trimster Posted March 17, 2021 Author Report Share Posted March 17, 2021 Between rain and snow storms built the arm that will hold the winch. It folds up small enough to fit into the smaller under-bed bin. Once I decide on the winch model and get it in hand, the mounting plate will be welded to the top and the whole unit will be sent off for powder coating. The weather broke and the bed liner rolled-on the side rails. Like this brand. It can be sprayed or rolled on. Took less than a qrt to do 2 coats on the rails all around. Today the deck plate gets a coat of acid etch primer...if the winds don't come up. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted March 20, 2021 Author Report Share Posted March 20, 2021 Deck plate has two coats of Durabak-18 in dark gray. First time trying this brand. Used Herculiner on the last truck and liked it. Durabak is very similar to that brand but does not cover as well. 2 coats and still has thin spots. Fortunately I got 2 gallons, and have 3/4 gal left, which is enough for a third coat. This Durabak dries really slowly. Raptor (2 part system) flashes at 60 min, dry to the touch. Raptor does not have any grit in it (although you can add some), producing a nice textured finish. I would imagine it might be slick if wet or snow covered. Durabak has texture and grit... so good non-skid properties. Also decided to put a 50' air-hose reel in one of the rear storage boxes. Now need to run an air line from the air tanks up front. Anyone see issues with running rubber or synthetic air hose from the air tanks back? ...and so it goes. Just a bit closer to done Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
rickeieio Posted March 20, 2021 Report Share Posted March 20, 2021 14 minutes ago, trimster said: Anyone see issues with running rubber or synthetic air hose from the air tanks back? Shoot'n from the hip.....if plastic and rubber are good enough for brakes, they oughta be fine. Consider adding a small tank back there too, if you have room. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
trimster Posted March 20, 2021 Author Report Share Posted March 20, 2021 (edited) 4 minutes ago, rickeieio said: Shoot'n from the hip.....if plastic and rubber are good enough for brakes, they oughta be fine. Consider adding a small tank back there too, if you have room. Additional tank... good idea. I should be able to find a used one at the semi junk yard north of here. I've got room. Anyone who has tapped into the VNL air tanks remember the adapters you used to get from the hole in the tank to a hose-friendly fitting? Edited March 20, 2021 by trimster Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
rickeieio Posted March 20, 2021 Report Share Posted March 20, 2021 I'm gleaning this thread for ideas to use on our next bed. Like'n it so far. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
rpsinc Posted March 20, 2021 Report Share Posted March 20, 2021 24 minutes ago, trimster said: Deck plate has two coats of Durabak-18 in dark gray Did you roll it? Looks like it from the pan & roller. I have used Xtreme Liner many times but have never rolled it. I spray it on with a HF drywall texture gun. Works good. They supply "crumb" for the texture in the product. Sometimes I use it sometimes I dont. Depends on what I am doing with it. Also, they offer many colors. Its 2 part, so it holds up pretty well. Quote Marcel Link to comment Share on other sites More sharing options...
trimster Posted March 20, 2021 Author Report Share Posted March 20, 2021 1 minute ago, rickeieio said: I'm gleaning this thread for ideas to use on our next bed. Like'n it so far. Any other/more information I can provide, please ask. I have not covered lots of little things here. Some are specific to this build but maybe helpful. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted March 20, 2021 Author Report Share Posted March 20, 2021 (edited) 3 minutes ago, rpsinc said: Did you roll it? Looks like it from the pan & roller. I have used Xtreme Liner many times but have never rolled it. I spray it on with a HF drywall texture gun. Works good. They supply "crumb" for the texture in the product. Sometimes I use it sometimes I dont. Depends on what I am doing with it. Also, they offer many colors. Its 2 part, so it holds up pretty well. Rolled both. Don't have the compressor ability to drive the air gun to shoot it. Rolled-on okay. The roller they include isn't the best. It worked better with the Raptor brand. Edited March 20, 2021 by trimster Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted March 20, 2021 Report Share Posted March 20, 2021 15 minutes ago, trimster said: Anyone who has tapped into the VNL air tanks remember the adapters you used to get from the hole in the tank to a hose-friendly fitting? There should be a couple spare 1/2" NPT ports with plugs installed. Make sure to tie into the right tank. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
trimster Posted March 20, 2021 Author Report Share Posted March 20, 2021 Just now, Darryl&Rita said: There should be a couple spare 1/2" NPT ports with plugs installed. Make sure to tie into the right tank. "Make sure to tie into the right tank"... but my tanks are on the left side. Sorry, could not resist. I'm assuming the three under the drivers side are for overall system air? or is there specific duties for one or more of them? There's another tank closer to the drives. I'm assuming that is for the parking brake? Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Steve from SoCal Posted March 20, 2021 Report Share Posted March 20, 2021 The type of hose you use is your choice, on ANY air line to an accessory put a ball valve at the tank to shut off the supply when not in use. If the valve is in a awkward location make an extension handle to an easy access point. I thought about a hose reel for my truck, decided the space it took up was too valuable and just coil up a hose. Steve Quote 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
Sculptor Posted March 20, 2021 Report Share Posted March 20, 2021 6 hours ago, trimster said: Any other/more information I can provide, please ask. I have not covered lots of little things here. Some are specific to this build but maybe helpful. How much do you charge? 😂 Just kidding, but wow what a nice job you have done! Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Darryl&Rita Posted March 20, 2021 Report Share Posted March 20, 2021 5 hours ago, trimster said: "Make sure to tie into the right tank"... but my tanks are on the left side. Sorry, could not resist. I'm assuming the three under the drivers side are for overall system air? or is there specific duties for one or more of them? There's another tank closer to the drives. I'm assuming that is for the parking brake? Off the compressor is the "Wet tank", then the primary and secondary tanks. This picture refers to them as secondary and service. Follow the lines to see what each tank supplies, then decide. I'd come off the wet tank, myself. Some trucks only have 2 apparent tanks, with the second tank seperated internally. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
noteven Posted March 21, 2021 Report Share Posted March 21, 2021 On a AD-IS system if there is a kinda like "pancake" tank on the air dryer that is the "wet" tank. Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Jack Mayer Posted March 21, 2021 Report Share Posted March 21, 2021 You will want to tap the wet tank. As someone said, put a valve at the tank in case you have issues. I'd use 1/2" DOT airline, but that is just me. Hose will work but it won't be as good and likely will cost more, unless you have some sitting around. You will like the Raptor - that is what we use on our beds after trying most of the other brands. You are finding out what we face daily - Massive price increases in steel and other components. We try to keep our prices under control, but it is difficult with things going up so fast. Quote Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
trimster Posted March 22, 2021 Author Report Share Posted March 22, 2021 10 hours ago, Jack Mayer said: You will want to tap the wet tank. As someone said, put a valve at the tank in case you have issues. I'd use 1/2" DOT airline, but that is just me. Hose will work but it won't be as good and likely will cost more, unless you have some sitting around. You will like the Raptor - that is what we use on our beds after trying most of the other brands. You are finding out what we face daily - Massive price increases in steel and other components. We try to keep our prices under control, but it is difficult with things going up so fast. Thanks Jack. I've been able to keep material costs down a bit by finding rems. Of course self-building kept the budget under control. But still, it's an ouch. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
essarebee Posted March 25, 2021 Report Share Posted March 25, 2021 I've followed your build thread since the beginning. I just joined the forum to say that pictures are time-consuming to post, but are very much appreciated! You might be shocked by the number of folks who follow your build. Quote Link to comment Share on other sites More sharing options...
trimster Posted March 26, 2021 Author Report Share Posted March 26, 2021 Someone asked what the basic sub-frame for the bed looked like. Here's a photo I forgot to post. The 6" C-channel bolts to the truck frame in several places. Where the original commercial hitch mounted, and some custom brackets that use exiting frame bolt holes to tie into. This shot was taken when I had planned on making the end of the bed 'beaver tailed'. I added segments of channel to the end creating a flat bed all the way back. Although this photo was taken in Jan, it seems like ages ago. Time flies when you are having fun. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted April 1, 2021 Author Report Share Posted April 1, 2021 Deck is now ready for the tread-plate install. Tomorrow the teenage grand kids are drilling and tapping 80+ screw holes. This should be entertaining. Today we put on 1/16" x 1.5" rubber gasket material. Some Super-77 holds it in place nicely. Older grandson is walking the steel like a pro. Kids have a good sense of balance. I'd need someone to call 911 of I tried. The two larger deck plates will have several surface mount d-rings to strap stuff down. Trying to figure out the best placement. I have 10 mounts to distribute over the deck. 4 will be assigned to the wheel-baskets for the Smart Car. Can't really place those until we get the car and put it on the deck. The generator arrived and that went to the fabricator. He's building the box and rollout drawer around the generator. Friday the underbed boxes get a final fit. We ran into fit issues yesterday at the first fitting. I did not make the first 2 cross ribs exactly square to each other.... off by under 1/4" end to end (101"). Way off by my standards. So the fabricator is making some changes to adapt the box to the space. My bad. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
rickeieio Posted April 1, 2021 Report Share Posted April 1, 2021 Bob, I'm so glad I'm watching your build. We just happen to have a couple of small generators on the farm, one being a Yamaha 3000i w/ electric start. Perfect...... Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
trimster Posted April 1, 2021 Author Report Share Posted April 1, 2021 I would have preferred a diesel genset but cost & size ruled that out. There will be an aux fuel cell [5-7 gal) above the generator box. That should give it 24 hrs of runtime. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
trimster Posted April 3, 2021 Author Report Share Posted April 3, 2021 Made good progress and it looks like a real flatbed. Fancy that. And with the help of the 2 grandsons.... the deckplate install went fairly fast. Better yet, no broken drill bits or taps. That in itself is amazing. Pulled out the tape and it's 64' long. Monday the fabricator does a final test fit on the boxes. I've been concerned that the pinbox and the deck frame clearance when doing off camber transitions. Did some fairly radical ones today and no deck-to-pinbox collisions. I'm going to mount a little action camera back there and record what's going on. Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
dblr Posted April 3, 2021 Report Share Posted April 3, 2021 Looking great and I bet it's nice having your grandson's help, plus think of all the on the job training they are receiving. Quote 2017 River Stone Legacy 38MB 2001 T2000 Kenworth 2009 Smart Passion ET Junior hitch Link to comment Share on other sites More sharing options...
noteven Posted April 3, 2021 Report Share Posted April 3, 2021 I saw a company somewhere on the internet that sells a key fob remote shutdown for portable generators. I think that could be convenient. Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Hot Rod Posted April 6, 2021 Report Share Posted April 6, 2021 Kinda curious on the choice of aluminum deckplate... why not steel? Weight is not an issue tandem, and you could have simply welded it down and saved a lot of work, and you are covering in bedliner anyway. Quote Link to comment Share on other sites More sharing options...
