motor amperage draw and turns off power.The only "switch" is the magnetic contacts on the screen door and on the wall next to the screen door. Kwikee states to lubricate all piviot points monthly for proper operation, how long since you lubricated the steps moving joints? reference: Kwikee Service Training Manual for all models. Edited March 18, 2021 by Ray,IN Quote Link to comment Share on other sites More sharing options...
Kstar Posted March 18, 2021 Author Report Share Posted March 18, 2021 There is an over-ride switch that allows the step to be in the closed position when the engine is off and door closed. When the door is opened the step goes out (safety measure, I guess) That is the switch that is causing the erratic step operation. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted March 18, 2021 Report Share Posted March 18, 2021 30 minutes ago, Kstar said: There is an over-ride switch that allows the step to be in the closed position when the engine is off and door closed. If your step is like the Kwikee steps that I have had, that switch is next to the door and allows the step to remain extended when the door is closed and the engine not running. Am I understanding correctly that the step runs continuously with that switch in the extended position and extends then retracts and extends again over and over? Quote Link to comment Share on other sites More sharing options...
Kstar Posted March 19, 2021 Author Report Share Posted March 19, 2021 Yes, that is the switch. With engine off, switch in over-ride mode (should retract step when door closes) the step comes in, then clunk, clunk, clunk - not really in and out, just jitters. Did find out that a good swift kick temporarily solves the problem. Will crawl under tomorrow, clean, lube, wiggle wires etc. Thanks Quote Link to comment Share on other sites More sharing options...
Kirk W Posted March 19, 2021 Report Share Posted March 19, 2021 10 hours ago, Kstar said: Will crawl under tomorrow, clean, lube, wiggle wires etc. I'll be interested to hear more. I have worked on quite a few of the Kwikee steps but can't recall ever seeing what you describe. Since the Kwikee does turn off on a current rise, that probably plays a part but I don't understand the reversing..... Quote Link to comment Share on other sites More sharing options...
johnpeters Posted October 18, 2021 Report Share Posted October 18, 2021 When you have automatic RV steps but they do not retract, the switches for the door & the door frame are not aligned correctly. Moreover, the cause may be the override switch that makes the steps remain extended while the RV’s parked. To fix this, check and turn the control switch to the auto position. Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted October 18, 2021 Report Share Posted October 18, 2021 (edited) K-Star, any progress to report? johnpeters, re-aligning the magnetic switch and magnet did solve my staying out problem. Kwikee does not use a rotary switch to the best of my knowledge. Edited October 18, 2021 by Ray,IN Quote Link to comment Share on other sites More sharing options...
