Parrformance Posted February 22 Report Share Posted February 22 I am not looking disparagingly at the wipers, being homeless and all. I just want to do my part to help them find a loving home. I need to turn the wipers on, wait till they get close to the home position, and quick turn them off. If left to their own devices they will stop wherever they damn well are when you switch them off. Might any of you successfully navigated a repair for this in a Volvo, with the Volvo D12 engine? Quote Link to post Share on other sites
Darryl&Rita Posted February 22 Report Share Posted February 22 Park circuit wiring? Trying to reload the memory banks, had same thing on an old Ford. Quote Link to post Share on other sites
Jaydrvr Posted February 22 Report Share Posted February 22 On my '99 Volvo, the wiper transmission drive doesn't lock onto the wiper motor, so that it can break away under load. The drive arm has spines, but the tapered motor shaft doesn't. If it slips, you can just loosen the nut, re-center the arm and re-tighten the nut. I actually replaced the motor unnecessarily to find this out. Not sure about other generations. Jay Quote Link to post Share on other sites
Parrformance Posted February 22 Author Report Share Posted February 22 Found a tip on intermittent wiper delay. Quote Link to post Share on other sites
Parrformance Posted February 22 Author Report Share Posted February 22 Wipers are working fine, except they do not return to the down position upon canceling the wipers. Quote Link to post Share on other sites
Parrformance Posted February 22 Author Report Share Posted February 22 http://www.hhrvresource.com/VolvoDocs/30-37/PV776-TSP143133.pdf I probably should start here. Quote Link to post Share on other sites
Shawn Patterson Posted February 22 Report Share Posted February 22 My experience on cars having this same problem is that it typically is a result of a failure in the park circuit of the wiper motor itself. Looks like they run about $160. Quote Link to post Share on other sites
Parrformance Posted February 22 Author Report Share Posted February 22 Sounds good, I will investigate further this weekend. Quote Link to post Share on other sites
Jaydrvr Posted February 22 Report Share Posted February 22 51 minutes ago, Shawn Patterson said: My experience on cars having this same problem is that it typically is a result of a failure in the park circuit of the wiper motor itself. Looks like they run about $160. That's what I thought too, until I took it out to replace it. Both my Volvos had the break away system. Jay Quote Link to post Share on other sites
Moresmoke Posted February 23 Report Share Posted February 23 2 hours ago, Jaydrvr said: That's what I thought too, until I took it out to replace it. Both my Volvos had the break away system. Jay With what you describe as the breakaway system, the wipers would still park reliably, just not at “home”. When you can’t get the wipers to stop at all, or just a very short window, it is electrical, typically in the motor as that is where the park switching usually is. Either way, beats my old Freightliner from years past. Air wipers with intermittent function. Some days they worked and some days they didn’t. Quote Link to post Share on other sites
Jaydrvr Posted February 23 Report Share Posted February 23 24 minutes ago, Moresmoke said: With what you describe as the breakaway system, the wipers would still park reliably, just not at “home”. When you can’t get the wipers to stop at all, or just a very short window, it is electrical, typically in the motor as that is where the park switching usually is. Either way, beats my old Freightliner from years past. Air wipers with intermittent function. Some days they worked and some days they didn’t. Yes, that's true. I've experienced the random parking wherever it wanted to, so I suspected the motor. One time, it wasn't the motor. Sometimes you're right, sometimes you're wrong. Jay Quote Link to post Share on other sites
Darryl&Rita Posted Tuesday at 05:12 AM Report Share Posted Tuesday at 05:12 AM 7 hours ago, Shawn Patterson said: My experience on cars having this same problem is that it typically is a result of a failure in the park circuit of the wiper motor itself. Looks like they run about $160. This sounds right, from a long time ago. Quote Link to post Share on other sites
Parrformance Posted Tuesday at 11:07 AM Author Report Share Posted Tuesday at 11:07 AM Wherever the wiper blades are when I turn them off is where they stop. Quote Link to post Share on other sites
Jaydrvr Posted Tuesday at 12:40 PM Report Share Posted Tuesday at 12:40 PM 1 hour ago, Parrformance said: Wherever the wiper blades are when I turn them off is where they stop. If they never stop on their own, it has to be the motor. I misunderstood what you meant. Jay Quote Link to post Share on other sites
Parrformance Posted Tuesday at 12:55 PM Author Report Share Posted Tuesday at 12:55 PM Sweet, thank you. I have dealt with this since I bought the truck, I will get around to replacing the motor after proper permissions are granted. Quote Link to post Share on other sites
noteven Posted Tuesday at 12:57 PM Report Share Posted Tuesday at 12:57 PM It's a long shot but it could be related to the turbo encabulator. Quote Link to post Share on other sites
Parrformance Posted Tuesday at 12:58 PM Author Report Share Posted Tuesday at 12:58 PM Changed that first🤣 Quote Link to post Share on other sites
Parrformance Posted Tuesday at 12:59 PM Author Report Share Posted Tuesday at 12:59 PM Well after I added blinker fluid.... Quote Link to post Share on other sites
Parrformance Posted Tuesday at 01:35 PM Author Report Share Posted Tuesday at 01:35 PM https://www.ebay.com/itm/New-Windshield-Wiper-Motor-for-All-Volvo-Semis-VN-series-WPM8025-/114047684820 Looks like one can be had out of Miami for $54. Quote Link to post Share on other sites
