castlewood57 Posted January 3, 2020 Report Share Posted January 3, 2020 Ok, I have a Volvo 670 we had 17" of snow dumped on us, took front end loader and moved snow for about 5 hours. Wanted to move truck to clean around it and tires just spun. found tow hook but no pins, being on a farm I found something that would work as a pin temporarily. So now i am doubting whether tow hook is right, and I know I definitely need a pin. Does anyone have pictures, and where to buy these items at? It was a long day, and didn't like having my own highway through hell episode just outside the front door of my house trying to pull the truck with the tractor. Tractor didn't like pulling that much and spent a considerable amount of time just spinning on ice. Time to get correct tools for the job, starting with hooks and pins. Thanks, Chuck Quote Link to comment Share on other sites More sharing options...
Jaydrvr Posted January 3, 2020 Report Share Posted January 3, 2020 You can use most anything for a pin. I've used a Craftsman half inch ratchet, but it was an earlier version from my dad circa 1968. Didn't even leave a scratch! Jay Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted January 3, 2020 Report Share Posted January 3, 2020 Tow pin; wrecking yard or dealer. Get some chains, learn how to put them on when you can't move. Use sand, kitty litter, fireplace ash, anything that can increase the traction. Adapt, improvise, overcome. Quote Link to comment Share on other sites More sharing options...
rpsinc Posted January 3, 2020 Report Share Posted January 3, 2020 I have seen shackels used instead of hooks. Just leave them in place or remove. Quote Link to comment Share on other sites More sharing options...
geodog Posted January 3, 2020 Report Share Posted January 3, 2020 I bought a Hitch pin at Tractor Supply. ShortyO ps. I live in West Texas---no snow Quote Link to comment Share on other sites More sharing options...
Imurphy907 Posted January 3, 2020 Report Share Posted January 3, 2020 https://www.amazon.com/Eyelet-Receiver-Insert-Tractor-000lbs/dp/B00NC6WXFO This is what I have. use a standard trailer hitch pin to hold it in place. Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted January 4, 2020 Report Share Posted January 4, 2020 Chains mite be a better bet. Nothing like getting out of a bad situation and unhooking the pulling unit. Get everything out of the way and still stuck. I finally had to buy a used set for possibly being stuck 100’ from pavement. It was well past time to go south, so I found a set and bought them. Now I have a place for storage of steel things as I carry a welder also. Now there could be a time when you could just lay the chains on the ground and drive out from a small problem. Also chains will work when only one driver is available. Or no pulling unit is available. Just my thought, Vern Quote Link to comment Share on other sites More sharing options...
Lance A Lott Posted January 4, 2020 Report Share Posted January 4, 2020 1 hour ago, Wrknrvr said: Now there could be a time when you could just lay the chains on the ground and drive out from a small problem. Just my thought, Vern I have done this many times, I have even used a tow chain snaked in front of the tire. It works really well if you can start just cant get up a small slope. You can also thry dumping the air and then chaining up the axle without the leveling valve then air up the added wheight will often help especially if its the rear axle that will be off the ground. A couple of year ago I was stuck, the front tires had sunken and then the ground froze, and it was ice under the farm tractor so It wouldn't pull. I put the loader on the truck frame and lifted the tractors front end, it backed right out, make sure the bucket it not going to slide on the truck. Quote Link to comment Share on other sites More sharing options...
noteven Posted January 4, 2020 Report Share Posted January 4, 2020 Time for the “jewelry” (tire chains). If you are just stuck right there on ice under the tires, and the footing is better immediately, pouring some methanol on the drive tires and being really gentle with the clutch you can rock your way into forward motion, especially if forward is a tiny bit down hill. Dropping the psi in the tires to about 35 or 40 can help a lot to. The Big HDT’s don’t put much ground pressure down on the drive tires when they are empty. Quote Link to comment Share on other sites More sharing options...
rickeieio Posted January 5, 2020 Report Share Posted January 5, 2020 One time at band camp.......... Oh, wrong movie.. in a pinch, run a rope through the holes in the wheels and around the tire to "knit" a chain of sorts. Not very fancy, but it got me out when I was stuck on a farm with no tow vehicle. what Darryl said. Quote Link to comment Share on other sites More sharing options...
Parrformance Posted January 5, 2020 Report Share Posted January 5, 2020 I bought the factory pins from Dex if I remember correctly https://www.dexheavydutyparts.com/ Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted January 5, 2020 Report Share Posted January 5, 2020 Now Rick you brought back memories of my childhood. The kids in my neighborhood would wrap small rope around our bicycle tires for traction when it snowed. that is back a few yours, Vern Quote Link to comment Share on other sites More sharing options...
runaway parents Posted January 5, 2020 Report Share Posted January 5, 2020 Sand lots of sand. Most tire shops have filled sand bags ready to use. Kitty litter works but makes a mess . if you can get it under the tires it should walk right out .for a pin a 1/2 inch our 5/8 inch bolt should work fine. I f these don't work time to sling some iron(chains) Quote Link to comment Share on other sites More sharing options...
runaway parents Posted January 5, 2020 Report Share Posted January 5, 2020 (edited) Here is another way to get unstuck. If your truck has differential lockers .Take a tow strap. put loop in tow strap between back tires run a bar threw hole in out side wheel threw loop in strap then threw hole in inner wheel (now this will wedge strap down between wheels. most likely ruin strap) Anchor other end of strap directly behind truck or directly in front of truck to something solid ie: tree another vehicle that wont move .put truck in gear and let it crawl up the strap . The truck will pull it self out .Pull the tree over or break the strap. once you have done this the strap will most likely have to be cut off it will be jammed between the wheels to the point that you will have to remove the wheel . So best thing to do is to cut strap as short as you can get it. Pull the bar out of the wheel and limp it to the tire shop. This is a extreme thing to do but a strap is cheaper than hiring a wrecker to winch you out. Edited January 5, 2020 by runaway parents Quote Link to comment Share on other sites More sharing options...
castlewood57 Posted January 5, 2020 Author Report Share Posted January 5, 2020 thanks everyone for the word of wisdom, Yes it looks like it may just be time to get some 'jewelry' for the truck. Being in South Dakota, and wife still working FT, it means snow is just a going to be a way of life for a while. I have cattle as well and this isn't just an RV truck, it still hauls several truckloads of hay, and farm equipment. So it seems it is time to get a few more items for the truck, some decent fenders for drive wheels and some good chains for it as well. Thanks all, Chuck Quote Link to comment Share on other sites More sharing options...
castlewood57 Posted January 6, 2020 Author Report Share Posted January 6, 2020 This is what I had to contend with.. Quote Link to comment Share on other sites More sharing options...
HERO Maker Posted January 6, 2020 Report Share Posted January 6, 2020 On 1/4/2020 at 7:49 PM, rickeieio said: One time at band camp.......... Oh, wrong movie.. I should have guessed!!!!! Quote Link to comment Share on other sites More sharing options...
