crstrm Posted August 16, 2020 Report Share Posted August 16, 2020 Hi, I own a 2016 Serenity (Class B motorhome) manufactured by Leisure Travel Vans. The coach is built on a Mercedes-Benz Sprinter 2WD 3500 chassis with rear duallys and I have an issue with stability. From what I have read, this is a common problem with this MH. The MH sways in high winds or passing trucks. On windy days I have to hang onto the wheel tightly. I do not plan on off road traveling. To address this issue, I was thinking about purchasing these components and having a mechanic install them. 1. Hellwig Sway Bar 2. Sumo Springs – SSF-106-47 Front and SSR-338-54 Rear. Are the rear springs necessary? 3. Rear Fox Shocks 2.5 -OR- 1. Hellwig Sway Bar 2. Front Sumo Springs SSF-106-47 3. Rear Timbren SES Suspension Enhancement System MBRSP35A SES 4. Rear Fox Shocks 2.5 Would it be better to install each component one at a time? If so, what should be the purchased order? Agile Off Road in California (https://agileoffroad.com/rip-kit-mercedes-sprinter/#1564700152114-17e32dbe-fec6) has a package called Sprinter 3500 2WD RIP Kit – Starting at $3200 (plus installation). That’s more then I want to spend. Any recommendations/suggestions would be appreciated. Quote 2016 Leisure Travel Van Serenity S24CB Link to comment Share on other sites More sharing options...
Kirk W Posted August 16, 2020 Report Share Posted August 16, 2020 With the caveat that my experience was with a class A, I'll offer an opinion, since the principals are the same even though the chassis are different. In both cases it is a matter of a wind catching body at the high end of the GVWR that is causing the issues. I would go with: 1. Hellwig Sway Bar 2. Rear Fox Shocks 2.5 I would try things between to see if the next is needed. You may find that the sway bar is all that you really need. I would also consider one of the trac-bar systems from some of the other manufacturers if you have not done so. Since we went back to a towable RV several years ago I am not current on that type of equipment. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
crstrm Posted August 20, 2020 Author Report Share Posted August 20, 2020 Kirk, Thanks for your thoughts. Art Quote 2016 Leisure Travel Van Serenity S24CB Link to comment Share on other sites More sharing options...
