Hot Rod Posted January 19, 2019 Report Share Posted January 19, 2019 (edited) Not exactly hdt, but this is what I picture whenever I see some dumba$$ hauling a fifth wheel with a 1/2 ton shortbed truck: I'm thinking Phil would throw away the key on this one. Edited January 19, 2019 by Hot Rod Quote Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted January 19, 2019 Report Share Posted January 19, 2019 What Ford has air brakes? So what type of reverse controller does he have? Quote Link to comment Share on other sites More sharing options...
Big5er Posted January 19, 2019 Report Share Posted January 19, 2019 Interesting setup. The airlines appear to be connected to the truck so I wonder if there is some sort of compressor driven addons available for the truck brakes, and IF that trailer is empty it should be well within the capacity of that F-450 but it sure looks messed up. Quote Link to comment Share on other sites More sharing options...
chirakawa Posted January 19, 2019 Report Share Posted January 19, 2019 I feel the same way about somebody playing with their cellphone while driving down the road. 🙂 Quote Link to comment Share on other sites More sharing options...
Second Chance Posted January 19, 2019 Report Share Posted January 19, 2019 Those box trailers weigh about 15,000 lbs. empty. If he's hauling anything other than Styrofoam, that's got to be heavy! Rob Quote Link to comment Share on other sites More sharing options...
Scrap Posted January 19, 2019 Report Share Posted January 19, 2019 Mico makes the relay valve, but pretty sure you have to make your own air/tractor protection kit. The problem is that most hydraulic ABS ECU's aren't set up with PLC so the truck can't light a dash light when the trailer has a ABS fault, which is required. So you have to do it on a truck older than 2001 or Big5er gets ya. https://www.mico.com/sites/default/files/document-pdfs/80460051Hydraulic Over Air Relay Valves_0.pdf That' video is a new trailer getting delivered isn't it? Quote Link to comment Share on other sites More sharing options...
Pete Kildow Posted January 20, 2019 Report Share Posted January 20, 2019 Almost bet, he's moving empty trailers. Truck is not going to last long though. Quote Link to comment Share on other sites More sharing options...
Dutch_12078 Posted January 20, 2019 Report Share Posted January 20, 2019 One of our truck shop customers had/has two similar trucks, one an F450 and the other an F550, that they used for moving empty trailers to/from their trailer repair/rebuild shop and the customers yards. The last I knew, at least one of them had hit 150K miles and was still in service. They both had a compressor and air tank on board, but I don't recall how the air brake control system was set up. Quote Link to comment Share on other sites More sharing options...
jenandjon Posted January 20, 2019 Report Share Posted January 20, 2019 I see this all the time. There are 2 Semi truck manufacturers in my area. They are often delivered this way. I got close enough to one pickup to see they had a big air tank on the bed. Quote Link to comment Share on other sites More sharing options...
rickeieio Posted January 20, 2019 Report Share Posted January 20, 2019 I'm surprised that a dry van weighs that much. My hopper trailer is less than half that. But then, I don't have a wood floor, that will hold up a fork lift. Quote Link to comment Share on other sites More sharing options...
Dutch_12078 Posted January 20, 2019 Report Share Posted January 20, 2019 According to "Ship North America", a 53' dry van approximate tare weight is 15,000 lbs, and 15,500 for a refer van. Quote Link to comment Share on other sites More sharing options...
jenandjon Posted January 21, 2019 Report Share Posted January 21, 2019 13 hours ago, rickeieio said: I'm surprised that a dry van weighs that much. My hopper trailer is less than half that. But then, I don't have a wood floor, that will hold up a fork lift. What kind of hopper do you have? Mine weighs around 12,000. Quote Link to comment Share on other sites More sharing options...
beemergary Posted January 21, 2019 Report Share Posted January 21, 2019 I just think-My fifth wheel is bigger than your fifth wheel. Usually just mom and pop unless they plan on throwing a party when they get to the campground. I am the opposite and use a Peterbilt 359 to haul a 32 ft. trailer. Quote Link to comment Share on other sites More sharing options...
Steveoreno Posted January 21, 2019 Report Share Posted January 21, 2019 I saw this on a travel trailer FB group. I thought it rich that a bunch feel that its great to tow a 35 ft travel trailer with a 1/2 ton. Yet this was out of line. I gave up on the page to many idiots Quote Link to comment Share on other sites More sharing options...
rickeieio Posted January 22, 2019 Report Share Posted January 22, 2019 11 hours ago, jenandjon said: What kind of hopper do you have? Mine weighs around 12,000. I have a 41' Wilson, spring ride, ag hoppers. Tare is roughly 9k. Hooked to my CH613 Mack, it's 25k with 1/2 tank of fuel and a 300# doofus behind the wheel. Quote Link to comment Share on other sites More sharing options...
Carlos Posted January 22, 2019 Report Share Posted January 22, 2019 On Sunday I sold the OEM crappy foam bed from my new TT to a guy who is going to be doing this with his Chevy 1-ton. He turned the back of the extended cab into a bed, and stuffed in the mattress. Apparently there's money to be made moving empty trailers quickly on demand, and at only 15k it's well within limits. Quote Link to comment Share on other sites More sharing options...
Big5er Posted January 23, 2019 Report Share Posted January 23, 2019 (edited) 9 hours ago, Carlos said: He turned the back of the extended cab into a bed, and stuffed in the mattress. LOL, and he will try to log his off duty time as "sleeper berth" until he runs into that nasty DOT cop who shows him that his back seat isn't wide enough to be a sleeper berth and shuts him down for violating his hours of service. 😎 Send him down my way. I love to hear drivers explain how they spent the night in a berth they don't have. Edited January 23, 2019 by Big5er Quote Link to comment Share on other sites More sharing options...
castlewood57 Posted January 23, 2019 Report Share Posted January 23, 2019 I'd love to see him in South Dakota with our high winds. Our F150 and a 28' camper with sway bars kept me busy. Chuck Quote Link to comment Share on other sites More sharing options...
jenandjon Posted January 23, 2019 Report Share Posted January 23, 2019 On 1/21/2019 at 6:01 PM, rickeieio said: I have a 41' Wilson, spring ride, ag hoppers. Tare is roughly 9k. Hooked to my CH613 Mack, it's 25k with 1/2 tank of fuel and a 300# doofus behind the wheel. I'm only hauling 100 bushels more than you and I have 7 axles. Something tells me all theses extra pushers and tags may not be worth the headache. I have a 50 ft Timpte with a 07 Pete. Empty around 33,000. Quote Link to comment Share on other sites More sharing options...
Carlos Posted January 23, 2019 Report Share Posted January 23, 2019 13 hours ago, Big5er said: LOL, and he will try to log his off duty time as "sleeper berth" until he runs into that nasty DOT cop who shows him that his back seat isn't wide enough to be a sleeper berth and shuts him down for violating his hours of service. 😎 Send him down my way. I love to hear drivers explain how they spent the night in a berth they don't have. Judging by how many people do it successfully, I guess maybe our police or laws are more reasonable out here? Dunno, not in the business so never paid attention other than just hearing about it. Quote Link to comment Share on other sites More sharing options...
Scrap Posted January 23, 2019 Report Share Posted January 23, 2019 If it has a Woodhouse kit to meet CFR393.76 you'd never notice it from the outside. It is all done inside the truck so what you see going down the road might still be legit. Hopefully that is the mattress/restraint kit this guy bought to put in? Quote Link to comment Share on other sites More sharing options...
Carlos Posted January 23, 2019 Report Share Posted January 23, 2019 I'm not sure if you're asking me, but I have no idea about any of that. He just bought an RV mattress from me and told me why. Quote Link to comment Share on other sites More sharing options...
Big5er Posted January 25, 2019 Report Share Posted January 25, 2019 On 1/23/2019 at 8:42 AM, Carlos said: Judging by how many people do it successfully, I guess maybe our police or laws are more reasonable out here? Dunno, not in the business so never paid attention other than just hearing about it. Since they are Federal regulations, the "law out here" isn't any more reasonable that in any other state. Since you are not in the business and "never paid attention" I'm betting that means you really have no idea how reasonably your officers enforce that violation. Scrap, I've seen 2 converted back seats in my career...compared to tons of bench seats with a mattress. Have you ever met anyone that actually met anyone that bought one? That aren't cheap...well a couple of grand anyway. And even then, it's still fairly cramped...especially with some thing to haul clothes and stuff in. I think I'd go nuts moving stuff around to get enough room to get into the "bed" every night. Quote Link to comment Share on other sites More sharing options...
Steveoreno Posted January 25, 2019 Report Share Posted January 25, 2019 On 1/22/2019 at 7:05 PM, Big5er said: LOL, and he will try to log his off duty time as "sleeper berth" until he runs into that nasty DOT cop who shows him that his back seat isn't wide enough to be a sleeper berth and shuts him down for violating his hours of service. 😎 Send him down my way. I love to hear drivers explain how they spent the night in a berth they don't have. I have seen 2 different companies that make a retro fit kit to make a crew cab DOT sleeper compliant. The windows are up and fixed in place and all the window guts are removed and inner door skin cut ot. the a little pan is added and then it has a funky safety net thingy that also meets the other part of DOT. Looks uncomfortable. I really dont understand the hot shot truck industry. any trailer worth pulling is over 10k which means class A license. If going that route then why not a real working truck. Quote Link to comment Share on other sites More sharing options...
Scrap Posted January 26, 2019 Report Share Posted January 26, 2019 Yea Big5er the one guy I got caught up with was raising hell at the parts counter claiming they gave him a mis-made bunk restraint. Went out to look at his truck and turns out it is our upper bunk restraint that is used but made to different dimensions. He wasn't a real happy feller in general, and me and the Pumas and headsets guys don't click too well either, so poked around his truck for a bit and that was about it. Losing your passenger seat has got to be the part that sucks the most. A few years ago when making the crew cab vs 40" sleeper decision the market research guys brought a bunch of the crewcab guys in. No trucks but they had to bring a binder/powerpoint explaining their operation and pics of their (legit) conversion. It seemed like there were a whole bunch of them out there but it was a targeted go-find-em deal and they probably had every legit one in the country in one small room....😏 Anyways, $1.00 per mile operating cost is still the main target, just like it has always been. Getting harder and harder every year... Quote Link to comment Share on other sites More sharing options...
