Wrknrvr Posted January 25, 2019 Report Share Posted January 25, 2019 This is a 12vdc controlled value that is fairly easy to find if you can use it. I used one of these on my air operated clutch in our HDT. It was used to exhaust the air from the cylinder to leave the clutch out. I also used one to separate air supply to the air shocks on my jeep from front axle to the rear axle it is from a discarded gas valve from a Rv refrigerator.it is closed when not powered. Opens when powered. Just thought, Vern not responsible for what you may think of to use this for. If anything. Link to comment Share on other sites More sharing options...
sdixon747 Posted January 25, 2019 Report Share Posted January 25, 2019 Are you selling it? Giving it away? Or just telling of it’s existence? I have some potential uses for it if you are looking to part with it. Steve Steve & Gail 2000 Volvo VNL660 Autoshift Detroit 60 12.7 "Semi Crazy" 2016 smart "Lil Crazy" 2018 Space Craft 48' TT "The Nut House" KJ4YGY & KK4CTE Link to comment Share on other sites More sharing options...
Parrformance Posted January 25, 2019 Report Share Posted January 25, 2019 https://www.amazon.com/4inch-Normally-Closed-Electric-Solenoid/dp/B00ON8XFSO ://www.amazon.com/Position-Pneumatic-Electric-Solenoid-Valve/dp/B00VU1BVDI https://www.amazon.com/Kleinn-Air-Horns-307-Solenoid/dp/B00EVQI2TK/ref=asc_df_B00EVQI2TK/?tag=hyprod-20&linkCode=df0&hvadid=312157747602&hvpos=1o5&hvnetw=g&hvrand=270126027491255446&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9012168&hvtargid=pla-436389682938&psc=1 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Wrknrvr Posted January 25, 2019 Author Report Share Posted January 25, 2019 No I am not selling it. Just throwaway part when people scrap a RV fridge. It is the gas valve on the fridge. Just some info I am passing on . Vern Link to comment Share on other sites More sharing options...
Lou Schneider Posted January 26, 2019 Report Share Posted January 26, 2019 Just keep in mind the working pressure in the RV refrigerator's gas line is 11 inches WC or about 0.5 PSI. Substantially less than the working pressure in your clutch or shocks. Link to comment Share on other sites More sharing options...
ARGO Posted January 26, 2019 Report Share Posted January 26, 2019 Plenty on Ebay for less than $20, full pressure. You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
Wrknrvr Posted January 26, 2019 Author Report Share Posted January 26, 2019 I will check the one I installed in my truck. It works to 120 psi or so. Maybe 140 psi. Yes that was a question I had. I tried it and it worked. The air operated clutch I made has a compressor from a toad braking system that was free. It did not work. But the parts did. That is how I get higher than truck system pressure. Now when opened it did release the air much faster than I wanted it. So the air cylinder released the clutch faster than I liked. So I installed a needle valve on the exhaust port of the valve and adjusted it for the rate that I liked. I think that needle valve was from a Rv fridge also. Now could you use two of these to operate the clutch fan independent of the truck system. One to engage the clutch, one to exhaust the air. That could be sorta a jake brake. Now I do have a muffler on my exhaust system, but it is open straight through. Sorta a anti deer device. So it is slightly loud. But some places do not like noise. Or use it when u are on a big incline to control temperature. i do have a pressure gauge on the dash for the air clutch I built. It also has a switch telling me that the clutch pedal has fully returned to the proper position. It has a light that says the clutch pedal is not at its resting place. I got that idea for the air operated clutch from Randy. Just thinking,. Vern Link to comment Share on other sites More sharing options...
