Seeria Posted February 16, 2017 Report Share Posted February 16, 2017 I picked up a Goal Zero unit and already have a solar panel but it sits on a stand outside. What can I use to do a pass through the wall from the panel outside to the Goal Zero in my kitchen? I'm looking for something water tight or somewhat water tight, 2 cable width or wider (if I can't figure how to cut the ends off and redo them). Not sure what they use on roof tops but I don't think that would work as I have to let out and take in the connection cable so some movement must happen. Suggestions? Link to comment Share on other sites More sharing options...
baphenatem Posted February 16, 2017 Report Share Posted February 16, 2017 This would probably do the trick, or add an outdoor electrical outlet cover over this jack for extra weather protection. https://powerwerx.com/panelpole-panel-mount-powerpole-housing?gclid=CICLg53ck9ICFcu2wAod_TcMxQ Link to comment Share on other sites More sharing options...
rpsinc Posted February 21, 2017 Report Share Posted February 21, 2017 Might also consider using a flat connector for trailer lights, but it would depend on the power you are putting through it. Might be too small. A weather tight connector suitable for your application should work. Doesnt necessarily need to be RV specific. And maybe even mount in a box against the chassis of the coach, out of run off from the wall of the coach. Make sure it has a cover, you dont want to be dealing with mud etc getting into it during travel. Link to comment Share on other sites More sharing options...
Rich&Sylvia Posted February 21, 2017 Report Share Posted February 21, 2017 This might do it for you: RV Solar Entry Gland Link to comment Share on other sites More sharing options...
Shadow Catcher Posted February 21, 2017 Report Share Posted February 21, 2017 I used a Perko watertight deck connector https://www.amazon.com/Perko-1190DP0CHR-Marine-Watertight-Connection/dp/B00144B67C Link to comment Share on other sites More sharing options...
lockmup68 Posted March 1, 2017 Report Share Posted March 1, 2017 These are made for detachable jumper cables and/or winches. 2g wire size should cover just about anything: https://www.amazon.com/Tuff-Stuff-Winch-Quick-Connector/dp/B002CEPI5O Link to comment Share on other sites More sharing options...
