lockmup68 Posted June 18, 2019 Report Share Posted June 18, 2019 21 hours ago, Steve from SoCal said: There is an aspect of propane that should be considered. IF you have a small air cooled generator cold weather opps could be an issue. Forklifts and equipment that run on propane have water heated vaporizers and even with that running in very low temps below the teens can be challenging. That is probably not an issue for general use, in an emergency situation that condition could exist. That said I have no first hand knowledge of these small engine systems, the propane engines I have all use the forklift bottles that draw liquid not vapor. I agree that for intermittent use propane is the fuel of choice. Steve I would assume if you are using propane for heat in the trailer, it will also work for the generator. Flow is flow, but if it is too cold to work for your furnace, then you have more problems to deal with! Quote 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Big5er Posted June 18, 2019 Report Share Posted June 18, 2019 20 hours ago, lockmup68 said: forgot pic of the Onan 8k diesel, sips from tanks and is very quiet. And it is working now! I think the 8k is quieter than the two Hondas. I wish you would quit posting this picture. I get so jealous everytime I see it!! Quote MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Steve from SoCal Posted June 18, 2019 Report Share Posted June 18, 2019 2 hours ago, lockmup68 said: I would assume if you are using propane for heat in the trailer, it will also work for the generator. Flow is flow, but if it is too cold to work for your furnace, then you have more problems to deal with! The withdraw rate is factor, a small heater is not using the volume a generator does. Steve 2 hours ago, lockmup68 said: Quote 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
lockmup68 Posted June 18, 2019 Report Share Posted June 18, 2019 2 hours ago, Big5er said: I wish you would quit posting this picture. I get so jealous everytime I see it!! I'll send you a copy of the invoice it took to repair it. But all good now. Quote 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Big5er Posted June 18, 2019 Report Share Posted June 18, 2019 1 minute ago, lockmup68 said: I'll send you a copy of the invoice it took to repair it. But all good now. That is where I have you beat. I live at an Onan service center. They will hopefully keep it running well for me. I'm heading to Herrin next week to get the stinger(?) built to house mine. With any luck, by this time next month I will be running a 7.5kw Onan QD when I need it. I just wish I could have mounted mine the way you did...or under the right side fairing...oh well, Plan A, B and C shot to hell, on with Plan D. Quote MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
lockmup68 Posted June 18, 2019 Report Share Posted June 18, 2019 (edited) I hear ya. Mine was a controller board went out. Up until that point, It just flat worked. You can't just replace the controller board on the older design, have to replace the entire inverter head to which the controller board is soldered. I'm seriously thinking about moving the gen set to the drivers side rear side, right behind the tires, same position it is in now, but to the drivers side outside the framerail, and move the hitch forward into the spot where the genset is. I could shorten up the bed by 3 feet or so. AC fix first...... Edited June 18, 2019 by lockmup68 Quote 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
rdickinson Posted June 19, 2019 Report Share Posted June 19, 2019 The idea of mounting b/w the frame rails has crossed my mind but service could be a problem. There is a pic or pics out there of a generator mounted on a slide which came out the back of the truck. Much the same as motorhome installations. I'm not sure if the door came out with the generator slide or swung out of the way. Sliding out would cause some issues for wiring. Quote Link to comment Share on other sites More sharing options...
rickeieio Posted June 19, 2019 Report Share Posted June 19, 2019 7 hours ago, Steve from SoCal said: The withdraw rate is factor, a small heater is not using the volume a generator does. Steve True. Evaporation is what makes yout a/c work......... and keeps the ice box.....iceeeeee. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
HERO Maker Posted June 20, 2019 Report Share Posted June 20, 2019 On 6/17/2019 at 3:53 PM, lockmup68 said: forgot pic of the Onan 8k diesel, sips from tanks and is very quiet. And it is working now! I think the 8k is quieter than the two Hondas. Wow! That is really quiet! I can't even hear it!!!!😀 Quote Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
jenandjon Posted June 24, 2019 Report Share Posted June 24, 2019 I mounted my Onan in a tool box that I got from Vander Haags salvage yard. I had an electrician run outlets and a breaker box. I have one 30 amp and two 20 amps on the bed. Four 20 amp outlets inside the cab. I got a 50 gallon John Deere fuel tank. Mounted to the bed. Bolted through the cross member and to the headache rack using the factory mounts. I have run the exhaust through 2 car mufflers. It is very quiet. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
NTPA Announcer Posted July 7, 2019 Report Share Posted July 7, 2019 We have an Onan Propane 5500 for the Redwood. It runs well and does what it's asked, but kinda has a drinking problem. I make sure we are full when we leave. I don't want to wreck the train, but I'd sure like to find a 7500 or + diesel for the bed of the hauler to marriage to the rig Quote Denver and Ms Judy Geitgey 2006 VOLVO 780 41 ' Redwood NTPA Event Announcer dngeitgey@gmail.com Link to comment Share on other sites More sharing options...
noteven Posted July 8, 2019 Report Share Posted July 8, 2019 2 hours ago, NTPA Announcer said: We have an Onan Propane 5500 for the Redwood. It runs well and does what it's asked, but kinda has a drinking problem. I make sure we are full when we leave. I don't want to wreck the train, but I'd sure like to find a 7500 or + diesel for the bed of the hauler to marriage to the rig Propane has many btu’s less per pound than gasohol and even more less than summer deezil fewl. It’s why deezil engines are “more efficient”... btu’s per lb and high compressions. Rudolph Diesel was pretty intelligent for a guy without a smart phone 😁 Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
NTPA Announcer Posted July 8, 2019 Report Share Posted July 8, 2019 Exactly. It was in the coach when we bought it. I’m grateful for the constant power when needed. Quote Denver and Ms Judy Geitgey 2006 VOLVO 780 41 ' Redwood NTPA Event Announcer dngeitgey@gmail.com Link to comment Share on other sites More sharing options...
Big5er Posted July 8, 2019 Report Share Posted July 8, 2019 (edited) On 7/7/2019 at 5:03 PM, NTPA Announcer said: I'd sure like to find a 7500 or + diesel for the bed of the hauler to marriage to the rig I just picked my truck up from Herrin Welding today. The box is done....I've got to clean up the carbon from being run with a broken exhaust, wire it up and then get the bed liner applied to it and the bed and that project will be done. 1 down, 467 million projects to go. I couldn't pass up that commercial grade 7.5kw Onan QD. Pictures here Edited July 8, 2019 by Big5er Quote MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted July 9, 2019 Report Share Posted July 9, 2019 Can't wait to see it this weekend, and of course the 4 legged babies you have, and wait you too.l Roger Quote Link to comment Share on other sites More sharing options...
noteven Posted July 9, 2019 Report Share Posted July 9, 2019 On 7/7/2019 at 6:58 PM, NTPA Announcer said: Exactly. It was in the coach when we bought it. I’m grateful for the constant power when needed. And LPG stays happy in storage - no gasohol absorbing water - no diesel growing algae... Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Sculptor Posted August 18, 2019 Report Share Posted August 18, 2019 Are any of you home fab folks using the space behind the chassis fairings? (I don't mean the flip open step fairings) I have space in front of my tanks that I would like to use for a Honda 2000 inverter gen, but no good way to access behind the fairings. They are a bit broken and I might just ditch them altogether. Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Big5er Posted August 21, 2019 Report Share Posted August 21, 2019 On 8/18/2019 at 1:17 PM, Sculptor said: Are any of you home fab folks using the space behind the chassis fairings? (I don't mean the flip open step fairings) I have space in front of my tanks that I would like to use for a Honda 2000 inverter gen, but no good way to access behind the fairings. They are a bit broken and I might just ditch them altogether. You mean like this? Quote MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
DesertMiner Posted August 21, 2019 Report Share Posted August 21, 2019 Or you could mount something like Sliding tray Quote Link to comment Share on other sites More sharing options...
Sculptor Posted August 21, 2019 Report Share Posted August 21, 2019 7 hours ago, Big5er said: You mean like this? Thanks Phil , yes exactly like this, but on my 2013 that space is taken with the DPF. I want the access like yours but farther back. How is retirement treating you? Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Jack Mayer Posted August 21, 2019 Report Share Posted August 21, 2019 (edited) On a newer DPF truck there is not usually room to mount a "real" genset under the cab. We usually only have 22" of space for our APUs and in some cases less. There may be room to squeeze in some Honda 2000-style units. Every truck is different - just measure and see. Then you can build a custom rack as shown. We can build a custom drom that has an Onan in the bottom and storage above. But it takes more space depth-wise than a typical drom and you have to plan your deck spacing around it. That has the advantage of leaving side box space on your bed - which is more accessible and usable than drom space. Edited August 21, 2019 by Jack Mayer Quote Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Big5er Posted August 21, 2019 Report Share Posted August 21, 2019 (edited) 9 hours ago, Sculptor said: Thanks Phil , yes exactly like this, but on my 2013 that space is taken with the DPF. I want the access like yours but farther back. How is retirement treating you? Damn the DPF stuff. I went as far back as I could and then ran into the fuel tank. I've got the new Onan generator so now that is just open space...maybe i need one of those tiny motorcycles? And retirement is great, thanks. I have no idea what day it is anymore....everyday is Saturday Edited August 21, 2019 by Big5er Quote MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Sculptor Posted September 3, 2019 Report Share Posted September 3, 2019 (edited) On 8/21/2019 at 4:14 PM, Big5er said: maybe i need one of those tiny motorcycles? https://tenor.com/zv2o.gif Edited September 3, 2019 by Sculptor Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Big5er Posted September 5, 2019 Report Share Posted September 5, 2019 On 9/3/2019 at 8:03 AM, Sculptor said: https://tenor.com/zv2o.gif That's it!! I could stuff one of those behind the passenger side fairing. Quote MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Sculptor Posted September 18, 2019 Report Share Posted September 18, 2019 On 9/4/2019 at 8:21 PM, Big5er said: That's it!! I could stuff one of those behind the passenger side fairing. I found a "better" one Mr. Cob will enjoy this. I skipped to 15:32 because after the paint it takes shape. Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
