Rgnmgr Posted January 5, 2020 Report Share Posted January 5, 2020 2015 Ram 1500 crew cab, 8 spd trans., hemi with 3.92 rear end. Rated tow 10,000+. Thinking of purchasing new trailer rated 6,800 dry. Thoughts about towing this weight? Quote Link to comment Share on other sites More sharing options...
NDBirdman Posted January 5, 2020 Report Share Posted January 5, 2020 (edited) Looking at your truck's specs, most I could see was 1,600lb capacity depending on bed length/2 or 4 wheel drive. 5th wheel, probably not going to happen. Travel trailer, not very big. My personal recommendation if you can do it, trade truck up a size or 2 (3/4 ton not far from 1/2 ton in recommendations), pick up an older used camper and try camping for a while. For safety, I try to stay at/under 80% of trucks max. One thing you need to watch is pin weight (if 5th-wheel) or tongue weight. Camper tire age and max truck tire & rear axle weight rating. Load your truck up with fuel/humans/pets, etc, items you will normally have in cab and/or bed and get weighed at a CAT scale most truck stops have. Subtract all that from your trucks combined max weight rating and go from there. Might surprise you what your truck loaded will weigh. One thing folks tend to overlook or not realize, is your truck can move that camper down the road, how well can it *stop* your truck/camper etc in a hurry? I've had idiots pull out in front of me thinking I could stop on a dime..... Edited January 5, 2020 by NDBirdman Quote Link to comment Share on other sites More sharing options...
Second Chance Posted January 5, 2020 Report Share Posted January 5, 2020 Start here to get a little better understanding: ChangingGears.com weights Rob Quote Link to comment Share on other sites More sharing options...
Kirk W Posted January 5, 2020 Report Share Posted January 5, 2020 (edited) Welcome to the Escapee forums! We are happy to have you join us and we will do all that we can to help. As I look at the spec sheet for your truck that comes from Ram, I don't see how you came up with the towing weight of 10K#. It would seem to me that yours should be about 9,350# if we assume the truck is at it's gross rated weight, which is the safe thing to do. A better way would be to load the truck as you would to tow with it and then take that truck to a scale and get an actual weight. If you are thinking of a fifth wheel, then you need to have the trailer attached when weighing the truck to add in the pin weight. Most experienced truck owners will tell you that for comfortable driving as well as good truck performance and reliability, you should not tow more than 80% of the rated weight as a constant thing since that rating is a maximum ever safe weight and is not a recommended weight for everyday. If you go by the 80% suggestion you should them limit the trailer weight to 7,480#. I can tell you that I towed a trailer weighing 4000# with a vehicle rated to tow 5000# for a time, then changed tow vehicles to one rated for much more and the difference in handling and comfortable driving has been remarkable. Edited January 5, 2020 by Kirk W Quote Link to comment Share on other sites More sharing options...
mptjelgin Posted January 5, 2020 Report Share Posted January 5, 2020 It looks to me like a 2015 crew cab 1500 with the hemi and 3.92 rear end has a GCWR of 15,850 or 15,950 depending on box length and 2WD vs. 4WD. So a rated tow capacity in the 10,000 pound range isn't out of the question. As far as looking at the new trailer, I'd disregard the listed empty weight and concentrate instead on the Gross Vehicle Weight Rating (GVWR) which is likely to more closely reflect the weight of the trailer in use, loaded up and ready to go. I've towed with half ton, 3/4 ton, and (mostly) one-ton pickups and prefer the heavy-duty trucks for towing as they are stiffer, more resistant to sway, better brakes, etc. That being said you've got a capable truck, and should be able to find a suitable travel trailer to tow safely behind it. The 80% number gets tossed around quite a lot and it is a decent enough guideline, but not gospel. I've been well beyond it with my last two trucks and have been completely satisfied going down the road, with no maintenance or performance issues. Most gasoline RV's, (which generally use the same drivetrain as the heavy-duty trucks) are well over 80% of the GVWR sitting on the lot, and often quite close to 100% 0f GCWR when loaded up and pulling a toad. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted January 5, 2020 Report Share Posted January 5, 2020 1 hour ago, mptjelgin said: Most gasoline RV's, (which generally use the same drivetrain as the heavy-duty trucks) are well over 80% of the GVWR sitting on the lot, and often quite close to 100% 0f GCWR when loaded up and pulling a toad. That is true and from experience and from reading of the experiences of others, that is the reason that they often do have handling issues that require aftermarket equipment to resolve. Quote Link to comment Share on other sites More sharing options...
Rgnmgr Posted January 6, 2020 Author Report Share Posted January 6, 2020 Thanks for all of the helpful responses. A lot of good information from everyone. One advantage of going to new trailer is our re-assessing of everything we had stored in our old unit. Much of it may not be needed in this new Rockwood Ultra Lite 2608. Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted April 13, 2020 Report Share Posted April 13, 2020 Keep in mind pulling power is not the complete measure of any vehicle, one must factor-in handling ability and stopping ability. NEVER buy a trailer based on the dry unloaded weight unless that is the way you intend to go camping = unloaded; always use the maximum capacity it may weigh. That TT weight calculator from Changing Gears is excellent for properly and safely matching a trailer and tow vehicle. Quote Link to comment Share on other sites More sharing options...
