trimster Posted August 18, 2020 Report Share Posted August 18, 2020 210 WB. Thinking about singling long. Need to find someone to do it in Salt Lake. Any leads appreciated. Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
rickeieio Posted August 18, 2020 Report Share Posted August 18, 2020 Do you have valid reasons for singling, or do you just "want to"? Make a list of pro's and con's. Many of us are still tandem, because that's what works for us. Fuel mileage will be affected very little. Storage space can be increased a bunch. Ride will likely be a little rougher single. The list goes on............. If singled, tires will wear faster, and age is important, as is loading. Less so on both counts if tandem. Brakes last just a few weeks longer than forever if tandem. If tandem, you have lots of spares on board. Many here are pushing the limit on axle loading, both front and rear, especially if singled long. Do a "weights and balance" calculation to see whether singling is right for you. Lots of discussion about it, led by DollyTrolly, an old fly-boy. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
GlennWest Posted August 19, 2020 Report Share Posted August 19, 2020 Why long. Can overload front axle Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
trimster Posted August 19, 2020 Author Report Share Posted August 19, 2020 Maybe because it's such a short wheelbase to start with. Might not be good thinking on my part. Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
jenandjon Posted August 19, 2020 Report Share Posted August 19, 2020 I'm singled long. I wouldn't recommend. I bought it that way. Problem is I'm awfully heavy on the steers. I'm not overloaded but I'm right there. If I built it over again I would have move the axle forward to make it single short. Save your money for other things and leave it tandem. Yea its more tires to buy but its also more brakes. I mean its your truck you can do whatever you want so go for it if you want but I wouldn't mess with it. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
ARGO Posted August 19, 2020 Report Share Posted August 19, 2020 I singled short. Short or long is your choice, but if'n I was to do it again- I'd trade the whole tandem to a yard for a factory single. Brakes etc are bigger, & same time you get the gear ratio of your choice. I went from 3.73 to 3.08, a little too far. Hindsight says 3.23, but I can run 55-65 in 9th. Quote You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
trimster Posted August 19, 2020 Author Report Share Posted August 19, 2020 Thanks all. Discussions with the CFO has lead me to keep it as is. We do need 8 new rears. That will be an ouch, but probably won't need to drain the account like that for years to come. Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Wrknrvr Posted August 19, 2020 Report Share Posted August 19, 2020 You could single the dual tires.. just run the outside tires. Vern in a T-shirt Quote Link to comment Share on other sites More sharing options...
trimster Posted August 19, 2020 Author Report Share Posted August 19, 2020 That's an interesting idea. Hmmmmm..... Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
geodog Posted August 19, 2020 Report Share Posted August 19, 2020 I replaced my drive tires two at a time. Started on outside duals. ShortyO Quote Link to comment Share on other sites More sharing options...
Phil D Posted August 19, 2020 Report Share Posted August 19, 2020 One wheel and tire per wheel position has been discussed here many times. You may want to search the forum for some of those discussions in order to make an informed decision. To summarize, engineers (most notably, the engineers that work for the companies that make the hubs on which you'd be mounting those wheels and tires) hate the idea, unless it's done "right" -- and nobody that does it does it "right" because that involves purchasing new zero offset wheels for all four drive tire positions. The weight ratings of the hubs is drastically reduced when operated with a standard offset truck wheel. Quote Phil 2002 Teton Royal Aspen 2003 Kenworth T2000 - Cat C12 380/430 1450/1650, FreedomLine, 3.36 - TOTO . . . he's not in Kansas anymore. ET Air Hitch Link to comment Share on other sites More sharing options...
rpsinc Posted August 19, 2020 Report Share Posted August 19, 2020 I have also seen leaving rear as dually and the forward axle singled. At least that reduces 2 tire/wheel combos. Quote Marcel Link to comment Share on other sites More sharing options...
GlennWest Posted August 19, 2020 Report Share Posted August 19, 2020 You so get more storage area singled. I singled mid. Actually you retain orginal wheel base this way. It is a personal decision. Nothing wrong with leaving as is. They stop good singled. Don't know if extra brakes make a difference. It is more tires, more air bags, more protential air leaks. Do you have a locker? That would ber only reason I know to keep dual Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
rickeieio Posted August 19, 2020 Report Share Posted August 19, 2020 Bob, you've opened a can-o-worms..... :-) If you remain tandem, you can (logically) run your drive tires a lot longer. Since the weight per tire will be so low, the tire pressure charts don't even go that low, it would seem we can run them much longer than that mythical 7 year mark. Mine are currently 12 y/o, and I may be pushing my luck. My struggling thought process is that my tires stay crazy cool, being so lightly loaded, and we all know heat is the enemy of tires. My drives typically run 20-30 degrees F cooler than the steers. As suggested above, swapping you tandems for a single at a junkyard makes sense. What most folks don't factor into the mix is that one axle of a tandem IS NOT rated for the input loads it will receive, while a factory single is. As to Vern"s suggestion of just running the outside wheels, it makes sense. As to the counter argument of the hubs not being rated as such, it also makes sense, EXCEPT, the loads are so light it'll likely never approach the limits imposed by the hub not being evenly loaded. Now how do we lasso a worm? Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
hone eagle Posted August 19, 2020 Report Share Posted August 19, 2020 What Rick said ,don't have to post when he reads my mind.🤐 Quote 2005 volvo 670 freedomline singledNewmar Torrey Pine 34rskswoot woot Link to comment Share on other sites More sharing options...
podwerkz Posted August 19, 2020 Report Share Posted August 19, 2020 Four super singles would be my choice but they can take 20-50 thousand miles to break in....better be ready for that. Quote Nothing to see here. Link to comment Share on other sites More sharing options...
ARGO Posted August 19, 2020 Report Share Posted August 19, 2020 If you decide to single by moving the rear axle fwd, or leaving it long, just be aware the input yoke on the rear axle is NOT the same size as the front. If having a driveshaft made keep that in mind. And it is a Metric tube on Volvos Quote You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
SuiteSuccess Posted August 20, 2020 Report Share Posted August 20, 2020 If leaving tandem look at second tier drive tires such as Sailun, Hercules, Coopers, BFG instead of Michelin, Goodyears, or Bridgestone. Second tier will save $$ and serve just as well. If you want later three consider for steers. BTW if you are not going off road consider all position. Lots of discussion on tires if you search this forum. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
trimster Posted August 20, 2020 Author Report Share Posted August 20, 2020 interestingly, I just got back from the tire place and was having the same kinda discussion with a salesman who 'got' what I am doing. I got gigged on the State inspection for having a G rating on one steer and H on the other. Really needs to be H for the axle rating. (note to self, don't go to the Volvo dlr for safety inspections. The tech gigged me for not fire extinguisher while he wrote his notes setting in the drivers seat with the new fire extinguisher right next to his right foot. Doh.), We talked about tread patterns, overall use of the truck (bad weather, off road, only fair weather...). We then chatted about super singles. He has the used rims ($75 ea) and some very serviceable used tires. He'll give me some $$$ for the 8 aluminum rims I currently have. I was not clear if the used tires were caps or virgin. We didn't get that far. I know there's strong feelings about super singles. All of which make sense. Not sure I would ever wear one out but road damage can affect any tire. Just not enough of them when doing super singles. I would do Supers for two reasons... the conversion price makes sense and the mere fact that I really like the look of them. Big, fat, meats. Reminiscent of my drag racing days. One reason is logical, the other...not so much. Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
GlennWest Posted August 20, 2020 Report Share Posted August 20, 2020 Road tire service truck likely won't have a tire. Something to consider Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
rickeieio Posted August 20, 2020 Report Share Posted August 20, 2020 Given the huge number of trucks on the road w/ super singles, I wouldn't make it a huge concern, but it does bear some thought. Not that long ago, if you saw a truck w/ SS tires, he was likely carrying a spare. Hardly ever see that now. And yes, I like the looks of them. At least one member here has had them on for over a year, perhaps he'll let us know what he thinks of them. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
podwerkz Posted August 20, 2020 Report Share Posted August 20, 2020 (edited) I put about a million miles on super singles (wide base singles) ...both with, and without, nitrogen. I recommend nitrogen fill and bump them at every stop just like duals. Other than that they are damn near maintenance free, quiet, smooth, and long lasting. But they do take awhile to break in, and handle right, as I mentioned earlier. If you do somehow manage to destroy one when on the road and have to call for service, you just tell the guy what you need and they will bring it. Super Singles have a substantial tread thickness and rarely get a 'normal' flat, and if they do, you will know it, unlike one tire in a set of duals going flat and the driver is sometimes unaware until it explodes. They can be a little 'floaty' on snow and ice. Usually slightly better MPG but not enough to pay for themselves if switching over. And, normally the axles are a tad longer (wider) to accommodate super singles, so an axle swap might be necessary. Pros and cons to either configuration. Edited August 20, 2020 by podwerkz Quote Nothing to see here. Link to comment Share on other sites More sharing options...
bigredhdt Posted August 20, 2020 Report Share Posted August 20, 2020 Are you talking about the free 78% nitrogen or $$ 100% nitrogen that you have to buy at special locations? Quote Link to comment Share on other sites More sharing options...
podwerkz Posted August 20, 2020 Report Share Posted August 20, 2020 Trust me, I knew the skeptics would chime in. They always do. Quote Nothing to see here. Link to comment Share on other sites More sharing options...
Moresmoke Posted August 20, 2020 Report Share Posted August 20, 2020 My truck came with singles. I switched over to duals this spring. The tires I had were due to be changed because of weather cracking. I am not currently a fan of Michelin’s in any flavor. Anyway, my reasoning for running duals is pretty simple. 1: I travel the most on weekends, often late into the evening. In locations where the tire service guy will get to you first thing Monday morning. I want to get home. If you travel mostly popular routes with services, may not be an issue for you. 2: There are more budget friendly tires available in sizes for duals. I can buy a pair of mid tier tires for $600. There isn’t much choice out there between the top names and the never heard of China imports in wide base. I noticed a significant drop in fuel mileage going to singles. I did go to a much more aggressive tread than I had previously. Quote Link to comment Share on other sites More sharing options...
