Parrformance Posted May 12, 2018 Report Share Posted May 12, 2018 I believe I have damaged a sensor for the air tanks. In my zeal to stop air leaks, I have somehow caused the low air pressure buzzer and stop light to stay lit in my 06 Volvo 780. The upper guage is reading no air pressure, the lower guage is reading normally, just past the mid poimt of the sweep. Could I have damaged the sensor by back filling the air tank closest to the front of the truck with my garage air compressor? If this might be the case, where can I find the sending units? Can I swap connectors to test the sensors? Thank you in advance for the help, I will say the truck holds air like a champ now. Michael Link to comment Share on other sites More sharing options...
DesertMiner Posted May 12, 2018 Report Share Posted May 12, 2018 How did you pressurize the air tanks? Are you sure you have air in all of your tanks? Air pressure sensors are mounted on the cabin side pass thru behind the kick panels on firewall. I believe they are the same. So you could interchange them to troubleshoot. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 12, 2018 Report Share Posted May 12, 2018 Not familiar with your model truck. Most have an 1/8 " airline to the back of the gauge. The switch integrated with the gauge. Have you had the dash apart? Is the wire (tubing) connected? Did you dick around the sensor area? Wire (tubing) connected? Nothing you could do by pressuring the tank would cause the symptoms you describe. Link to comment Share on other sites More sharing options...
Parrformance Posted May 12, 2018 Author Report Share Posted May 12, 2018 I have had several things apart, the big thing I replaced was a "protection valve". I also had fittings on the tanks, off to rebuild them. The dash I have had apart, but not where the guages are. I found a leak behind the red knob for trailer brakes. Link to comment Share on other sites More sharing options...
Nigel Posted May 12, 2018 Report Share Posted May 12, 2018 The gauge is electric. On the inside of the fire wall where the pass thru connector is there are pressure sensors there. I had one go bad earlier this year but for the life of me I don’t remember how I figured which one it was. My truck is not here for me to refresh my mind but I suspect you could swap the connectors. Nigel Link to comment Share on other sites More sharing options...
DesertMiner Posted May 12, 2018 Report Share Posted May 12, 2018 46 minutes ago, DesertMiner said: How did you pressurize the air tanks? Are you sure you have air in all of your tanks? Air pressure sensors are mounted on the cabin side pass thru behind the kick panels on firewall. I believe they are the same. So you could interchange them to troubleshoot. Air in tanks? Link to comment Share on other sites More sharing options...
Parrformance Posted May 12, 2018 Author Report Share Posted May 12, 2018 All three tanks do have air it seems Link to comment Share on other sites More sharing options...
Parrformance Posted May 12, 2018 Author Report Share Posted May 12, 2018 I bypassed a line in the pass thru, to fix a leak. Would this have caused it? Link to comment Share on other sites More sharing options...
Parrformance Posted May 12, 2018 Author Report Share Posted May 12, 2018 Looks like this may be it. Link to comment Share on other sites More sharing options...
DesertMiner Posted May 12, 2018 Report Share Posted May 12, 2018 30 minutes ago, Parrformance said: I bypassed a line in the pass thru, to fix a leak. Would this have caused it? Link to comment Share on other sites More sharing options...
Parrformance Posted May 12, 2018 Author Report Share Posted May 12, 2018 Looks like we have a winner, Nigel... Thank you for the heads up on the location of the pressure sensors. I knew it was something I did, but I was having tunnel vision with the pressure protection valve. I thought for sure that I had crossed an airline up. Soon as you mentioned the passtrough, I realized the problem must be there. One of the former owners "fixed" the leaky passtrough and the pressure protection valve, by coating them in epoxy. I tried to stop a significant leak, but could not get the airline out, it was completely epoxied to the collet and passtrough assembly. This of course had the pressure sensor plugged into the leg connected to the line on the opposite side. I will order the new passtrough and swap it next week. Thank you Link to comment Share on other sites More sharing options...
Parrformance Posted May 13, 2018 Author Report Share Posted May 13, 2018 Desert Miner, I must have missed your edit, I caused the problem trying to fix a leak on the passthrough. I ordered a new one, should be here by midweek. Thanks Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 13, 2018 Report Share Posted May 13, 2018 And I quote " what did u dick around with "? Ok, more of a paraphrase. Link to comment Share on other sites More sharing options...
Parrformance Posted May 13, 2018 Author Report Share Posted May 13, 2018 Absolutly, I knew I did it, just couldn't figure out what I did. I knew it was sensor related, just had no idea where the sensors were. I have been chasing leaks for three days, air tanks rear bags, leveling valves, dash valve, foot valve, small line on passenger side the egr pipes and passtrough assembly. Just did way too much, and couldn't figure where I screwed up. I felt so much better after the help from everyone got me on the right track to fix it, and the cold beer helped too. Link to comment Share on other sites More sharing options...
DesertMiner Posted May 13, 2018 Report Share Posted May 13, 2018 Watch out ...pass thru part numbers have changed and they are configured differently....try to order the "same" part number you have installed and take pictures before you change it out! Link to comment Share on other sites More sharing options...
Parrformance Posted May 13, 2018 Author Report Share Posted May 13, 2018 10-4 Caught a great YouTube video on the update unit 22646187, seems as though they have marked all the fittings. I have taken 15 pictures, of each side, and thinking a short video might not hurt. The new unit has the fittings as a true pass-through with the pressure sensors for each on a regular "T" right next to the cooresponding hose. No more offcentered sensor location on a different area of the unit. The write up by Suite Success is a great source of help as well, When I screwd up, I was dead tired from working too long on the truck (my fault), I needed to step back and figure out what I did. I should have quit for the day before I tried to fix "the last leak". Thankfully, I often do board repair and replacements with my fulltime job. Thank you all for the advice, "I just needed direction" to clear up the fatigue induce brain fog I was in yesterday afternoon. Michael Link to comment Share on other sites More sharing options...
Moresmoke Posted May 13, 2018 Report Share Posted May 13, 2018 Parrformance, when you get done with yours, you can head over here. I've got the air leaks down to where I can't hear any, and I have a couple pounds of air the next morning. Going to be good enough for now. 12 days until we leave on the big trip of the year, finding more leaks will have to wait. Link to comment Share on other sites More sharing options...
Parrformance Posted May 13, 2018 Author Report Share Posted May 13, 2018 Moresmoke, got to say that is tempting, we look forward to heading west soon. I suspect we will do 4 week trip next summer. I can't hear any leaks anymore either, but rear bags were still down this am. I hope to find more leaks and repair them before we go to Tennessee and Kentucky in late June. The truck should still hold air for an overnight stop at least. I drew detailed maps of both sides of the pass thru this morning, and labeled all conections in the cab and under the hood. I used labels where I could and color coded zip ties where the labels would be too large. Now I just need to weight for the part to arrive from Hollywood Florida, if sellers ships Monday, I should have by Wednesday, I am in Central Florida. One not, I use Snap-On racheting screw drivers, expensive but worth it. I was able to break all the Torx 27 fasteners loose with my long shank screw driver and bit, even the one hidden to the driver side of the ECM wire bundle, without removing the connectors or lines. Michael Link to comment Share on other sites More sharing options...
