Deezl Smoke Posted February 1, 2021 Report Share Posted February 1, 2021 I have doubts that it has been done, but just in case, has anyone cut the riser out of the cab where the seats mount, tubbed it, and relocated the cab mounts so high base (standard) seats can be put in? I see several have cut the back out to allow crawl/walk through to a sleeper. But so far, nothing about removing that vocational equipment rise and putting in a new flat floor. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted February 1, 2021 Report Share Posted February 1, 2021 Will a low rise seat base work? I know that there's M2's with air ride seats. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Deezl Smoke Posted February 1, 2021 Author Report Share Posted February 1, 2021 Yes. My FL70s have factory air driver side seats, I believe called "low base" seats. They're actually an ok seat. But nothing like what is in my Peterbilt. Since I will need to put an air ride passenger side seat in, and they're near the same price, I wondered if anyone had done the cab mod to accommodate the standard seat base. Kind of a lot of work on an old truck for the purpose, but we each have our own priorities as for what we want out of a rig. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted February 1, 2021 Report Share Posted February 1, 2021 Gotcha. Just remember, the seat and base are two different parts. The seat has more bearing on the comfort level, but the low rider bases do only have "so much" travel. All bases also have pivot points that use lube. Our seats smartened up immensely when I sprayed all the pivots with Brak-Kleen and lubed them. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Deezl Smoke Posted February 2, 2021 Author Report Share Posted February 2, 2021 4 hours ago, Darryl&Rita said: Gotcha. Just remember, the seat and base are two different parts. The seat has more bearing on the comfort level, but the low rider bases do only have "so much" travel. All bases also have pivot points that use lube. Our seats smartened up immensely when I sprayed all the pivots with Brak-Kleen and lubed them. Good points. Notes taken. I think we can get by with the low base travel and fewer knobs to play with, we just need to do as you mention, and make the shorter travel as posh as possible. Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted February 2, 2021 Report Share Posted February 2, 2021 (edited) One thing I don't like about the low bases. I'm a long legged drink of water, and unless I can kick my legs out in front of me, a'la sedan, I look like a kangaroo sitting there. KW and Pete cabs let me stretch a bit, but I'd still like more. Nephew has a W900 with the seat on the floor. I hate it. He's about 5'4", so it works for him. Edited February 2, 2021 by Darryl&Rita Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Deezl Smoke Posted February 2, 2021 Author Report Share Posted February 2, 2021 I'm only 5'11", but I too need my legs out front of me. My Peterbilt 379 is fine for my body, but the old FLD120 condo I had was even better, like your T2000. We do stop a lot on our travels. But I prefer to stop when we want to, not need to because our legs are cramping or backs are having spasms. I have a plasma table and press brake etc., so I can do the work myself, but I like to see if what I plan has been done before or not. What lubricant did you use after you cleaned the pivots on your seats? White grease or something like slick50? Quote I'm a work'n on it. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted February 2, 2021 Report Share Posted February 2, 2021 Probably either white Moly grease, or Fluid Film spray. They're my go to's for spots like this. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
