SWharton Posted February 14 Report Share Posted February 14 Just in case something has improved in RV ranges has anyone discovered the "best" range. I do not want induction. Propane, 3 burner basic. This is probably a fruitless quest, but I am an optimist. Thanks Quote Link to post Share on other sites
Kirk W Posted February 15 Report Share Posted February 15 Ours is 12 years old so I don't know about recent innovations, but I have a question for you. Did your present stove top die? I don't recall ever hearing of one failing. Quote Link to post Share on other sites
SWharton Posted February 15 Author Report Share Posted February 15 It has never worked right from the beginning. It would light for a few weeks, then stop and I had to go to a lighter, then out of the clear blue it would start again. We replaced the wires, had i it looked at under warranty etc. I am tired of dealing with it, lemon from the beginning. Quote Link to post Share on other sites
Darryl&Rita Posted February 15 Report Share Posted February 15 Samsung convection oven over the range. Only way, baby. Bigger, better temp control, makes microwave popcorn, too. Quote Link to post Share on other sites
Chalkie Posted February 15 Report Share Posted February 15 8 hours ago, Darryl&Rita said: Samsung convection oven over the range. Only way, baby. Bigger, better temp control, makes microwave popcorn, too. But can you fry an egg in it? Convection ovens are great but they are not a replacement for a stove top. I don't know the specific dimensions but a lot of newer RVs are coming with a 4-burner cooktop that actually has a usable oven. If you don't want the oven take a look at gas cooktops. They can be had in smaller sizes and most gas places are able to convert natural gas to propane. Quote Link to post Share on other sites
SWharton Posted February 15 Author Report Share Posted February 15 I want propane. 3 burner is fine.No oven. Quote Link to post Share on other sites
Darryl&Rita Posted February 15 Report Share Posted February 15 2 hours ago, Chalkie said: But can you fry an egg in it? Convection ovens are great but they are not a replacement for a stove top. Can you dry an egg in your oven? Haven't seen that recipe, but I suppose anything's possible. We're talking about ovens here, not stoves. We have a gas cooktop, too. Quote Link to post Share on other sites
jbh Posted February 15 Report Share Posted February 15 I read something years ago about the peizo sparker being replaced by a battery-powered one from a Weber grill. Might be something to explore. Quote Link to post Share on other sites
podwerkz Posted February 15 Report Share Posted February 15 (edited) A range has an oven down below and burners on top. A cooktop is just the burners on top. Which do you need? If you are only having trouble with the igniter, may I suggest keeping a grill lighter or oven matches nearby. I bought and installed the Furrion 3 burner cooktop and the igniter on it works well, and I like the controls (10%-100%) and the gas safety cutoff if a flame blows out. Just FYI, having a safety thermocouple on each burner means that you do have to hold the knob pushed down for several seconds after the burner ignites. It's a mid-priced unit, not the best but certainly better than the $30 units installed by some of the factories. It has actual cast iron grates inserted into rubber grommets, not the cheap and noisy bent steel grates on the cheap cooktops. It is 3 burners but...you can't fit 3 large pots or pans or skillets at the same time. You can fit two large pans or skillets, or a flat griddle plate across all 3 burners. My only 'nit' is that the knobs get spattered along with the rest of the cooktop when cooking, but you can easily remove the knobs for cleaning them and the surrounding surface. https://www.etrailer.com/RV-Stoves-and-Ovens/Furrion/FGH4ZSASS.html Edited February 15 by podwerkz Quote Link to post Share on other sites
Chalkie Posted February 16 Report Share Posted February 16 On 2/15/2021 at 7:37 AM, Darryl&Rita said: Can you dry an egg in your oven? Drying an egg could be interesting. Would that leave you with a powdered egg? But I did say fry. Quote Link to post Share on other sites
Darryl&Rita Posted February 17 Report Share Posted February 17 8 hours ago, Chalkie said: Drying an egg could be interesting. Would that leave you with a powdered egg? But I did say fry. Bad proof reading, combined with Autocorrect. Quote Link to post Share on other sites
sandsys Posted February 17 Report Share Posted February 17 On 2/15/2021 at 5:29 AM, Chalkie said: But can you fry an egg in it? Convection ovens are great but they are not a replacement for a stove top. You have me thinking about putting some oil in a cereal bowl, breaking an egg into it, breaking the yolk so it won't explode, putting it in the microwave, and seeing what happens. After all, I regularly cook a lightly beaten egg with a can of salmon stirred into it that way. It seems to me that method would work in a convection oven. Linda Quote Link to post Share on other sites
Chalkie Posted February 17 Report Share Posted February 17 5 hours ago, sandsys said: You have me thinking about putting some oil in a cereal bowl, breaking an egg into it, breaking the yolk so it won't explode, putting it in the microwave, and seeing what happens. After all, I regularly cook a lightly beaten egg with a can of salmon stirred into it that way. It seems to me that method would work in a convection oven. Linda I have a gizmo for a microwave that you are supposed to put in a scrambled egg and cook it to make the egg for an egg muffin. I have found that unless you time it perfectly it comes out rubbery and can vary from egg to egg. It is much more satisfactory to me to pour that scrambled egg into one of the silicon rings in the fry pan. But your experiment sounds interesting. Let us know if it works, which I think it will, but the real trick would getting an easy over egg out of a microwave. Quote Link to post Share on other sites
