NeverEasy Posted February 23, 2017 Report Share Posted February 23, 2017 While doing the spring checks to get ready for travel, I checked the transmission fluid level. It is just a bit low but I decided to change it as I don't know when and if it was ever done before. I chased down the fluid to be Eaton PS-386, a 50w synthetic. Problem is I can't find any. Volvo dealer only carries the PS-295 for the I-shift. This is what Eaton says: Eaton PS-386 synthetic transmission fluid is approved for these OEM specifications: Emgard MTF 7000 Mack TO-A Plus Navistar MPAPS B-6816 Type II API MT-1 Then I went to Google and it listed Mobile Delvac Synthetic Fluid 50 and Lucas Oil 10146. This stuff is $50-60 a gallon and I need 3.5 gals. The question is: Is anyone else using something that is available on the local market. P.S.: I have 25 gallons of Dexron III! Link to comment Share on other sites More sharing options...
sclord2002 Posted February 23, 2017 Report Share Posted February 23, 2017 You might search for Mobil Delvac SAE 50 synthetic gear oil. Amazon has 4 gallons for 152 bucks. It should be available locally, also. There are many brands of 50 wt synthetic gear oils available. Charlie Link to comment Share on other sites More sharing options...
NeverEasy Posted February 23, 2017 Author Report Share Posted February 23, 2017 Thanks for the reply, Charlie. I tried every auto parts store around. Only one (Advance Auto) could get any but said they could only get 2 gallons. I was just being impatient as the truck is up on blocks so I can crawl under it. It is ready to move and I am ready to go but I won't bring it off the blocks until the fluid is changed. I will likely have to go with Amazon Prime and wait two more days. Chet Link to comment Share on other sites More sharing options...
Shifted Posted February 23, 2017 Report Share Posted February 23, 2017 Valvoline HD Synthetic Transmission Fluid SAE 50 is on Eaton's official list of approved lubricants for the 2nd generation Autoshift. Part # VV706035M is a 5 gallon pail of it. You can find it on eBay for about $250 including shipping. Link to comment Share on other sites More sharing options...
Shifted Posted February 23, 2017 Report Share Posted February 23, 2017 Here are the part #'s if you want different sizes: http://hd.valvoline.com/our-products/valvoline-hd-synthetic-transmission-fluid I found the 5 gallon pail for about $125 last year on eBay. So there are deals to be had on it if you keep an eye out. Here is a link to Eaton's full approved lubricant list. Maybe you can do some searches to come up with something that you prefer. Or call around to see who might carry what you need. https://www.dropbox.com/s/n0oyv2k2b90hvok/Eaton%20Approved%20Lubricant%20Suppliers%20-%20ct_070589.pdf?raw=1 Link to comment Share on other sites More sharing options...
