colomtns Posted February 25, 2017 Report Share Posted February 25, 2017 I am looking to buy a used motorhome. One of the units I am looking at does not have leveling jacks. I know from my experience with a truck camper that the refrigerator did not work properly when the unit wasn't level plus it just felt uncomfortable. How do you level a motorhome that does not have leveling jacks? By the way I would be staying at places ranging KOA campground to boondocking. Thanks Lew Link to comment Share on other sites More sharing options...
budeneighe Posted February 25, 2017 Report Share Posted February 25, 2017 I used 2x6" scraps to add under the tires. ***** Be sure to always support both tires on a dual set, otherwise, you will overload and compromise the internal integrity of the single tire carrying the load and it will peel tread or blow out sometime later. I used this method on both 24' and 27' class A Winnebagos. Link to comment Share on other sites More sharing options...
Clay L Posted February 25, 2017 Report Share Posted February 25, 2017 My first motor home did not have leveling jacks either. I carried 5 bags of 10 each Lynx leggo type leveling blocks. Even after the first year when I bought a new motor home that did have jacks I still had to use them sometimes and would crack one every year or so. I just considered it a cost of the lifestyle and replaced them as needed. I did not want the weight of wood and really did not have the space to store wood strips/blocks anyway. Link to comment Share on other sites More sharing options...
Kirk W Posted February 26, 2017 Report Share Posted February 26, 2017 Our first motorhome had no leveling jacks either and I used a series of 2X8 planks with a beveled leading edge. I always kept about 10 of them in varying lengths from about 2' to 4'. Link to comment Share on other sites More sharing options...
Pat & Pete Posted February 26, 2017 Report Share Posted February 26, 2017 I am looking to buy a used motorhome. One of the units I am looking at does not have leveling jacks. I know from my experience with a truck camper that the refrigerator did not work properly when the unit wasn't level plus it just felt uncomfortable. How do you level a motorhome that does not have leveling jacks? By the way I would be staying at places ranging KOA campground to boondocking. Thanks Lew I wouldn't buy a unit without jacks . And , if there was a unit without jacks that interested me , I'd have to look at having a jack system installed . Of course , you could always look at 'hand leveling' a unit as 'just a part of the RVing fun' . Link to comment Share on other sites More sharing options...
bruce t Posted February 26, 2017 Report Share Posted February 26, 2017 We started out with no jacks on a 35ft mh. I went to Lowes and asked then to cut up a sheet of ply into 12" x 12" squares. Just make sure it's 'good' ply. Link to comment Share on other sites More sharing options...
colomtns Posted February 26, 2017 Author Report Share Posted February 26, 2017 Thanks, for the input. I like the idea of using the wood planks. Link to comment Share on other sites More sharing options...
kb0zke Posted February 27, 2017 Report Share Posted February 27, 2017 Lew, you didn't say what you are looking at. Our 40' Foretravel doesn't have leveling jacks, but we're always level. Why/how? Our coach uses the air bags for the leveling system. Once we're landed, I push the button twice, and the system lowers the high end until the coach is level. If that isn't enough it will start raising the low end. Newell also uses this system, and I think some Country Coach and Beavers do, too. If you don't have a leveling system, some two by planks are a good alternative. As was mentioned, be sure to support both tires for the duals. If weight and space limits allow, I'd make one just a little bit longer than the footprint of the tire, then make a second one long enough for the first one to rest on it. Drill some holes in both so that you can drop four, six, or eight fat nails in to hold the two together. Four such sets would be good enough. If you wanted to get really fancy, make the shortest ones out of 1 by material, then a second level out of the 2 by, then a third one also out of 2 by. That way you can raise in 3/4 inch increments up to 3 3/4" lift. Notice that I didn't specify 2 x 6 or 2 x 8. Measure the footprint of your tire and make sure that you are using something that is slightly wider than that. If you get a coach with drop-down jacks you will need to have something underneath them. If you get a heavy coach, like a Bluebird, you will need something pretty stout to take the weight. Link to comment Share on other sites More sharing options...
Solo18 Posted March 4, 2017 Report Share Posted March 4, 2017 You might want to buy two small levels and put one of them on each side of one of the back corners. That way, you can quickly see how un-level you are. And by the way, the newer refrigerators don't have to be quite as level as the older ones to work efficiently. I carry about five two-foot long 10x2s and only have to use them about once in every three campgrounds. The rest of the time, the sites are level enough to be comfortable. Link to comment Share on other sites More sharing options...
budeneighe Posted March 4, 2017 Report Share Posted March 4, 2017 Just being level enough to work might not be level enough to keep from damaging the refrigerator. http://www.doityourselfrv.com/know-rig-level-enough-rv-refrigerator-work-properly/# Link to comment Share on other sites More sharing options...
