GlennWest Posted June 24, 2020 Author Report Share Posted June 24, 2020 Well, that facebook bunch has got me questioning using Victrons. I asked about whether we needed a monitor as all programming done with computer and phone apps also. Definitely so they say. Mention needing to change settings, turning on and off. Leads me to think they lot of trouble. Commuting with Steve Dixion on his Magnum system and he States basically set it and forget it. His works trouble free. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Randyretired Posted June 25, 2020 Report Share Posted June 25, 2020 When I was looking at charge controllers, Victron had features that others didn't but I am also a plug it in and forget it guy. I wouldn't use a lot of those features and a more basic controller fits my needs for less $$$. Quote Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
DesertMiner Posted June 25, 2020 Report Share Posted June 25, 2020 Glenn just copy Mr. Dixon’s set up and be done. You are driving yourself crazy ! Everyone on FB will tell you their setup is the Best! Quote Link to comment Share on other sites More sharing options...
GlennWest Posted June 25, 2020 Author Report Share Posted June 25, 2020 Yes, you guys are right. I begining to believe Victron is " drinking the kool aid". Lol. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
jcussen Posted June 25, 2020 Report Share Posted June 25, 2020 (edited) Victron solar controllers, battery monitor, and inverter/charger work great in my coach 12 volt battery, 120 volt ac system. But for my house 240 volt system, magnum and Midnite solar work better. Edited June 25, 2020 by jcussen Quote Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
GlennWest Posted June 25, 2020 Author Report Share Posted June 25, 2020 Well I like their controllers and battery monitor. The inverter gives me pause. Not that they don't work but it seems like a part time job to keep them right. That is what they were describing while bragging about them. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
jcussen Posted June 25, 2020 Report Share Posted June 25, 2020 Not sure what you mean "keep them right". For lithium, you must use Victron Connect to initially set up values, but once set, I have not needed to adjust anything since I set it up two years ago. This is a 12 volt battery bank and a 120 volt 3000 watt inverter. Don't know about running a 240 volt Victron system, which is why I use a Magnum on my 48 volt battery and 240 ac volt system at the house, it is also a set it and forget it system. Quote Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
GlennWest Posted June 25, 2020 Author Report Share Posted June 25, 2020 1 hour ago, jcussen said: Not sure what you mean "keep them right". For lithium, you must use Victron Connect to initially set up values, but once set, I have not needed to adjust anything since I set it up two years ago. This is a 12 volt battery bank and a 120 volt 3000 watt inverter. Don't know about running a 240 volt Victron system, which is why I use a Magnum on my 48 volt battery and 240 ac volt system at the house, it is also a set it and forget it system. Thank you. Your post is way different from theirs. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
lockmup68 Posted June 26, 2020 Report Share Posted June 26, 2020 17 hours ago, GlennWest said: Thank you. Your post is way different from theirs. Glenn, been following your posts on the facebook forums too. I think it is simply a communication thing. You have a monitor with apps and web interface. Saying "don't want to mess with a monitor" I think came across as not having any monitor in place, which is not true. There always needs to be a monitor and you would have a monitor. Just my two cents. Quote 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
GlennWest Posted June 26, 2020 Author Report Share Posted June 26, 2020 17 minutes ago, lockmup68 said: Glenn, been following your posts on the facebook forums too. I think it is simply a communication thing. You have a monitor with apps and web interface. Saying "don't want to mess with a monitor" I think came across as not having any monitor in place, which is not true. There always needs to be a monitor and you would have a monitor. Just my two cents. I was under the impression that set up was done with a laptop. Now I understnd a battery monitor Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
