DesertMiner Posted February 11, 2020 Report Share Posted February 11, 2020 Just search on Amazon for a “J1939 splitter”. Lots of options to choose from Quote Link to comment Share on other sites More sharing options...
Ronbo Posted February 11, 2020 Author Report Share Posted February 11, 2020 A,Avon is your friend. Just make sure the color of the splitter is the same as your diagnostic port. Quote Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
DesertMiner Posted February 11, 2020 Report Share Posted February 11, 2020 Something to be aware... the power consumption of the module if it doesn’t go into sleep mode. You could see some low truck batteries. Quote Link to comment Share on other sites More sharing options...
Scrap Posted February 11, 2020 Report Share Posted February 11, 2020 I'm not sure you are supposed to hook ELD's and brakes to the Volvo HD-OBD port? It is missing data and doesn't lock, so I think Volvo wants you to go into the fuse panel and grab power from the fuses and data from the terminating resistor connection. Use a harness like this, then Y off of that. https://www.amazon.com/Volvo-Harness-9-Pin-Deutsch-J1939/dp/B07T2FD6DS/ref=sr_1_11?keywords=MasterELD&qid=1581408130&sr=8-11 Yes, for other trucks be real careful to use the right color harness for the right color plug, and that your splitter is actually a splitter and not a crossover cable. On the GREEN plug your vehicle 1939 is on pins F-G and not C-D like it had been for 20 years with black. C-D is 500K engine diagnostic. If you somehow end up with a 500K device on your 250K vehicle can it'll error out the can and if you have an automatic it'll get the dinging F error and shift itself to neutral until you unplug the thing, no matter where you happen to be. It friggen sucks. This is a 2016-2019 non-Volvo motor thing (I think that is how you get your HD-OBD plug?) and can get mighty confusing amongst all the truck brands. EPA forced the 500K for their use and everyone read the rule differently... 2019+ has a new "RP1226" connector that is standardized so it is the same for everybody. They don't want you using the diagnostic connector for anything but diagnosing anymore. There's 9-pin adapters out there that will hook to it. Quote Link to comment Share on other sites More sharing options...
Jack Mayer Posted February 11, 2020 Report Share Posted February 11, 2020 Scrap, that is the plug in the new trucks that you show above. The Direclink plugs into it and seems to work fine. Should it not be using it? Quote Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Scrap Posted February 11, 2020 Report Share Posted February 11, 2020 Yes it is. For sure that is the plug to use. It is the HD-OBD that I don't think you are supposed to use for safety/regulation stuff. Quote Link to comment Share on other sites More sharing options...
Ronbo Posted February 11, 2020 Author Report Share Posted February 11, 2020 there are two versions of the software. Trucks and Motorhomes. I use motorhomes since I don’t need the functions of the trucker version. Quote Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
dan412 Posted February 15, 2020 Report Share Posted February 15, 2020 On 2/10/2020 at 11:37 AM, Jack Mayer said: Which model do you have? Got an Amazon link? Thanks for the report. I bought the Green one that works on the newer trucks on amazon for 190.00 Quote 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
Ronbo Posted February 15, 2020 Author Report Share Posted February 15, 2020 See you post above for the amazon link Quote Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
RandyA Posted February 20, 2020 Report Share Posted February 20, 2020 Looks like a nice unit. Just for the record, I am still running my Silverleaf VMSpc on my Volvo D12 into a netbook on the dash. It has worked flawlessly for 5+ years. I can design my own gauges and select from virtually any truck or motorhome engine ever built. The number of gauges displayed is dependent on your wishes and screen space available. Quote Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
Ronbo Posted February 20, 2020 Author Report Share Posted February 20, 2020 (edited) If you already have the silver leaf I wouldn’t change. If you are comfortable with the software then why change. If you like to play, you can download this device and see if it will work with silver leaf. It might benefit some people that are having trouble with their gauges. Edited February 20, 2020 by Ronbo Quote Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
