Wrknrvr Posted February 19, 2021 Author Report Share Posted February 19, 2021 Do you have 12 volt power. is your furnace operating if your furnace is operating it is possible to somehow open a heating vent pipe underneath the camper. That way heat would be able to flow under the rv and heat everything up at a steady pace. I have see just metal ductwork like in a house used. That may need to be cut open for heat to escape. It can be put back together easily. If you have a flexible vent line you could just cut it with a knife and pliers. It can be put back together . This is absolutely in desperate times. So if you block some heat from venting into the camper it will force more underneath the camper. Tanks frozen solid may take awhile to completely thaw out. But if you gat some flow of water out then letting water run may help. I would be careful about black tank flowing open. Just in case some solids could block the valve. Just giving a idea to help. Vern Quote Link to comment Share on other sites More sharing options...
justRich Posted February 20, 2021 Report Share Posted February 20, 2021 In a pinch, the outside shower can be used to put hot water into the fresh water tank. Short term, emergency use only. Quote ~Rich Link to comment Share on other sites More sharing options...
Al F Posted February 20, 2021 Report Share Posted February 20, 2021 10 hours ago, Rich&Sylvia said: In a pinch, the outside shower can be used to put hot water into the fresh water tank. Short term, emergency use only. Is that IF the shower hose reaches the gravity fill, or do you attach a hose to the shower and run it to the gravity fill? Quote Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
Kirk W Posted February 20, 2021 Report Share Posted February 20, 2021 10 hours ago, Rich&Sylvia said: In a pinch, the outside shower can be used to put hot water into the fresh water tank. Why would you want to do that? As I understand the problem, his waste tanks are frozen and he needs to empty them? Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
packnrat Posted February 22, 2021 Report Share Posted February 22, 2021 (edited) last night it got down to the high 30F now at 1:15 pm it is 70F. got to love ca for the moderate temps. everything else...well that's another wording. bty: wrknrvr, love the way to heat the underside of your rv. Edited February 22, 2021 by packnrat Quote Link to comment Share on other sites More sharing options...
sandsys Posted February 23, 2021 Report Share Posted February 23, 2021 We had a typical January thaw today--above freezing with a chance of rain. Yeah, I know it's not January but time is so screwed up who else would know? Linda Quote Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
