runaway parents Posted February 17, 2020 Report Share Posted February 17, 2020 Several years ago we went on a wilderness survival camp out it was to teach boy scouts how to survive in the wilderness with minimal equipment. The kids set up several fire rings that night were several rocks exploded sending rock fragments every where. We had holes burnt in tents and sleeping bags. Some body asked me if they used river rocks and told me that could of been the cause. No there was no rivers in the area fore miles. Lots of shail and basalt. I am not a rock expert but what would cause this? Moisture in the rocks? I am sure there is a rock expert out there that can explain to me what kind of rock makes for a safe fire ring that will not explode Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted February 17, 2020 Report Share Posted February 17, 2020 17 minutes ago, runaway parents said: Several years ago we went on a wilderness survival camp out it was to teach boy scouts how to survive in the wilderness with minimal equipment. The kids set up several fire rings that night were several rocks exploded sending rock fragments every where. We had holes burnt in tents and sleeping bags. Some body asked me if they used river rocks and told me that could of been the cause. No there was no rivers in the area fore miles. Lots of shail and basalt. I am not a rock expert but what would cause this? Moisture in the rocks? I am sure there is a rock expert out there that can explain to me what kind of rock makes for a safe fire ring that will not explode Good description here. Had it happen with sandstone at Boy Scout campout. https://www.hunker.com/12397976/rocks-that-explode-around-fire-pits Quote Link to comment Share on other sites More sharing options...
runaway parents Posted February 17, 2020 Author Report Share Posted February 17, 2020 1 hour ago, SuiteSuccess said: Good description here. Had it happen with sandstone at Boy Scout campout. https://www.hunker.com/12397976/rocks-that-explode-around-fire-pits This makes a lot of sense . It was definitely cold . there was snow on the ground in places. talk about duck and cover. when these rocks went off ,they sent pieces flying threw the air 2 inches in diameter. Had one land on my sleeping bag burned a 3 inch hole in it . Quote Link to comment Share on other sites More sharing options...
castlewood57 Posted February 20, 2020 Report Share Posted February 20, 2020 Most any kind of rock will do so, epecially if it is cold and then 'super heated' with a fire in the center. Even granite will explode, all it takes is a bit of water in any crevice and you have a bomb. I would recommend some good solid pieces of steel instead. if you absolutely need to use rock, make sure to dirt piled up on the inside area of the ring to protect the rocks, you want it about a foot thick, that should help reduce explosions. I'd place sod on the outside to be safe as well. Quote Link to comment Share on other sites More sharing options...
