PAylor Posted January 22, 2021 Report Share Posted January 22, 2021 The good news is that we have a new fifth wheel on order. The bad news is after four years the a/c in the living room is acting up. The compressor comes on for a few minutes then cuts off. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Kirk W Posted January 22, 2021 Report Share Posted January 22, 2021 Could it be freezing up? When ice builds up most RV a/c units do turn off the compressor. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Pat & Pete Posted January 22, 2021 Report Share Posted January 22, 2021 Maybe the capacitor(s) on the control board , or possibly the board relay . Both weak links . Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
GlennWest Posted January 22, 2021 Report Share Posted January 22, 2021 When I had them. Changed mine to mini splits. My compressor motor fan was freezing up. It would go back to working once it cooled off. Replaced it and good for a year and same again. We are full time so they run constantly. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
bigjim Posted January 22, 2021 Report Share Posted January 22, 2021 If they have them still it could be as simple as a weak Klixon. Or plugged coils. Right that a faulty fan could cause it too. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted January 23, 2021 Report Share Posted January 23, 2021 Start simple. Clean the inside and outside coils. No cost, but time. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
papaamericano Posted February 17, 2021 Report Share Posted February 17, 2021 On 1/22/2021 at 8:35 PM, PAylor said: The good news is that we have a new fifth wheel on order. The bad news is after four years the a/c in the living room is acting up. The compressor comes on for a few minutes then cuts off. Any suggestions? If you notice that an air conditioner turned off suspiciously quickly - immediately after turning it on, after 5 - 10 minutes, do not rush to panic: perhaps you set such settings and it quickly coped with your task. But there are also many reasons for the rapid shutdown of the air conditioner associated with the breakdown of one of its components or improper operation. In this case, only a qualified professional technician with the necessary diagnostic equipment can find the root cause of a breakdown and fix it. Some of the reasons are: REACHED THE SET TEMPERATURE If you set too high temperature, an air conditioner will easily cope with the task and will turn off.DRYING MODE IS SET In dry mode, an air conditioner usually does not work for a long time. If you have it turned on, do not worry when a device turns off after 10-15 minutes.COMPRESSOR OVERHEATING If a compressor overheats, it will be turned off. But there can be many reasons for overheating: A condenser of an outdoor unit is clogged with debris and dust. Narrow capillary tubes are clogged, usually due to poor installation. A dryer filter may be clogged. A cooling fan of an outdoor unit is defective or heavily clogged.AIR TEMPERATURE SENSOR BROKE DOWN An air conditioner control board makes decisions about turning on/off a compressor, including based on information from an air temperature sensor.INTERIOR UNIT FAN BROKEN An inoperative fan will drastically reduce cooling, and a control module may well shut down an air conditioner after a while. This information also might be useful :) Quote Link to comment Share on other sites More sharing options...
TXiceman Posted May 27, 2021 Report Share Posted May 27, 2021 Replacing the compressor is costly. Might as well replace the unit. As noted, start simple by cleaning the coils and filters. Also check for air bypassing from inlet to out let and retape any air leaks. Next find our why the unit is shutting off. This will take looking at the wiring diagram and a bit of trouble shooting. Ken Quote Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
D&J Posted May 27, 2021 Report Share Posted May 27, 2021 If it only runs for a few minutes and your sure it's just the compressor kicking off but the fan is still running then the control circuit is working. That short of time is not long enough to freeze up or kickoff on temperature so it's probably going off on the current overload switch mounted on the top of the compressor. If it starts then the start relay and cap are good so that leaves a bad run cap or the compressor is dragging causing high current draw, you will need a amp probe to figure that out. Denny Quote Denny & Jami SKP#90175 Most Timing with Mac our Scottie, RIP Jasper our Westie 2013 F350 SC DRW 6.2 V8 4.30 Gears 2003 HH Premier 35FKTG Home Base Nebraska Link to comment Share on other sites More sharing options...
