NoDirectionHome Posted December 30, 2017 Report Share Posted December 30, 2017 I'd like to collect some thoughts about pluses & minuses. I'm currently leaning towards lateral and two stage (or two plane) as some call it. Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted December 31, 2017 Report Share Posted December 31, 2017 (edited) Carefree's Mirage is the strongest, most durable lateral arm box awning available - IF one is to believe their advertising. This type awing seems to be most often used on new MH's with starboard slide rooms. My objection to using one is the lack of a tilt feature to block evening/morning sunlight. Guess that's why I still like my old manual Carefree awning, which may be lowered to within 5' of the ground.(no starboard slide) Edited December 31, 2017 by Ray,IN Quote Link to comment Share on other sites More sharing options...
Chad Heiser Posted December 31, 2017 Report Share Posted December 31, 2017 4 hours ago, Ray,IN said: My objection to using one is the lack of a tilt feature to block evening/morning sunlight. Guess that's why I still like my old manual Carefree awning, which may be lowered to within 5' of the ground.(no starboard slide) The link you provided says that awning has 30” of pitch adjustment. Quote Link to comment Share on other sites More sharing options...
NoDirectionHome Posted December 31, 2017 Author Report Share Posted December 31, 2017 There is so little information on the websites for such high dollar products. I was looking at this Girard https://cdn.shopify.com/s/files/1/1069/3350/files/AK._Nova_II_Installation_Manual.pdf?5433730594210278951 and the Zip Dee Century 2 http://www.awningsbyzipdee.com/century-automatic-awning.html Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted January 1, 2018 Report Share Posted January 1, 2018 20 hours ago, Chad Heiser said: The link you provided says that awning has 30” of pitch adjustment. Good catch, however it states 30" instead of 30*. Quote Link to comment Share on other sites More sharing options...
Pat & Pete Posted January 1, 2018 Report Share Posted January 1, 2018 50 minutes ago, Ray,IN said: Good catch, however it states 30" instead of 30*. Ray , what does 30 stars mean ? LOL If you want the degree sign , press Alt + 0176 . That will give you ° . Quote Link to comment Share on other sites More sharing options...
Barbaraok Posted January 1, 2018 Report Share Posted January 1, 2018 (edited) On a Mac it is option, shift, 8 for ° and option 4 gets ¢ Edited January 1, 2018 by Barbaraok Quote Link to comment Share on other sites More sharing options...
Yarome Posted January 1, 2018 Report Share Posted January 1, 2018 I've been visiting back on this thread because I am also quite interested in the pros and cons of the two. I can see where a lateral is going to help get the support arm up out of the way, but I wonder about the stability and suseptability to winds. With fewer moving parts I could also maybe see them being a bit more maintanence free for that reason (?). It doesn't appear that tilting or doing a rain dump is any issue. I mounted awning pole brackets and poles that retract and secure against the side of my rig during travel. Mainly so I don't have to worry if winds pick up a bit (the brackets also has holes for tiedowns), but I would also wonder if the laterals have enough front edge support for a similar system. Curious minds want to know.... Quote Link to comment Share on other sites More sharing options...
NoDirectionHome Posted January 1, 2018 Author Report Share Posted January 1, 2018 I'm right in line with your thoughts Yarome. I imagine multiple head strikes with the vertical supports, but the stability is and issue (maybe). I was thinking a pair of telescoping poles in that case would still be a better occasional solution. The auto-retract sensitivity is adjustable. On the Irv2 forum and as seen on most high end motorhome's the Girard seems to be the awning of choice for function and customer service. At $6K each (20') and I need two of them, I don't want any regrets. Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted January 2, 2018 Report Share Posted January 2, 2018 (edited) 22 hours ago, Pat & Pete said: Ray , what does 30 stars mean ? LOL If you want the degree sign , press Alt + 0176 . That will give you ° . 30° HaH! finally got it. I was using the numbers at the top of the kyeboard, but the numbers on the right side of the keyboard must be used. Remember, a computer is only as smart as the operator. Only the right Alt key works with Alt+248. Now to discover how to create a shortcut for ° Thanks for the lesson. Edited January 2, 2018 by Ray,IN Quote Link to comment Share on other sites More sharing options...
Pat & Pete Posted January 2, 2018 Report Share Posted January 2, 2018 1 hour ago, Ray,IN said: 30° HaH! finally got it. I was using the numbers at the top of the kyeboard, but the numbers on the right side of the keyboard must be used. Remember, a computer is only as smart as the operator. Only the right Alt key works with Alt+248. Now to discover how to create a shortcut for ° Thanks for the lesson. Belated Merry Christmas . I learn new to me stuff fairly often . I know I don't use but a fraction of what my machine is capable of . Quote Link to comment Share on other sites More sharing options...
