johnschnee Posted November 12, 2018 Report Share Posted November 12, 2018 We've been camping in a Class "A" for 6 years now, but this is the first time we've had to winterize our rig (always keep it stored or in use waaaaay down South) & am wondering - besides the obvious step of "running a whole bunch of city water through everything" are there any other steps I need to take to ensure that my DW doesn't taste or even think about any anti-freeze residue that might be left behind? I'm thinking maybe it would be a good idea to put some water in my fresh water holding tank & add some of those "fresh water freshener" products & then run that through? I also plan to sanitize my entire water system as soon as possible after getting my rig out of storage. Mostly I'm worried about the ice maker - any thoughts? Link to comment Share on other sites More sharing options...
wrenchhead30 Posted November 12, 2018 Report Share Posted November 12, 2018 I run apple cider vinegar through the system and put a gallon in the fresh water tank then run that through then follow up with some water it cleans out your lines and sanitizes the tank. it may taste a little like apples for a bit but its better than antifreeze 1992 Peterbilt 379 cummins N14(under construction) 2003 dodge ram 3500 4wd crewcab dually cummins 5.9 2012 heartland 40' big country 5th wheel Home base Moody, Texas Link to comment Share on other sites More sharing options...
Kirk W Posted November 12, 2018 Report Share Posted November 12, 2018 To remove odor and taste mix 1/2 cup of baking soda with a gallon of water and add that to your fresh water tank. Fill the tank and then run the mix through your water system. Let it stand for an hour or two and then drain the system and fill with fresh water. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Lance A Lott Posted November 12, 2018 Report Share Posted November 12, 2018 I only put the antifreeze in my fresh tank once. Since then I use a bypass and only put it in the pipes. I drain the fresh tank, my drain is on the front so I back it up a hill to get as much out as possible. Done this for 25 years no problems. I live in Vermont so it freezes hard and stays that way. Link to comment Share on other sites More sharing options...
OregonJim Posted November 12, 2018 Report Share Posted November 12, 2018 On your first trip, offer to cook the first meal. Use plenty of tabasco and jalapeno. By the time she is able to taste the water again, it will be nice and fresh. Seriously though, my DW worries about the same thing. I always used a bit of chlorine bleach, but I might try the baking soda idea next time. Link to comment Share on other sites More sharing options...
Ray,IN Posted November 13, 2018 Report Share Posted November 13, 2018 NEVER put anti-freeze of any type into your fresh water tank, what little water remains in the tank after draining is of no consequence, same for the water heater. The Vinegar recommendation is valid, for the reasons assigned. There are many utube videos of how to winterize a MH, just keep my first paragraph in mind. One method of winterizing has little aftertaste, use cheap vodka. If DW doesn't like that taste_ enjoy the de-winterizing process by yourself. 🤭 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Darryl&Rita Posted November 13, 2018 Report Share Posted November 13, 2018 Avoid the taste, use air. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Dodgeguy Posted November 13, 2018 Report Share Posted November 13, 2018 I also use air at about 35 psi. Don't forget the toilet valve. That one is a tough one to change when it breaks. I'm going to try apple cider vinegar for sterilisation. Sounds like its better tasting than bleach. Thanks wrenchhead30. Link to comment Share on other sites More sharing options...
Kirk W Posted November 13, 2018 Report Share Posted November 13, 2018 20 minutes ago, Dodgeguy said: I'm going to try apple cider vinegar for sterilisation. Sounds like its better tasting than bleach. Welcome to the Escapee forums! We are pleased to have you join us. I am skeptical of the ability of vinegar as a disinfectant but perhaps BarbOK will join in since she is our resident chemist. The following is a quote from Healthy Spaces: Quote Vinegar can be used as a safer bleach alternative for some applications, like cleaning. It is also biodegradable. However, vinegar is not a registered disinfectant and does not kill dangerous bacteria like staphylococcus. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Second Chance Posted November 13, 2018 Report Share Posted November 13, 2018 13 hours ago, Darryl&Rita said: Avoid the taste, use air. X2^^. Rob 2012 F350 CC LB DRW 6.7 2020 Solitude 310GK-R, MORryde IS, disc brakes, solar, DP windows Full-time since 8/2015 Link to comment Share on other sites More sharing options...
JimK Posted November 14, 2018 Report Share Posted November 14, 2018 Don't worry about any residual antifreeze. After you drain the lines and tank, it will be time to sanitize with a load of bleach. I don't have any issues with either antifreeze or bleach residue. My tank drains to virtually empty and then I refill and drain at least once, often twice. Link to comment Share on other sites More sharing options...
johnschnee Posted November 15, 2018 Author Report Share Posted November 15, 2018 All, Appreciate all the great advise offered here: sweetie seems a little leery about the ideas involving apple cider vinegar, tabasco or cheap vodka, so likely I'll try the one involving baking soda! 🙂 Thanks again! Link to comment Share on other sites More sharing options...
Lance A Lott Posted November 15, 2018 Report Share Posted November 15, 2018 After I learned my lesson to not put the antizee in the fresh tank cleaning up in the spring is just a mater of running fresh water until the pipes are clear I usually use the shore hookup first then put some in the tank, drain the tank and good to go. I have had more trouble with smell after using the camper and letting it sit for a week or two before using again. Link to comment Share on other sites More sharing options...
bigjim Posted November 15, 2018 Report Share Posted November 15, 2018 2 hours ago, johnschnee said: vinegar, don't dismiss vinegar out of hand. I use regular cheap white vinegar to eliminate some tastes and smells. It rinses out pretty easy to get rid of the vinegar taste and smell. I just used it on a small container about an hour ago. I like the idea of the apple cider vinegar but I am to cheap to use it much. I have used it on some really small containers. I use it a good bit to deal with calcium deposits on surfaces. I am in areas where this is a big problem for extended periods. Link to comment Share on other sites More sharing options...
