aztex Posted May 10, 2020 Report Share Posted May 10, 2020 (edited) Hi,Research convinced me this is a good device so dropped $150 on a basic unit.Unfortunately the website and instructions leave much to be desired. After much research it seems like it gets installed like this (after disconnecting power and propane etc): Please see images for clarification. One is the "block" I reference as-is and the other I drew wires. Drawn wires from APRV. Drawn red is the disconnected 12v supply from battery.1. Remove 12v battery supply from connecting block.2. Connect 12v battery supply to red wire on APRV3. Connect yellow wire from APRV to where 12v battery was connected on block.4. Connect ground from APRV to ground on the connecting block, leaving the trailer ground connected too.5. Connect twisted wires from APRV to sensor.6. Install sensor as described.It's as simple as routing power through the APRV which is a smart switch.Does this sound like the proper way to do this?I have a Dometic fridge.Thanks Edited May 10, 2020 by aztex links Quote Link to comment Share on other sites More sharing options...
aztex Posted May 10, 2020 Author Report Share Posted May 10, 2020 Why don't photos show up? Quote Link to comment Share on other sites More sharing options...
aztex Posted May 10, 2020 Author Report Share Posted May 10, 2020 OK I'm not going to edit and start another post so the photo stays put. This was recommended as the proper way elsewhere with the addition of a resettable breaker between the ARP and the 12v supply line. The breaker seems unnecessary since the control panel has a fuse .... Thought? Thanks! Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted May 10, 2020 Report Share Posted May 10, 2020 Your links in your first post open the Airstream forum, not pictures or ARP/Fridge defend instructions. I don't remember installing a breaker in the hot wire. The ARP instructions show wiring their unit in series with the "recall box", IMO this is to avoid lawsuits with Norcold, since the recall box is now a redundant system. I consider the money I spent on the Fridge Defend/ARP unit well spent. Have you watched the installation video yet? Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
57becky Posted May 10, 2020 Report Share Posted May 10, 2020 (edited) In addition to the video, go to this link https://www.arprv.com/dometic-ez-install.php and select the model fridge you have for detailed installation. When I installed our ARP device, a fuse was recommended, which I used, and for the slight cost, I can't understand why one wouldn't install the protection. There is the boiler temperature sensor that is wired, plus another thing connected to the tubing which is a ring connector that is just clamped to the tubing. I also have the ARP device that controls additional fans because our fridge is in a slide and needs additional air flow. If you really get stuck, there is a contact page you can submit a question, and Paul will either respond that way or call you direct. https://www.arprv.com/contact-us.php Edited May 10, 2020 by 57becky Quote Link to comment Share on other sites More sharing options...
Customer1 Posted May 11, 2020 Report Share Posted May 11, 2020 I'm not qualified to advise you but I have installed the ARP on two different Dometic refrigerators. At first glance I found it confusing. I took my Chromebook to the trailer, went to the instructions for my refrigerator and followed them step by step. By taking things one step at a time it all fell into place. FWIW, both installs I removed the refrigerator, and placed it on a table so I could comfortably sit on a stool. Although it can be done outside through the vent opening I found it worth the extra effort to remove. The additional benefit is I added additional baffles and insulation behind the refrigerator. Quote 2018 Keystone Cougar 2016 Chevrolet Silverado 3500 DRW D/A Link to comment Share on other sites More sharing options...
