GlennWest Posted September 19, 2020 Report Share Posted September 19, 2020 (edited) Too much time on my hands. Victron plainly states on say a quattro 48/8000 has 6600 watts and 8000VA. Basically 80% difference. Magnum 44448 PAE states 4400VA and no mention of continuous watts. So is the Magnum only 3000 watts? Edited September 19, 2020 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
oldjohnt Posted September 19, 2020 Report Share Posted September 19, 2020 Hey Glenn, I thought we went through all this a while back ??? Watts = Power Factor X Volt Amps or PF= W/VA. If the Power Factor is unity one (that's a goal) then VA = Watts. Volt Amps versus Watts IS NOT the same as only the "continuous watts" you spoke of above. I cant say what Magnum's Watts or Volt Amp ratings are ????? I don't have any of their data. If you find out let us know John T Quote Link to comment Share on other sites More sharing options...
GlennWest Posted September 19, 2020 Author Report Share Posted September 19, 2020 We did but I can't find the info for Magnum. Simply states 4400 KA. Have searched and searched for that info. Hoping someone on here knows. The .7 factor I understand is the difference. That really adds up in higher wattage inverters Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
jcussen Posted September 19, 2020 Report Share Posted September 19, 2020 (edited) The label on my 4448 says max output amperage is 19. So at 220 volts, 4180 watts. . Not sure how to calculate it with both 120 and 220 volt loads. Edited September 19, 2020 by jcussen Quote Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
GlennWest Posted September 19, 2020 Author Report Share Posted September 19, 2020 53 minutes ago, jcussen said: The label on my 4448 says max output amperage is 19. So at 220 volts, 4180 watts. . Not sure how to calculate it with both 120 and 220 volt loads. Have you ever checked the display to see the wattage? Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
jcussen Posted September 19, 2020 Report Share Posted September 19, 2020 21 minutes ago, GlennWest said: Have you ever checked the display to see the wattage? I only have the Arc50 and the BMK and the only readout I get is battery voltage and amps out. So I can figure it out. The most I have ever pulled out of battery is about 2700 watts and that is with a combined 220 and 120 load. Quote Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
GlennWest Posted September 19, 2020 Author Report Share Posted September 19, 2020 Wife was cooking with convection at 400 degrees. One leg was seeing 19-21 amps. I mini split on. It 240v so one leg was on that but it is basically idling. Not very warm here. So most of that was convection microwave. I just wanting to make sure 2 of those inverters will run everything. Cooking our biggest draw Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
