Zulu Posted October 19, 2020 Report Share Posted October 19, 2020 On 9/6/2020 at 10:39 AM, George the greek said: out with the old and in with the new so now its on to replacing the shower head couldnt fint anything in the owners manual about pressure so I set it at 55 I started with expensive (Watts) and went to the cheap, simple one as both get the job done. I found that the Watts restricted water flow more than the cheap, simple one. Quote SKP #79313 / Full-Timing / 2001 National RV Sea View / 2008 Jeep Wrangler Rubiconwww.rvSeniorMoments.comDISH TV for RVs Link to comment Share on other sites More sharing options...
remoandiris Posted October 19, 2020 Report Share Posted October 19, 2020 15 hours ago, Ray,IN said: If the gauge freezes the regulator workings are also frozen with water, which expands and cracks the brass housing. Once I replaced the gauge, it worked fine and no leaks. Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted October 19, 2020 Report Share Posted October 19, 2020 7 hours ago, remoandiris said: Once I replaced the gauge, it worked fine and no leaks. I had one get a hairline split at the screw-in male hose thread. Next one has the oil-filled gauge, however it will not prevent a re-ocurrance of the brass splitting. Oddly the split did not leak until there was high incoming water pressure. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
