MilesAndSmiles Posted January 5, 2018 Report Share Posted January 5, 2018 We are camping in Florida, and even here we are having sub-freezing nights. We noticed water seeping onto the floor from under the refrigerator. I checked outside and the evaporation pan was full to overflowing. I wonder if the cold weather is a factor in this problem? If so, would it help to switch from electric mode to propane mode overnight, which would generate some heat in the refrigerator compartment outside? Any other suggestions? Quote Link to comment Share on other sites More sharing options...
Dutch_12078 Posted January 5, 2018 Report Share Posted January 5, 2018 Many of us move the drain hose from the pan to the outside by running it through the vent a couple of inches. Quote Link to comment Share on other sites More sharing options...
ALLOY Posted January 5, 2018 Report Share Posted January 5, 2018 Maybe with the cooler temp people are inside more opening the fridge which allows more moisture into the fridge. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted January 5, 2018 Report Share Posted January 5, 2018 4 hours ago, MilesAndSmiles said: I wonder if the cold weather is a factor in this problem? If so, would it help to switch from electric mode to propane mode overnight, which would generate some heat in the refrigerator compartment outside? I highly suspect that you are correct about the cause. That hose only gets a few drops of water at a time under normal circumstances and most likely it has frozen those drops until the hose was completely blocked. I highly doubt that changing energy sources would do much for you but it probably would help to move that hose as Dutch has suggested preventing that drain pan from filling up, and then I also suggest that you put a drop light with an incandescent bulb into the back of the refrigerator as well, just to be sure that the hose does not freeze up. Quote Link to comment Share on other sites More sharing options...
MilesAndSmiles Posted January 6, 2018 Author Report Share Posted January 6, 2018 Thanks for the great suggestions. I'm glad to say the floor is dry this morning, and the temp is going up again tomorrow. Quote Link to comment Share on other sites More sharing options...
