jcsteele Posted May 15, 2018 Report Share Posted May 15, 2018 The inevitable is starting to happen. My factory Binkley hitch head is starting to fail on my Trailer Saver.... Wasn’t there an updated one I could buy somewhere??? I looked on the ET site but didnt see anything. Link to comment Share on other sites More sharing options...
Av8r3400 Posted May 15, 2018 Report Share Posted May 15, 2018 Henry is making the components, I don't think they are on the website, however. Give him a call. Av8r34002012 Volvo VNL 730 D13 iShift & 2021 Grand Design Momentum 397TH I'd rather die trying to live - Than live trying not to die. -Leonard Perry Link to comment Share on other sites More sharing options...
SuiteSuccess Posted May 15, 2018 Report Share Posted May 15, 2018 2 hours ago, jcsteele said: The inevitable is starting to happen. My factory Binkley hitch head is starting to fail on my Trailer Saver.... Wasn’t there an updated one I could buy somewhere??? I looked on the ET site but didnt see anything. What is failing? Jaws should never fail, block should be good. Pins will eventually get sloppy. The original Binkley is “non-serviceable “ if it’s the pins, although one of the forum members who is a damn good machinist serviced one for RandyA and made it better than the original. Maybe he will respond. Otherwise you have to purchase a new head. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
crazybanshee Posted May 16, 2018 Report Share Posted May 16, 2018 I just purchased a new head from Trailer Saver. $500 plus shipping. Old one was twelve years old. 2007 Volvo 780 Ultrashift Trailersaver Hitch 2017 Momentum 397th 3 Yamaha Banshees 2 Honda 400EX's Polaris Outlaw 50 Polaris Outlaw 110 EFi 2018 Polaris RZR S 1000 Stealth Black 2019 Polaris RZR S 1000 Titanium Matte Metal 2015 Polaris RZR S 900 VooDoo Blue https://i.imgur.com/e0ajU8Pl.jpg Link to comment Share on other sites More sharing options...
jcsteele Posted May 17, 2018 Author Report Share Posted May 17, 2018 I was hoping the super binkley could be purchased for it but it doesnt look like it. The swivel pins for the head are wearing drastically, which sounds like a common problem. I have been trying to attach pics but they are too big Link to comment Share on other sites More sharing options...
NeverEasy Posted May 17, 2018 Report Share Posted May 17, 2018 If you get it to me in Virginia Beach, I would be happy to attempt a fix. Cannot say if it is repairable until I take it apart and see. Not too hard after doing the first one for RandyA. I am not a Dr Pepper fan, I drink Diet Coke. You would have to buy about $30 worth of inch and a half 1045 rod about a foot long. I might even have enough left from Randy's hitch to do another one. There was a lot of discussion here: We will be leaving for Idaho on May 27th. Be back late June. Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
RandyA Posted May 17, 2018 Report Share Posted May 17, 2018 Chet (NeverEasy) has developed a method for replacing the pins. The replacement pins now have an outer shoulder and a retaining plate bolted onto the head that can be removed and replaced an infinite amount of times with individual exact fit pins. His replacements include grease fittings that work like suspension wet bolts, which are not on the originals. I am not under the impression that he is going to start a business doing the modification, but he did discuss and explain the process on a thread in late March so others might do the same. A good lathe, tools, micrometer and plasma cutter are needed. You can find the thread here. Chet is an extremely gifted man that has and knows how to use the machining tools in his shop. What I found unique in his rebuild was that he cut pin blanks from aluminum stock while constantly checking fit in the holes. On the head he did for me the pins are of different diameters compensating for wear. He then made steel pins the same diameter as the aluminum test pins once he got the fit he wanted. I just got the TSLB installed on the Volvo last week so I do not have any test mileage on the head he modified but have absolutely no doubt it will perform flawlessly. If my memory serves me well Henry's replacement Super Binkley head has the right plate for the Trailer Saver and can reuse the jaws and a couple of other parts from a Binkley and possibly save the customer a good chunk of change. Don't toss your old head, the jaws apparently have value. Like anything Henry builds, this new head will be virtually bulletproof and of the highest quality in materials and workmanship. If I were starting from scratch and could not repair my existing Binkley head I would put my money into Henry's replacement. IMHO, we are fortunate to have Henry's engineering expertise and passion for perfection building products for our RV HDT's. Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
NeverEasy Posted May 17, 2018 Report Share Posted May 17, 2018 Jcsteele, Jack posted a way to upload pictures. It works for me but things act a little strange on the first click to the link: I get a cookie error. I just click on the link again and it works. Just drag and drop a picture or search for one on your computer. Jack's instructions are here: Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
jcsteele Posted May 17, 2018 Author Report Share Posted May 17, 2018 37 minutes ago, NeverEasy said: If you get it to me in Virginia Beach, I would be happy to attempt a fix. Cannot say if it is repairable until I take it apart and see. Not too hard after doing the first one for RandyA. I am not a Dr Pepper fan, I drink Diet Coke. You would have to buy about $30 worth of inch and a half 1045 rod about a foot long. I might even have enough left from Randy's hitch to do another one. There was a lot of discussion here: We will be leaving for Idaho on May 27th. Be back late June. Dang! I am currently “home” in Central Oregon (5 hours from Caldwell, ID) and even going to Boise over memorial day.... too bad your shop isnt mobile!! I rarely get out to the east coast 😞 Link to comment Share on other sites More sharing options...
jcsteele Posted May 17, 2018 Author Report Share Posted May 17, 2018 So it appears to only be starting to fail on one side.... here is the bad side http:// and the “good” side. http:// that is white lithium grease in there... i didnt have anything else that would “spray” up in there... Link to comment Share on other sites More sharing options...
jcsteele Posted May 17, 2018 Author Report Share Posted May 17, 2018 I usually like to go the most frugal route but in this case i really have no time for down time.... is there a way to buy the super binkley already welded on the swivel base that goes in the trailer saver? I know I really need to call Henry.......... Lol Link to comment Share on other sites More sharing options...
Chad Heiser Posted May 17, 2018 Report Share Posted May 17, 2018 1 hour ago, jcsteele said: Dang! I am currently “home” in Central Oregon (5 hours from Caldwell, ID) and even going to Boise over memorial day.... too bad your shop isnt mobile!! I rarely get out to the east coast 😞 Your that close to Caldwell and your not coming to the WCR? 😧 You should come check it out. It’s going to be a good time. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
jcsteele Posted May 17, 2018 Author Report Share Posted May 17, 2018 10 hours ago, Chad Heiser said: Your that close to Caldwell and your not coming to the WCR? 😧 You should come check it out. It’s going to be a good time. I wish I had time 😞 Work takes me all over the place and usually on a very tight schedule. Link to comment Share on other sites More sharing options...
RandyA Posted May 17, 2018 Report Share Posted May 17, 2018 This is a photo from the right side of the retainer plate Chet used for holding the new pins in place. They can now be easily removed. Below: The pin in the foreground is the aluminum pin Chet made to determine exact fitment. The aluminum pin was reproduced in steel for the final assembly. The pin in the back is the OEM pin. Note the shoulder on the new pin that acts as a retainer. Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
phoenix2013 Posted May 17, 2018 Report Share Posted May 17, 2018 TraileSaver head and swiveler replacements are available from ET Hitches on an exchange basis (old Binkley and old swiveler being a core). It hasn't made the website yet. The head is a brand new Super Binkley (slightly smaller version of the Super Binkley), the swiveler is a TrailerSaver bottom modified to accept the Super Binkley (hence the need for the core). Link to comment Share on other sites More sharing options...
noteven Posted May 17, 2018 Report Share Posted May 17, 2018 Are the pins wearing in the Holland fifth wheel because it is mounted to the Trailer Saver air suspension - being in constant motion under tow conditions? "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
RandyA Posted May 18, 2018 Report Share Posted May 18, 2018 Quote Are the pins wearing in the Holland fifth wheel because it is mounted to the Trailer Saver air suspension - being in constant motion under tow conditions? 2 From what I can see on the Holland-Binkley head the main problem contributing to the wear is the way the pins were placed without any way to apply sufficent lubricant (non-serviceable according to Hensley). So, as you asked the wear in the pins would come from the forward and backward tilt of the head as one travels. The airbags "may" contribute to the movement but when you rotate steel against steel under the pressure or force on the pins without lubricant the wear is inevitable. I was beginning to see similar wear on the non-airbag Reese hitch head I was using prior to getting the parts to assemble a full Trailer Saver hitch from Dave and Chet. Since Chet has developed a modification to not only make replacement of the pins fairly easy they can also be lubricated by the same methods wet bolts are on a trailer suspension. Only time will tell but I expect that with proper maintenance the replaced pins will outlast me. Henry's new design of his "Super Binkley" head appears to have removed the non-serviceable limitation of the OEM head. Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
SuiteSuccess Posted May 18, 2018 Report Share Posted May 18, 2018 Randy or Chet, I know from GeorgiaHybrid that 1045 is strong steel but does the lube channel in the pin itself weaken the pin and add a point it could crack? Just wondering if a design change with the grease bathing the pin through a zert would be better. For example on Henry’s second picture an accessible zert in the tabs? Just a question for the experts. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
phoenix2013 Posted May 18, 2018 Report Share Posted May 18, 2018 1 hour ago, SuiteSuccess said: Randy or Chet, I know from GeorgiaHybrid that 1045 is strong steel but does the lube channel in the pin itself weaken the pin and add a point it could crack? Just wondering if a design change with the grease bathing the pin through a zert would be better. For example on Henry’s second picture an accessible zert in the tabs? Just a question for the experts. The pins on the Binkley see an awful lot of IMPACT! Up to 1/2G when things are new and most likely several Gs once wear causes for gaps to develop and the force vectors on the pins (up and down and forward and back) change from pressure forces to hammering forces. The pins see 1G force down of the pin weight constantly, so that's 3-6,000 pounds, but that's nothing compared to 1/2G forward and back on 20-25K trailer (10-12,500 pounds) and that can be a lot more (several Gs) once gaps develop and things travel through open space and then come to an instantaneous stop. That's why hammers work so well when you pound on something. Whatever force you apply to the hammer with you wrist is hundreds of times more when that hammer hits and comes to an abrupt stop. To mitigate things you need to spread the forces over a larger area. On the original Binkley the forces on the pins act on the vertical tabs only. Note that in my "modification" I enlarged that area significantly by welding in longer bushings. The inside of the bushings is lined with a high end non-greaseable composite bearing, that material can withstand pressure of 27,000 pounds per square inch, there are over 3 square inches of area in each bearing. Putting zerks in pins was my initial thought, but I had the same concern Carl has that once you drill grease alleys, particularly sideways to redirect the grease to the "areas of interest" what happens over the time with all that impact and shear forces. So the second thought I had to put zerks in the top of the ears and drive the grease down towards the pins. That required putting access holes in the top of the head and low profile zerks (head rotation clearance), etc., etc, lot of work. Hence my current "solution", chop the old ears off, re-weld new ones on with larger bushings and bearings. Re-utilize the old swiveler to hold the cost down and re-utilize the old jaws and block from the old Binkley again to hold the cost down. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted May 18, 2018 Report Share Posted May 18, 2018 39 minutes ago, phoenix2013 said: The pins on the Binkley see an awful lot of IMPACT! Up to 1/2G when things are new and most likely several Gs once wear causes for gaps to develop and the force vectors on the pins (up and down and forward and back) change from pressure forces to hammering forces. The pins see 1G force down of the pin weight constantly, so that's 3-6,000 pounds, but that's nothing compared to 1/2G forward and back on 20-25K trailer (10-12,500 pounds) and that can be a lot more (several Gs) once gaps develop and things travel through open space and then come to an instantaneous stop. That's why hammers work so well when you pound on something. Whatever force you apply to the hammer with you wrist is hundreds of times more when that hammer hits and comes to an abrupt stop. To mitigate things you need to spread the forces over a larger area. On the original Binkley the forces on the pins act on the vertical tabs only. Note that in my "modification" I enlarged that area significantly by welding in longer bushings. The inside of the bushings is lined with a high end non-greaseable composite bearing, that material can withstand pressure of 27,000 pounds per square inch, there are over 3 square inches of area in each bearing. Putting zerks in pins was my initial thought, but I had the same concern Carl has that once you drill grease alleys, particularly sideways to redirect the grease to the "areas of interest" what happens over the time with all that impact and shear forces. So the second thought I had to put zerks in the top of the ears and drive the grease down towards the pins. That required putting access holes in the top of the head and low profile zerks (head rotation clearance), etc., etc, lot of work. Hence my current "solution", chop the old ears off, re-weld new ones on with larger bushings and bearings. Re-utilize the old swiveler to hold the cost down and re-utilize the old jaws and block from the old Binkley again to hold the cost down. Thanks Henry. I’m slowly learning about sites of potential stress and failure. Now it gives some perspective to why in big projects welds are xrayed for defects and same with concrete. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
RandyA Posted May 18, 2018 Report Share Posted May 18, 2018 Nothing less than what I would expect from Henry's amazing engineering brain! Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
RandyA Posted May 18, 2018 Report Share Posted May 18, 2018 2 hours ago, SuiteSuccess said: Randy or Chet, I know from GeorgiaHybrid that 1045 is strong steel but does the lube channel in the pin itself weaken the pin and add a point it could crack? Just wondering if a design change with the grease bathing the pin through a zert would be better. For example on Henry’s second picture an accessible zert in the tabs? Just a question for the experts. I am not a metallurgist nor do I have the knowledge Henry does about "such things". My only claim to fame was being a straight A student in Physics many years ago. But, IMHO, I believe that there is a lessened chance of this happening than one would have with the hole cross drilled in the OEM pin that has a small retainer pin pressed in as the retainer. Now, if one neglects to keep the assembly greased I can see wear issues quickly returning. There is no doubt that Henry always builds a better mouse trap and it is a crying shame he is not the president of Lippert. But Chet has devised a way to circumvent the "non-servicable" component with something better than their original factory engineered design. The possibility of cracking cannot be tossed away, but the likelihood of it happening with a recreational fifth wheel in the weight class we (I, Chet or you) are towing is pretty darn small. I feel safer with Chet's design and mod than I would with the OEM pins. Yes, I would also like to have Henry's upgrade and perhaps one day I will. But, right now I am as happy as a pig in mud to have what I do and can't thank those enough that worked to see that I had a proper, safe hitch for the heavier trailer we bought after the fire that did not have the TrairAir airbag pin box. Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
phoenix2013 Posted May 18, 2018 Report Share Posted May 18, 2018 The reason I am "so smart" because I spent all my life listening to guys like Chet. Link to comment Share on other sites More sharing options...
rickeieio Posted May 18, 2018 Report Share Posted May 18, 2018 3 hours ago, phoenix2013 said: The reason I am "so smart" because I spent all my life listening to guys like Chet. Proving that you are "wise" as well. KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
dblr Posted May 18, 2018 Report Share Posted May 18, 2018 6 hours ago, phoenix2013 said: The reason I am "so smart" because I spent all my life listening to guys like Chet. Henry I have remembered some of your phrases when you did my hitch at the ECR and even applied one or two so I might be as "smart" but my dad always said listen and learn. 2017 River Stone Legacy 38MB 2001 T2000 Kenworth 2009 Smart Passion ET Junior hitch Link to comment Share on other sites More sharing options...
