Chuck Posted January 28, 2019 Report Share Posted January 28, 2019 2003 Volvo vnl 610. About a mile from our campground I noticed the truck gunning bad, the computer mpg dropped significantly. Ran a fault check. 1. Air inlet heater electrical fault 2. Injector #6 Electrical fault inactive.. these are new codes as I cleared all old ones some time ago. What is the connection between these 2 fault codes. Thoughts in what is going on. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted January 28, 2019 Report Share Posted January 28, 2019 There isn't any connection, other than 2 failures since the last code clearing. You've lost a grid heater, and sounds like an injector. Depending on ht e miles on all the injectors, it may be time to replace the whole bank. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Chuck Posted January 28, 2019 Author Report Share Posted January 28, 2019 634,000 miles. Don't know if ever changed. Closest shop is 18 miles. Ok to drive? Link to comment Share on other sites More sharing options...
Parrformance Posted January 28, 2019 Report Share Posted January 28, 2019 Perhaps checking connections would be the best first step. 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Jaydrvr Posted January 28, 2019 Report Share Posted January 28, 2019 14 hours ago, Chuck said: 634,000 miles. Don't know if ever changed. Closest shop is 18 miles. Ok to drive? Certainly okay to drive 18 miles.. Prolly not 500 miles.. If the injector is not working, you're not getting fuel to lubricate the upper cylinder. A few miles are fine, but hundreds can do damage. Link to comment Share on other sites More sharing options...
Chuck Posted January 28, 2019 Author Report Share Posted January 28, 2019 Took the truck out this morning- Ran fine for about 15 miles, then began to shutter slightly. As it ends up, the only active code is “Engine Air I let heater electrical fault active. Any thoughts on this..? Link to comment Share on other sites More sharing options...
Moresmoke Posted January 28, 2019 Report Share Posted January 28, 2019 Inlet heater is the grid heater to warm the intake air for cold starting. Might make the truck run a bit rough when first started, but should not be an issue after 15mi. The heater fault could be the grid itself, or a power supply issue like a fuse or bad connection. I would start with fresh fuel filters and see what happens after that. Link to comment Share on other sites More sharing options...
Showme Posted January 30, 2019 Report Share Posted January 30, 2019 The air heaters on Volvo engines, may come apart and be digested by the engine. Bad day when that happens. Just saying if apiece of the air heater grid comes off and is sucked into a cylinder hitting the injector tip, that would be the connection between the two codes. Pull the intake hose and four bolts holding the grid heater, do a close visual inspection, looking for any missing or loose pieces. Cover the air inlet manifold while doing your inspection, don't want anything to fall into the air inlet. Volvo VNL / Missouri Titled RV Ved12 425HP Super 10 Spd 37ft KOA Fifth Wheel Jeep Rubicon Toad Link to comment Share on other sites More sharing options...
Pete Kildow Posted January 30, 2019 Report Share Posted January 30, 2019 Sounds like a bad wire on the injector. Being it runs good until engine is getting warm. Link to comment Share on other sites More sharing options...
rpsinc Posted January 30, 2019 Report Share Posted January 30, 2019 Not versed in this topic but just asking-could it be a bad ground?? Marcel Link to comment Share on other sites More sharing options...
Chuck Posted February 2, 2019 Author Report Share Posted February 2, 2019 Does this make sense. d-12 Volvo engine. 644,000 miles. No active injector faults. 1. Truck died on me where we have been staying, Tombstone, the town to tough to die. Lol. Lost prime again. Could not reprime 2. towed to Vanguard Volvo in Tucson, thank you Coach net. 3 While I did have it running. Temp from heat gun on #6 exhaust port significantly cooler than the other ports. 4. Is there a connection between losing fuel prime and a bad injector or cup.? 5. Of course dealer wants to replace all 6 injectors. Wooh, hold on here. I told them to look at #6 only. Granted, the others perhaps should be changed, but I would rather wait until I get home in a few weeks. 6. Could it be just a cup and O ring issue? Link to comment Share on other sites More sharing options...
