Jeff.Sloan Posted September 17, 2017 Report Share Posted September 17, 2017 I need to replace this air release valve on my forward dry tank. Mine has been sticking and put us on the side of the road twice lately. I can't find any info on it. Anyone know what it is called and if it is a dealer only item or aftermarket as well. Crazy small pic of it to fit under the 0.1MB limit: TIA Jeff 2004 Volvo 630, Cummins ISX, Eaton 10 speed (air assist clutch), 3.71 3.07 rear locker, ET jr, 200" WB, GearMaster 2017 Forest River Sierra 372LOK Full time June 2017 DW, 2 kids, and 2 dogs Link to comment Share on other sites More sharing options...
MrSeas Posted September 17, 2017 Report Share Posted September 17, 2017 Is that located on the back side of your "wet tank" ? Do you have a "manual" moisture release valve on that tank? Could it be a some type of a "automatic" moisture release valve? http://www.plazafleetparts.com/uploads/2/1/9/0/2190100/dv-2_drain_valve_installation.pdf http://www.eriksmilitarysurplus.com/airreaumoejv.html Link to comment Share on other sites More sharing options...
Jeff.Sloan Posted September 17, 2017 Author Report Share Posted September 17, 2017 It's the center of the three tanks. I thought the front one was the wet tank, but I guess I'm not sure. It has wires coming off of it, I assume they run up into the harness somewhere. I will crawl back under tomorrow and take some more pics :-) EDIT: Read those links you posted MrSeas. Thanks. That sure looks like what it is. I'll still take photos tomorrow but thanks a bunch for the leads! 2004 Volvo 630, Cummins ISX, Eaton 10 speed (air assist clutch), 3.71 3.07 rear locker, ET jr, 200" WB, GearMaster 2017 Forest River Sierra 372LOK Full time June 2017 DW, 2 kids, and 2 dogs Link to comment Share on other sites More sharing options...
ray.service Posted September 17, 2017 Report Share Posted September 17, 2017 That's an automatic drain. The wires are for a heater so it doesn't freeze in winter and prevent draining. Not it has a petcock so can be drained manually. IIFC it works on pressure like a relief valve so it cycles. It can be totally removed and replaced by manual valve but then you have to crawl under to drain. You can't used the front of the wet tank because it has a small built in "ping" tank for the dryer regen. Also that should be on the front "wet" tank. The primary and secondary tanks have drain valves on the outside that have to be manually drained during pre-trip. Ray & Deb - Shelbi the Aussie & Lexington the cat2004 Volvo 630 500HP ISX "Bertha D" - 10 Speed-MaxBrake -ET hitch.SOLD2009 Designer 35RLSA SOLDFulltiming since '07 - stopped 2016 Link to comment Share on other sites More sharing options...
noteven Posted September 17, 2017 Report Share Posted September 17, 2017 Stop by a Kenworth dealer and buy a manual drain valve with a cable lanyard that can be routed for convenient air tank draining. "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Jeff.Sloan Posted September 17, 2017 Author Report Share Posted September 17, 2017 Well I was wrong. It is on the wet (front) tank. Has an airline coming out of the top. I think this is it: http://www.eriksmilitarysurplus.com/airreaumoejv5.html The wires to it looked very OEM, so I looked on the build sheet for my truck and it was an factory accessory: "UW-A1 Automatic Air Tank Drain Valve $56" Very cool. will be ordering a new one up tonight! Thanks everyone :-) 2004 Volvo 630, Cummins ISX, Eaton 10 speed (air assist clutch), 3.71 3.07 rear locker, ET jr, 200" WB, GearMaster 2017 Forest River Sierra 372LOK Full time June 2017 DW, 2 kids, and 2 dogs Link to comment Share on other sites More sharing options...
