runaway parents Posted May 30, 2018 Report Share Posted May 30, 2018 Well it finally caught up with me . Broke a fuel tank strap rusted threw underneath cat walk. Must be karma after giving Vegas Teacher a bad time for hiring someone to break his nuts loose. Anybody have a good sores for a replacement strap for a 08 780? Link to comment Share on other sites More sharing options...
JPL Posted May 31, 2018 Report Share Posted May 31, 2018 RP I don't know where you are but I would ck the used truck yards. Are You close to Richmond Va. or Roanoke Va? Best I can Do! Good luck There is one out there with your name on it. You just have to find it. Pat The Old Sailor Link to comment Share on other sites More sharing options...
jenandjon Posted May 31, 2018 Report Share Posted May 31, 2018 It may not look the best but you can wrap a ratchet strap around it to get you home. Completely legal. Call these guys. https://www.vanderhaags.com/index.php Link to comment Share on other sites More sharing options...
Sehc Posted May 31, 2018 Report Share Posted May 31, 2018 I had that problem. Like Jenandjon, I used a ratcheting strap I bought at a Flying J. It was more permanent than I planed and was still going after three years. Link to comment Share on other sites More sharing options...
rickeieio Posted May 31, 2018 Report Share Posted May 31, 2018 Last year I had one break on our Mack. Of course, I had just filled the tanks. I got a new set, as they were all the same age so why replace one just to have another fail shortly? In removing the straps and cleaning the old isolator padding off the tanks, I found a leak in one tank. Had to drain it and take it to the welding shop for a patch. The fun just never ends............... Link to comment Share on other sites More sharing options...
VegasFlyer Posted May 31, 2018 Report Share Posted May 31, 2018 While prepping our truck for POR-15, we found a broken tank strap and replaced it. For a new one, we found the best price to be the dealer at 157.00. you need to assess the rubber welting to determine whether it can be reused. New welting is not cheap. Link to comment Share on other sites More sharing options...
VegasFlyer Posted May 31, 2018 Report Share Posted May 31, 2018 And VegasTeacher can probably hook you up with the mechanic......lol By the time you wrestle the strap around under your truck, you will wish you hired the guy....It was like wrestling a fat girl for the last piece of pizza.. Link to comment Share on other sites More sharing options...
Wrknrvr Posted May 31, 2018 Report Share Posted May 31, 2018 I had one that rusted through several years ago. So I rebuilt that side under the fiberglass . Removed one strap at a time. Welded a repair on the old stap. The bottom foot support was rusted away. Made one out of 1/4" angle iron. Made sure all other brackets, braces and such were in good shape cleaned ,treated and painted. Not a fun job. While I had it apart the fiberglass panels were repair and painted. Sorta fun to do, . But looks much better. So I may take the drivers side apart this summer Safe Travel,. Vern Link to comment Share on other sites More sharing options...
runaway parents Posted May 31, 2018 Author Report Share Posted May 31, 2018 3 hours ago, VegasFlyer said: And VegasTeacher can probably hook you up with the mechanic......lol By the time you wrestle the strap around under your truck, you will wish you hired the guy....It was like wrestling a fat girl for the last piece of pizza.. Yep your right demo was the worst part lots of rusted bolts.Tthink I got lucky only broke off one bolt. Link to comment Share on other sites More sharing options...
Parrformance Posted May 31, 2018 Report Share Posted May 31, 2018 5 hours ago, VegasFlyer said: While prepping our truck for POR-15, we found a broken tank strap and replaced it. For a new one, we found the best price to be the dealer at 157.00. you need to assess the rubber welting to determine whether it can be reused. New welting is not cheap. Good used tire carcass could be used for welting, I imagine. They litter the highway's, stop and pick some up. Link to comment Share on other sites More sharing options...
VegasFlyer Posted June 1, 2018 Report Share Posted June 1, 2018 10 hours ago, Parrformance said: Good used tire carcass could be used for welting, I imagine. They litter the highway's, stop and pick some up. I would classify that idea as,”looks good on paper”. The straps come straight and tend to like it that way. As you wrestle it around the tank, between the mounting brackets for fairings, etc, the last thing you will need to deal with, would be pieces of tire tread. If you are careful taking off the old welting and clean it up, it can be reattached to the new strap and raps around the edges and stays in place. Link to comment Share on other sites More sharing options...
runaway parents Posted June 1, 2018 Author Report Share Posted June 1, 2018 Found a tank strap in Spokane yesterday morning at spaldings auto wrecking heavy truck division. Went out side to see DW off to work at 5:30 this morning. Found new used part sitting in drive way next to the truck. This thing traveled 150 miles in less than 24 hours . They not only sent me the strap they sent me every thing from the frame out bolts pins rubber insulator mounting brackets for faring and steps Do not recall putting over night shipping on this. But I am definitely not complaining. Way to go Spaldings. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted June 1, 2018 Report Share Posted June 1, 2018 6 hours ago, VegasFlyer said: I would classify that idea as,”looks good on paper”. The straps come straight and tend to like it that way. As you wrestle it around the tank, between the mounting brackets for fairings, etc, the last thing you will need to deal with, would be pieces of tire tread. If you are careful taking off the old welting and clean it up, it can be reattached to the new strap and raps around the edges and stays in place. Never mind the stress that fuel sloshing around in the tank causes. Plain rubber is only a temporary fix. The real rubber locks on the straps for a reason. Link to comment Share on other sites More sharing options...
Parrformance Posted June 1, 2018 Report Share Posted June 1, 2018 7 hours ago, VegasFlyer said: I would classify that idea as,”looks good on paper”. The straps come straight and tend to like it that way. As you wrestle it around the tank, between the mounting brackets for fairings, etc, the last thing you will need to deal with, would be pieces of tire tread. If you are careful taking off the old welting and clean it up, it can be reattached to the new strap and raps around the edges and stays in place. I personally use my old bicycle tires from my road bike and mountain bike for abrasion resistance needs. The tires I use have Kevlar beads and are very durable, and look like the rubber used under the straps of the tanks. Oh and they are already round, with a safety bead to keep them in place:). Link to comment Share on other sites More sharing options...
noteven Posted June 1, 2018 Report Share Posted June 1, 2018 Woo hoo! Finally a use for my old tires...! i roared out and looked at the tanks on my 20 yr old KW... but the factory rubber ones are still ok. Oh well... 😎 Link to comment Share on other sites More sharing options...
Scrap Posted June 2, 2018 Report Share Posted June 2, 2018 What? A Canadian without wrinkled tank rubbers? So anyways what happens when a strap on a hanging tank like this breaks? Do you have to jack the tank back into place? Does it bend up the other strap? Does it just bolt back in or is it a major pain? Tank doesn't get worn or punctured? Kind of sounds like a non-event if your pre-trip catches it? We've sold against hanging tank trucks for so long that by now I figured a broken strap would be an Atomic Fireball with some Valdez Jr on the side... Link to comment Share on other sites More sharing options...
noteven Posted June 2, 2018 Report Share Posted June 2, 2018 I usta spec 7” wide hanging style quite a bit to reduce wear on the bottom of tanks from gravel striking the tank bracket style mounts when people don’t install or maintain “stone protection” aka mud flaps. Like lotsa stuff on KW’s can’t remember one of them breaking. Once in a while a roller skate car would vector into someone’s fuel tank and straps would go out of parts dept for accident repair. Link to comment Share on other sites More sharing options...
runaway parents Posted June 2, 2018 Author Report Share Posted June 2, 2018 7 hours ago, Scrap said: What? A Canadian without wrinkled tank rubbers? So anyways what happens when a strap on a hanging tank like this breaks? Do you have to jack the tank back into place? Does it bend up the other strap? Does it just bolt back in or is it a major pain? Tank doesn't get worn or punctured? Kind of sounds like a non-event if your pre-trip catches it? We've sold against hanging tank trucks for so long that by now I figured a broken strap would be an Atomic Fireball with some Valdez Jr on the side... Well any way when tank strap broke not much happened with the tank. There is two other straps on this tank . There was very little movement at all. But the faring steps and cat walk is attached to this strap they all moved. Installed new strap. Every thing pulled back together. No jacking involved. The reason it broke it was rusted threw up underneath the cat walk. Pre trip would not have caught it unless cat walk was removed. As far as being a pain fixing broke bolts rethreading removing rusted bolts all take time Link to comment Share on other sites More sharing options...
