No power to Dometic RM2354 control panel
Steve M
Hi All. I need help with my Dometic 2354. There is no power (I think) to the front control panel. The unit has power to it. I checked with a multimeter and all the fuses are good. I have both 12V DC and 120 V AC thru the fuses in the rear. I tried it with the batteries, shore power, and propane. I am thinking that it is in either the circuit board in the back, or the board behind the front control panel. Before I bring it to the service center I wanted to see if I could get any suggestions here.
 A few week ago I had a service call for a rv that was bought as is.
 It was delivered to Arizona and set up. Customer wanted it operational.
 Fridge did nothing on the control panel. Removed control panel cover, pushed on off button and it worked. Control cover push button area felt really spongy when it was operated in place.
told customer do not turn off. I had a bunch of other stuff to do.
just by luck I got it working?
 Maybe pull connections apart gently and hope for the best.
   Vern
  • 1 month later...
