GlennWest
slide out for toolbox
Had no good way for tool storage. So yesterday went to Harbor freight and picked up a box. Nice box, fits in my truck box good. Top lifts up to release lock on trays. So for now I have trays out a little and not locked. I  close door to box so this not a big deal. I thought I could pick up a slideout to install under it. This would allow me to use top section and lock trays. When I googgle "slideout" I get mostly rv room slideouts. I could build one I reckon.
Share this post
Link to post
I am working on this very issue.  I bought a used Snap On road box with a top lid and front cover.  I have a Stalick bed with a generator cabinet which is where I put the box, BUT, I have gas shocks on the doors of the cabinet and they interfere with the tool box cover which in turn wont let me open the tool box.
So I have been looking for some slides designed for emergency or service vehicles and will do a 150% extension.  My weight is projected at 800#, which with tools wont take long.
I have run into many slides that will do 150% extension BUT not with that weight capacity.  I have an existing slide in the cabinet for the generator, so I will bu using Extra HD slides and making my own 2nd slide to get that box out far enough.  I need about 6" more than the existing 20" extension.  The generator slides are sufficient but wont do the extra 50% I need.
See Accuride slides or Google emergency vehicle drawers.  Can also consider slides for RV pull outs and make your own tray.  Wood or better yet, sheet metal.
Share this post
Link to post
150% is really out there. I can do 100% and open box lid. all i need. Thanks for tip on seach. Found "SlideMaster". They are more money than I want to put in them. Do believe I can build that for a fraction of their price.
Edited by GlennWest
Share this post
Link to post
Of course you can.  You fabricate and tig weld.  Padda bing!  Done.  Check out Accuride slides.  I have used a creative idea for my battery box that would likely work too.  I bought some track and rollers(nylon ones) for garage doors.  Made a box for the batteries, used a bolt as a retainer to keep it from rolling around when stored, and then installed it.  Works good and cheap.  Could also use a channel as the track and some bearings for the rollers attached to a sheet metal tray.  Weld a tab for the stop(dont want that thing taking off when you pull it out.
Something like this is what I am considering(,https://www.accuride.com/products/drawer-slides/9308e-heavy-duty-full-extension-slide) but they have lots of options.
Share this post
Link to post
Yes I would do an internet search focused on heavy duty drawer slides. Some of those are rated quite high for lbs.  Things get really expensive when you start to look at specialized premade equipment focused just on slideouts. I wish I had your skills Glenn.
By the way. I got my 12,000 btu miniswplit installed yesterday. I am in love.
Share this post
Link to post
I know you are. Most just don't know.
Share this post
Link to post
11 hours ago, GlennWest said:
I don't have that much head room in my truck boxes
That's what I was thinking while reading replies. These trays are between 3"-5" high, depending on weight capacity.
Share this post
Link to post
Glen,
Have you perused RKI for their drawer systems for service bodies?
They have many height & depth options upm to 36" slides.
Geodog
Share this post
Link to post
I guess most of us are facing this issue actually. I was actually looking for a proper toolbox recently. I do not want a really giant one nor a tiny one. What would be the point of getting a small toolbox which would not fit any proper instruments in it. I couldn't really find a ''normal'' sized one yet. Have you got any ideas for one? I even tried to make a box by myself. At last, the box wasn't really... durable. However i thought i did everything right, used the right sander and all. However, the box turned a bit bigger than i expected. It actually occupied a very significant space. And that is what happens every single time i try to do something with my own hands.
Edited by Vasaelch
Share this post
Link to post
There are slides at 500# available.. A steel frame of 1.5" , 1/8 " angle iron, a plywood floor of 3/4" plywood and you have a fine pullout for toolboxes. Slides are cheap but worth the price. Mine have worked for 12 years. With a  200+# toolbox, a 2' long box for electrical tools and spare relays etc, a smaller box for plumbing tools and fittings, and finally a box loaded with drill bits for the load on the slides.
Bill
Share this post
Link to post
DFW RV Roof
RVAir The cleanest air in RVing!
AGS Now Hiring
RV Pet Safety
