strawdog Posted August 25, 2018 Author Report Share Posted August 25, 2018 37 minutes ago, HERO Maker said: So Dave, as you said, " Result - #4 injector driver fails under high heat conditions then recovers when cooled down. " Is that driver inside the ECM? And is it more of a programming issue, not hardware? The driver is inside the ecm. The exact failure report was - "*Typical Injector Timing Chip Failure Due To Age". The testing procedure was to hook the ECM up to a test fixture, place the ECM on a hot plate, heat it up and monitor for error codes. Once the error code appeared the driver chip was cooled down locally and error code went away. A similar on the road test would have been to drive the truck until the error code was solid then pack the ECM with ice and see if the error code went away….. But much less precise. Dave Dave, Renee & furkids Casey & Miss Kitty 1998 Volvo 610 Straight 10 "Leather n' Lace"; Herrin bed w/Rampage motorcycle lift; 2010 40' New Horizons Majestic; 2008 Harley FLSTC; 2006 Jeep Wrangler Unlimited; 1999 Yamaha 4X4 Kodiak (that is NOT with us!) Link to comment Share on other sites More sharing options...
HERO Maker Posted August 25, 2018 Report Share Posted August 25, 2018 Thanks Dave. Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
bags Posted August 28, 2018 Report Share Posted August 28, 2018 On 7/9/2018 at 11:04 AM, strawdog said: Hmmmm... working on that now, all are a little low, 12.41,12.41, 12.42, and 12.41. going to charge them up one at and a time and check after sitting for awhile... Dave I bet it is your alternator. 12.40ish is to low. Should be 13.5 0r above. John and Michal Bagley 1999 Volvo 610 the 'Millennium Falcon', 400 hp ISM, Autoshift Gen 2, single axel w/steel bed, Pressure Pro, VMSPC, Trailer Saver Air Hitch, 3 bags, 38 foot Royals International, and our 3 dogs. Link to comment Share on other sites More sharing options...
strawdog Posted August 29, 2018 Author Report Share Posted August 29, 2018 On 8/27/2018 at 9:05 PM, bags said: I bet it is your alternator. 12.40ish is to low. Should be 13.5 0r above. Nope, alternator is fine, truck had just been sitting awhile with laptop gps etc plugged in and batts were a little low. Charged them individually and let them sit for 48 hrs, held 12.8v. Dave Dave, Renee & furkids Casey & Miss Kitty 1998 Volvo 610 Straight 10 "Leather n' Lace"; Herrin bed w/Rampage motorcycle lift; 2010 40' New Horizons Majestic; 2008 Harley FLSTC; 2006 Jeep Wrangler Unlimited; 1999 Yamaha 4X4 Kodiak (that is NOT with us!) Link to comment Share on other sites More sharing options...
