GlennWest Posted February 28, 2021 Report Share Posted February 28, 2021 (edited) My bms is two sided taped to battery pack. The bms is ribbed surface for heat dispatch. I have batteries positioned so that bms is in vertical position. They come loose. Do you think a dose of super glue to back of bms would hold it. Tape is stuck good to battery. Or remove and velcro. Edited February 28, 2021 by GlennWest Quote Link to comment Share on other sites More sharing options...
Twotoes Posted February 28, 2021 Report Share Posted February 28, 2021 Ok, I give up. What is bms? Quote Link to comment Share on other sites More sharing options...
GlennWest Posted February 28, 2021 Author Report Share Posted February 28, 2021 Just now, Twotoes said: Ok, I give up. What is bms? Battery management software device Quote Link to comment Share on other sites More sharing options...
GlennWest Posted February 28, 2021 Author Report Share Posted February 28, 2021 (edited) https://i.imgur.com/UxUX Edited February 28, 2021 by GlennWest Quote Link to comment Share on other sites More sharing options...
jcussen Posted February 28, 2021 Report Share Posted February 28, 2021 When I changed out one BMS on a battery pack, just used double sided VHB tape. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted February 28, 2021 Author Report Share Posted February 28, 2021 (edited) 11 minutes ago, jcussen said: When I changed out one BMS on a battery pack, just used double sided VHB tape. I know your bms are different from mine. Is yours smooth surface where tape goes? Edited February 28, 2021 by GlennWest Quote Link to comment Share on other sites More sharing options...
jcussen Posted February 28, 2021 Report Share Posted February 28, 2021 51 minutes ago, GlennWest said: I know your bms are different from mine. Is yours smooth surface where tape goes? Mine are stacked horizontally, not vertically, so tapped to flat side of cells. If your leads reach, would mount on top or sides of the battery pack. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted February 28, 2021 Author Report Share Posted February 28, 2021 (edited) 2 hours ago, jcussen said: Mine are stacked horizontally, not vertically, so tapped to flat side of cells. If your leads reach, would mount on top or sides of the battery pack. That would shorten my negative line also. I have added a sheet of plywood on top since that pic took but be easy to remove and do this. Thanks. Don't know why I hadn't thought to relocate it Edited February 28, 2021 by GlennWest Quote Link to comment Share on other sites More sharing options...
