aknavy Posted February 18, 2021 Report Share Posted February 18, 2021 I just had new tires put on my new to me truck - singled 2001 Volvo 660. I also had Centramatics put on steer and drive axle. Driving home, there was a slight "wobbly" vibration around 45-50mph. Tire shop balanced the steer tires, but not the drive. Should I have the drive axle tires balanced? Quote Link to comment Share on other sites More sharing options...
spindrift Posted February 18, 2021 Report Share Posted February 18, 2021 Not a believer in those Centramatics, unlike some folks. Did your shop spin the tires while they were on the truck? There's more rotating mass on the steer axle than just the wheel/tire combination which is why a balancing on the truck is essential...IMHO. Quote Link to comment Share on other sites More sharing options...
lappir Posted February 18, 2021 Report Share Posted February 18, 2021 New tires take a while to "break in". Actually several heat and cooling cycles to make them whole. Depending on your style of "Drive" tire, they sometimes take longer if you have a tire with lugs for more traction. If you have put steer tires on the rear, you may not notice. If the tire shop "tossed" a couple bags of balancing beads, it does take a bit for the bags to break open and start actually doing their thing. I also didn't like the Centramatics and took them off. Rod Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted February 18, 2021 Report Share Posted February 18, 2021 (edited) 19 minutes ago, aknavy said: I just had new tires put on my new to me truck - singled 2001 Volvo 660. I also had Centramatics put on steer and drive axle. Driving home, there was a slight "wobbly" vibration around 45-50mph. Tire shop balanced the steer tires, but not the drive. Should I have the drive axle tires balanced? Usually not necessary. Are your wheels hub centric or lug centric? If lug centric sometimes the lugs will not be centered in the hub and can cause mild to severe vibration. I found out the hard way after getting king pin bushings replaced and truck nearly shook apart at 45mph. Shop checked all their work and denied responsibility. They said tires. Drove to tire shop. They pulled both steers to rebalance and check trueness. I happened to look at hub on drivers side saw lug was to edge of hole, recentered it and shimmy completely disappeared. I now have stud centering lug nuts on both steers that center the hub. Just happened to have read a post on this site over 10 years ago that mentioned looking for that as a possible source of a shimmy. Edited February 18, 2021 by SuiteSuccess Quote Link to comment Share on other sites More sharing options...
aknavy Posted February 18, 2021 Author Report Share Posted February 18, 2021 1 hour ago, SuiteSuccess said: Usually not necessary. Are your wheels hub centric or lug centric? If lug centric sometimes the lugs will not be centered in the hub and can cause mild to severe vibration. I found out the hard way after getting king pin bushings replaced and truck nearly shook apart at 45mph. Shop checked all their work and denied responsibility. They said tires. Drove to tire shop. They pulled both steers to rebalance and check trueness. I happened to look at hub on drivers side saw lug was to edge of hole, recentered it and shimmy completely disappeared. I now have stud centering lug nuts on both steers that center the hub. Just happened to have read a post on this site over 10 years ago that mentioned looking for that as a possible source of a shimmy. I'll have to look and see. Not sure off hand. Quote Link to comment Share on other sites More sharing options...
hone eagle Posted February 18, 2021 Report Share Posted February 18, 2021 my centramatics 'wobble' every spring after a long idle period ,takes 20-30 kms before things smooth out. Like a out of round tire ,maybe give em some time. Quote Link to comment Share on other sites More sharing options...
dlcarsonak Posted February 18, 2021 Report Share Posted February 18, 2021 (edited) I second what Suitesuccess said, about the centering lug nuts. They worked for me. I now do not worry about balancing the steer tires. I only put two nuts on each wheel, 180 deg. from each other. I am looking at getting Centramatic, these are the first negative commits' I have heard about them. Safe travel and stay warm in Texas. Edited February 18, 2021 by dlcarsonak Quote Link to comment Share on other sites More sharing options...
aknavy Posted February 18, 2021 Author Report Share Posted February 18, 2021 1 hour ago, hone eagle said: my centramatics 'wobble' every spring after a long idle period ,takes 20-30 kms before things smooth out. Like a out of round tire ,maybe give em some time. I'll give it a longer evaluation period before making any changes. That, and check the lugnuts. Quote Link to comment Share on other sites More sharing options...
Parrformance Posted February 18, 2021 Report Share Posted February 18, 2021 4 hours ago, dlcarsonak said: I second what Suitesuccess said, about the centering lug nuts. They worked for me. I now do not worry about balancing the steer tires. I only put two nuts on each wheel, 180 deg. from each other. I am looking at getting Centramatic, these are the first negative commits' I have heard about them. Safe travel and stay warm in Texas. I have Centramatics, but when you first drive the truck, it seems as though the flat spots in the tires need to round out then the balancing settles in. Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted February 18, 2021 Report Share Posted February 18, 2021 I have centramatics also. Quote Link to comment Share on other sites More sharing options...
Nwcid Posted February 18, 2021 Report Share Posted February 18, 2021 I do not want to hijack this thread but I have a question inline with it. I am still getting my truck serviced and ready for an upcoming trip. The dealer replaced my font shocks, they appeared original and had 400k on them. The truck rode very soft and felt "loose" Now with the new shocks and about 250 miles total on them I feel like I have more front end vibration that changes with speed so I am assuming it is balance issue. The steer tires are in good shape. I am going to have them balanced and rotated next week. The tire shop recommend beads vs weights. Should I do weights or beads? Cost is about the same. Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted February 18, 2021 Report Share Posted February 18, 2021 (edited) 22 minutes ago, Nwcid said: I do not want to hijack this thread but I have a question inline with it. I am still getting my truck serviced and ready for an upcoming trip. The dealer replaced my font shocks, they appeared original and had 400k on them. The truck rode very soft and felt "loose" Now with the new shocks and about 250 miles total on them I feel like I have more front end vibration that changes with speed so I am assuming it is balance issue. The steer tires are in good shape. I am going to have them balanced and rotated next week. The tire shop recommend beads vs weights. Should I do weights or beads? Cost is about the same. Do you intend to run tire pressure monitors? If you do then I would get weights which is what I did (I also have centramatics). TST (Truck System Technology) which are the monitors I use said definitely do not use liquid or powder and also advised beads will eventually fracture and break off tiny pieces that could affect the monitors. I think that is probably after many more miles than we usually drive but was what I was told. Some people swear by beads. Edited February 18, 2021 by SuiteSuccess Quote Link to comment Share on other sites More sharing options...
Nwcid Posted February 18, 2021 Report Share Posted February 18, 2021 31 minutes ago, SuiteSuccess said: Do you intend to run tire pressure monitors? If you do then I would get weights which is what I did (I also have centramatics). TST (Truck System Technology) which are the monitors I use said definitely do not use liquid or powder and also advised beads will eventually fracture and break off tiny pieces that could affect the monitors. I think that is probably after many more miles than we usually drive but was what I was told. Some people swear by beads. I know the reasons for monitors, but it is not something in budget right now or high on my list. Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted February 18, 2021 Report Share Posted February 18, 2021 (edited) 58 minutes ago, Nwcid said: I know the reasons for monitors, but it is not something in budget right now or high on my list. Understand. Can tell you it saved me blowing a tire and many thousands of $$ when I lost a disk brake caliper on my trailer. Temp shot up, alarm sounded. I pulled off immediately, hub temp was 180*. If I had kept driving would have blown the tire and pretty sure had a fire. Again, please don’t take this wrong, but would try to at least budget for trailer asap. For reference, 20% of trailer fires arise from tires or wheels. Truck probably not an immediate need. Again just a suggestion. Edited February 18, 2021 by SuiteSuccess Quote Link to comment Share on other sites More sharing options...
Moresmoke Posted February 19, 2021 Report Share Posted February 19, 2021 One thing not mentioned here on tires. Truck tires have a tapered bead. Sometimes, when you install the tire, it does not push out evenly around the rim. If your tire has a raised ridge just outside the rim you can see the difference. After some time on the road, they will settle into the right spot. Higher pressure in the tire will help them seat properly, especially if you run lower pressures for reduced load most of the time. My little truck has 19.5 tires on it, also taper beads. The rims are cold galvanized coated. It is not a smooth surface. On those I have to air them to max pressure (120 psi) for a couple weeks to get the tires to seat on the beads right. Quote Link to comment Share on other sites More sharing options...
palmeris Posted February 19, 2021 Report Share Posted February 19, 2021 On 2/18/2021 at 8:37 AM, dlcarsonak said: .... I am looking at getting Centramatic, these are the first negative commits' I have heard about them.... I also am looking at getting a set for the f450...can you all expound on any issues with them? Quote Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted February 20, 2021 Report Share Posted February 20, 2021 Have the tires spin balanced on the truck. That will help balance out an drum issue as well. Quote Link to comment Share on other sites More sharing options...
Parrformance Posted February 20, 2021 Report Share Posted February 20, 2021 If your heart can take it, there are shops that will true(shave) a tire as well. Hard to watch the expensive tire rubber flying of the tread. Quote Link to comment Share on other sites More sharing options...
lappir Posted February 20, 2021 Report Share Posted February 20, 2021 8 hours ago, Parrformance said: If your heart can take it, there are shops that will true(shave) a tire as well. Hard to watch the expensive tire rubber flying of the tread. Unless you are driving 8 hours a day, most of us will never wear a set of tires out and would never miss the rubber that's shaved off to make it round. I'm not saying it will do any good to shave them, but the loss of rubber is the least of the worries. Rod Quote Link to comment Share on other sites More sharing options...
noteven Posted February 21, 2021 Report Share Posted February 21, 2021 My Michelin XZA steer shoes are no balance weight required. They cost quite a bit of beer and pizza though. Quote Link to comment Share on other sites More sharing options...
