Nwcid Posted March 17, 2021 Report Share Posted March 17, 2021 I have about 4000 miles on my new to me 2014 VNL 630 with 420k miles. Obviously the "best" answer is take it to the shop, but if it is something I can trouble shoot at home I would like to start there. Occasionally the "parking" brake will "release" allowing the truck to roll about an inch or two and then locking up again. I have had this happen enough times not to be a fluke, but not constantly either, maybe 6-8 times. Here is what I have found so far: Has never happened when the truck is parked and shut down. The only time it will happen (if it happens) is if the truck is parked, shut off and then started up shortly after, maybe under 15 min (never really timed it). Typically within 1-2 min of restarting the truck it will make the "air pressure" bleed off noise as the tanks hit pressure, the truck will roll a little (even on flat ground) and then lock up again. Quote 2014 Volvo 630. 2016 Fuzion 325T, RZR 900 Trail 675ah AGM, MSH 3012 inverter, 960w Solar. (2016 Chevy 3500 DRW, backup) Link to comment Share on other sites More sharing options...
noteven Posted March 17, 2021 Report Share Posted March 17, 2021 When you set the park valve (pull the yellow control) where does the air exhaust from the brake chamber? It should exhaust near the axles - not inside the cab. With the park brakes set and the engine shut down, can you hear air moving in the system? Kind of a mystery - if the brakes are adjusted correctly the only way the park brakes should release is when sufficient air is supplied to the spring chambers to release them. The only way brakes that are set would release, then set again is if air is bleeding into the chambers, then bleeding off again allowing the spring brakes (parking brakes) to set again. In any case this is dangerous. Suggest chocking the wheels whenever you park the truck until you get this figgered out. Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Nwcid Posted March 17, 2021 Author Report Share Posted March 17, 2021 When I set the brakes I can hear air move at the dash, but the exhaust is at the axles. With the engine shut down there is some air bleed from the fan clutch and something near the rear the axles that lasts for a few seconds. There is no problem with them releasing while the truck if off. Or if I restart it after sitting for several hours/overnight. The only time it happens, if it happens, is truck has been running, got shut off for a short period of time, and then started back up. Then if its going to happen it will be in the first minute or so. Quote 2014 Volvo 630. 2016 Fuzion 325T, RZR 900 Trail 675ah AGM, MSH 3012 inverter, 960w Solar. (2016 Chevy 3500 DRW, backup) Link to comment Share on other sites More sharing options...
Darryl&Rita Posted March 17, 2021 Report Share Posted March 17, 2021 The only connections to the brakes is the yellow knob. If the knob's out, there's no supply to the brakes. No supply, parking brake is applied. There's no ignition connection, no timer of any sort. Confirm proper brake adjustment, including Slack adjustment and S Cam movement. Chock the tires until you get this sorted out. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Jaydrvr Posted March 17, 2021 Report Share Posted March 17, 2021 If you have weak spring brakes, they're weak all the time. What you're describing definitely sounds like some kind of air system issue. Jay Quote Link to comment Share on other sites More sharing options...
Nwcid Posted March 18, 2021 Author Report Share Posted March 18, 2021 I called a shop this afternoon. They basically acted like they have never heard of such a thing happening. I have an appointment next week to have them look at it. Quote 2014 Volvo 630. 2016 Fuzion 325T, RZR 900 Trail 675ah AGM, MSH 3012 inverter, 960w Solar. (2016 Chevy 3500 DRW, backup) Link to comment Share on other sites More sharing options...
Parrformance Posted March 18, 2021 Report Share Posted March 18, 2021 Try to take good notes, this is one that sounds tough to duplicate for the tech. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Deezl Smoke Posted March 18, 2021 Report Share Posted March 18, 2021 This truck will have anti-lock brakes.? So there will be an electric connection between the brakes and likely the ecm, or an electrically charged anti-lock system. If it were my truck, I would attempt to locate the anti-lock system and inspect all wire connection and routings. I am not a truck mechanic, but I have to wonder since this appears to only do this upon a re-start, perhaps some sort of anti-lock feedback or wiring component holding a bit of electric charge might be the culprit.? Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
dennisvr Posted March 18, 2021 Report Share Posted March 18, 2021 59 minutes ago, Deezl Smoke said: This truck will have anti-lock brakes.? So there will be an electric connection between the brakes and likely the ecm, or an electrically charged anti-lock system. If it were my truck, I would attempt to locate the anti-lock system and inspect all wire connection and routings. I am not a truck mechanic, but I have to wonder since this appears to only do this upon a re-start, perhaps some sort of anti-lock feedback or wiring component holding a bit of electric charge might be the culprit.? That's a good thought, but I believe the anti lock only works on the service brake side. If the park brake is activated a spring sets the brakes. I have never ran across anything like what is described in all the yrs of working on them. Quote "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
Nwcid Posted March 18, 2021 Author Report Share Posted March 18, 2021 Yes this will be hard to duplicate. Yes I have ABS. In theory they can start by checking the braking system and making sure everything is adjusted correctly. This truck does have "self adjusting" brakes, but still. While the weather was still below freezing I had my drivers, front drive brake routinely be frozen after sitting and I would have to tap on it to release. Quote 2014 Volvo 630. 2016 Fuzion 325T, RZR 900 Trail 675ah AGM, MSH 3012 inverter, 960w Solar. (2016 Chevy 3500 DRW, backup) Link to comment Share on other sites More sharing options...
Deezl Smoke Posted March 18, 2021 Report Share Posted March 18, 2021 2 hours ago, dennisvr said: That's a good thought, but I believe the anti lock only works on the service brake side. If the park brake is activated a spring sets the brakes. I have never ran across anything like what is described in all the yrs of working on them. It does. However, the anti-lock "computer" has to know that the park brake is released, so there is a connection there of some type. Upon re-start, should the ecm or separate anti-lock device need to run some sort of self-diagnostic, I can't help but wonder if said device would momentarily glitch and begin release thinking that the wheel sensors are showing movement of some kind? Since this only seems to happen upon warm re-start, perhaps some component is holding a charge or some sensor is faulty and sending a false reading. The ecm knows the engine temp at all times. I dont know. I'm just grasping at straws wondering why this happens upon a warm restart and so far anyway, not on cold startup. I know recalls happen on most all new vehicles now days. Perhaps a recall history would also be in order? Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Parrformance Posted March 18, 2021 Report Share Posted March 18, 2021 3 hours ago, Nwcid said: While the weather was still below freezing I had my drivers, front drive brake routinely be frozen after sitting and I would have to tap on it to release. I had this issue with a brake that would not release. I changed out the chamber and cured the issue. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Nwcid Posted March 18, 2021 Author Report Share Posted March 18, 2021 (edited) 1 hour ago, Parrformance said: I had this issue with a brake that would not release. I changed out the chamber and cured the issue. Would not release all of the time or just in freezing weather? All it takes to release it is a simple tap with a hammer on the edge of the drum. I just did 3000 miles with no releasing trouble. Edited March 18, 2021 by Nwcid Quote 2014 Volvo 630. 2016 Fuzion 325T, RZR 900 Trail 675ah AGM, MSH 3012 inverter, 960w Solar. (2016 Chevy 3500 DRW, backup) Link to comment Share on other sites More sharing options...
Parrformance Posted March 18, 2021 Report Share Posted March 18, 2021 3 hours ago, Nwcid said: Would not release all of the time or just in freezing weather? All it takes to release it is a simple tap with a hammer on the edge of the drum. I just did 3000 miles with no releasing trouble. With mine it stuck when sitting for extended period of time. It was leaking internally. This made it take forever to release the park brake. I just did a piggy back replacement. Took about 45 minutes the first time. Now I can do it much faster. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted March 18, 2021 Report Share Posted March 18, 2021 Either your dash valve is leaking or the relay valve that feeds the airlines to the brake cans may have an issue. I have antilock on the rear axle of our old Volvo, but I've never had an issue with the truck rolling with the park brake set. I'd chock the wheels, and release the brakes and carefully crawl under the back and check the pad clearance. I had 1 automatic adjuster that didn't adjust all the time. Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Nigel Posted March 18, 2021 Report Share Posted March 18, 2021 If your suspension leaks down in that short time the truck will move an inch of two as the suspension airs back up. If that is what you are feeling you must have a pretty good air leak that needs to be addressed. Nigel Quote 2006 Volvo VNL 430, 2006 smart cabrio cdi, 2000 Triple E Topaz 30' Link to comment Share on other sites More sharing options...
Nwcid Posted March 19, 2021 Author Report Share Posted March 19, 2021 My brake sticking only happened in freezing weather and usually when it had been wet. My understanding is this is a semi common problem. I do not think I have any leaks. I have never timed it or check my pressure levels while sitting. Even after sitting for a few hours there is usually enough pressure in the system my "alarm" does not go off when starting the truck. How long should the truck hold pressure? I thought about the suspension also because I can get it to "roll" if dumping or inflating. My suspension stays inflated (or mostly) even after sitting for long periods. Quote 2014 Volvo 630. 2016 Fuzion 325T, RZR 900 Trail 675ah AGM, MSH 3012 inverter, 960w Solar. (2016 Chevy 3500 DRW, backup) Link to comment Share on other sites More sharing options...
Scrap Posted March 19, 2021 Report Share Posted March 19, 2021 If you've got stability control it'll apply the service side momentarily during the chuff test just after key on. Leaking diaphragm, bad QR-1C, messed up plumbing from converting it to straight truck, etc, could cause crossover and momentary park release. Probably need to unhook some emergency side hoses to isolate and see just which ones are blowing air at that time. Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted April 14, 2021 Report Share Posted April 14, 2021 Check the back-flow prevention/directional air valve on each air storage tank for leaking. Sounds like the secondary tank is back-flowing slowly into the main tank when moisture in the valve freezes. I'm assuming you have replaced the air dryer filter recently and drained both air tanks???? Even so you can still get moisture in the tanks and valves. The only way to remove residual moisture is to introduce air-drying alcohol into the system; HDT's used to have a reservoir specifically made for this. If there is no moisture in the system perhaps the directional air valves need replacing. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Nwcid Posted April 14, 2021 Author Report Share Posted April 14, 2021 I did schedule an appointment but I had to cancel it. In the past month I have been driving it on a lot of local trips. This includes lots of parking and turning on and off. I have not had this happen to me again. Quote 2014 Volvo 630. 2016 Fuzion 325T, RZR 900 Trail 675ah AGM, MSH 3012 inverter, 960w Solar. (2016 Chevy 3500 DRW, backup) Link to comment Share on other sites More sharing options...
