Cotreker Posted January 28, 2019 Report Share Posted January 28, 2019 No start Sunday late afternoon in a snow covered snowmobile parking lot. So I researched this site and found very similar issues. Last summer I noticed the starter hang up a time or two and then Sunday dead for 5 to 6 try's. Hit is with a bar few times and it started, good old trick to know about. I am interested in pulling this off and having it serviced at a local starter shop per a post I found. Any recommendations pro or con???? "When the "hammer-kiss" to the starter is needed this usually indicates that the brushes are worn and likely the communcater needs to be turned and mica needs undercut and then brushes installed.....fairly quick job and any real stater shop can do the work for reasonable $...." Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Parrformance Posted January 28, 2019 Report Share Posted January 28, 2019 They will likely have a reman on the shelf to swap with yours. Did this type of work for a year or so after high school. https://www.dbelectrical.com/products/starter-volvo-truck-acl42-acl64-vhd-vnl-vnm-series-ved12-engine.html?mrkgcl=1145&mrkgadid=3209329535&product_id=SMT0387&adpos=1o1&creative=194904876629&device=c&matchtype=&network=g&gclid=Cj0KCQiA7briBRD7ARIsABhX8aC9jDNjWFouzh4YQjrVbpEHDAdRuWq7Kdzc5Y2qBhYPKZY6x2A8Jg4aAn5AEALw_wcB I have done business with DBelectrical in the past, their starter has been perfect for 7-8 years or so in my wonton. 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Parrformance Posted January 28, 2019 Report Share Posted January 28, 2019 Two day shipping with Prime Ooops, this was is up to 2002 https://www.amazon.com/Electrical-Sdr0458-Starter-ACL42-ACL64/dp/B0081S96YE/ref=sr_1_1_sspa?s=automotive&ie=UTF8&qid=1548702367&sr=1-1-spons&keywords=volvo+vnl+starter&psc=1 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
DesertMiner Posted January 28, 2019 Report Share Posted January 28, 2019 Just change it.....see if you can get a "gear reduction" model. What motor? Link to comment Share on other sites More sharing options...
Cotreker Posted January 28, 2019 Author Report Share Posted January 28, 2019 Hello Parrformance, just ordered from DB and did get the gear reduction for $167 on the phone. Will have it this Thursday. Time to clean the old start off and area. Thanks for the help. Volvo motor D12. STARTER VOLVO TRUCK ACL42 ACL64 VHD VNL VNM Series VED12 Engine Item Number: 18970 Brand: DB Electrical Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Parrformance Posted January 28, 2019 Report Share Posted January 28, 2019 Easy swap, don't forget to disconnect the batteries first.👍 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Cotreker Posted January 29, 2019 Author Report Share Posted January 29, 2019 OK, how long will this take me to R&R? Yes I will remove battery cables. Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted January 29, 2019 Report Share Posted January 29, 2019 It's 3 bolts but it is heavy. I paid to have mine done. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Parrformance Posted January 29, 2019 Report Share Posted January 29, 2019 So long as things are not too tight, I suspect 30 minutes R&R. The gear reduction starters are lighter than the traditional units. 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
bja1234 Posted January 29, 2019 Report Share Posted January 29, 2019 Tie a light rope around the old starter, then hand the other end up to a helper positioned above the tire for assistance. Seems lighter this way when laying on back with hands extended above head...............Experience is a wonderful thing to have and a SOB to get. Link to comment Share on other sites More sharing options...
Cotreker Posted March 21, 2019 Author Report Share Posted March 21, 2019 Update, spent 3 hours busting the bolts loose only got the front two free. The back one is very tight, can not get a bar onto it due to the long lenght of the extensions. My older air gun and electric torque gun will not break them free. Good excuse to purchase a new Kobalt impact wrench it does 600 ft bl's which should do it just fine! Put some Kroil on the bolt to make it release, hope it works. Next update coming soon when it is off and back running. Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Cotreker Posted March 25, 2019 Author Report Share Posted March 25, 2019 New starter now installed along with the solenoid (one on the firewall) covered my bases. Ended up getting the difficult bolt free with a 1/2" 17mm short impact socket (6 point) and pray bar. With just the right sections and process I got hold of it and it came loose. Nothing easy about this job, sometimes I do like a challege and I got one. I added a few more tools to the box as a result of doing this job. My connections were all cleaned and coated with Dielectric Grease. Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
rickeieio Posted March 25, 2019 Report Share Posted March 25, 2019 11 minutes ago, Cotreker said: impact socket (6 point) and pray bar. Now there's a tool I wish were in my toolbox.😜 KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted March 26, 2019 Report Share Posted March 26, 2019 18 hours ago, rickeieio said: Now there's a tool I wish were in my toolbox.😜 Yep, the better pray bars come with knee pads. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
